How much fuel is in the tank when the last bar blinks?
Discussion in 'Gen 2 Prius Main Forum' started by gwilliams, Dec 20, 2004.
  1. gwilliams
    gwilliams New Member
    78
    Columbus, OH
    Folks:
    Has anyone come across any "official" documentation from Toyota stating how much fuel remains in the tank/bladder when the last "bar" starts blinking?
    Without a DTE (Distance TO Empty) reading on the computer, it is difficult to estimate how far one can travel when the last fuel bar starts blinking. To date, I have never had a nine gallon fillup, much less 10 or 11. I typically stop for gas when I get down to 1 "bar". With the "snowflake" crushing my fuel economy, I would like to go farther. However, I would like some assurance that there's a modicum of fuel remaining when the last bar blinks.
    Thanks,
    Glenn
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    No telling. I had the TSB for the fuel guage and tank filler tube done since I had been getting flashing and needing to fill with only 8-8.5 gallons. after that...no change.
    Yesterday I drove a full 50 miles past the start of the last bar flashing, filled and topped off with one squeeze....7.5 gallons!! I'd only gone a total of 398 miles. Now, in winter, there is some bladder shrinkage and some loss in total fuel capacity, but surely there should be another 2-3 gallons available, and thus another 150 miles of driving!!
    This is a real problem and the recall repair, in my case and many others, has done nothing to solve the problem. It does make the last 3 bars drop a little more consistantly (~50 miles/bar)
  3. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    I'm seeing about the same as Evan. Even on the one tank when I thought I was stretching out that last blinking bar and driving on fumes, I eeked 493 miles but could only fit 9.8 gallons on the refill. In theory, I guess, I might have been able to drive well over another 100 miles on that last blinking bar.
    On that tank, The MFE read about 48 MPG. And with 490 miles I fit almost 10 gallons. So when I think about it, gauging the amount of fuel remaining based on MPG seems more realistic and what I really rely on these days.
    Mind you, I don't mind refilling less than ten gallons at a time. If anything, it's somewhere securing to know that even when that last bar is blinking there's "emergency" gas still in the tank. It's just that I wish there was a little more accuracy in the gauge.
  4. efusco
    19,891
    1,196
    Nixa, MO
    Although I completely agree with that theory, it is darn hard to keep driving for long past that damn blinking bar!!! My brain starts creating out of fuel scenarios, I start thinking that maybe my last fill wasn't completely full (ie early pump shut off) and I don't have as much fuel left as I think I should and paranoid thought after paranoid though intrudes!!
    I just can't seem to force myself to push more than 50 miles beyond blinking! :oops: :cussing:
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I got the triangle of death of death with 1 bar left on a high speed 360 degree on ramp to a freeway and it wouldn't reset so I took it to the dealer but the tech was booked for the day so on the way home I stopped at a gas station when the last bar started blinking and filled up and the triangle went out. With a bladder I don't think it's really a good idea to push it very far after the last bar starts to blink.
  6. jamarimutt
    jamarimutt New Member
    985
    There should be at least two gallons left in the tank after the last bar starts blinking, but I don't drive more than 30 miles before refueling.
  7. disneydad
    disneydad Junior Member
    85
    Leominster, MA
    I got 55 miles mixed driving, out of my blinking last block, then I ran out of fuel. oops. i had 43 miles out of the one before that, with 1.5 gal left in the tank. and that was in 20ºF weather.
  8. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    I don't quite know the answer to that question but with the last bar blinking I thought that I'd better fill-up. All I could squeeze in was 7.1 gallons. It was 26F outside. I wish they would add a miles to empty function. It couldn't be that hard to update the computer with a new function.
  9. cybele
    cybele New Member
    406
    Los Angeles
    In my experience I've been going 1 gallon past the blinking light - I just figure whatever my most current mileage is. So I usually go about 45-50 miles past the blinking light.
    However, if I know I'm going someplace important or will on the highway in the rain or something, I will not attempt this and I will fill early. I have never run out of gas in my life and I don't plan on starting now.
    I still only put between 7-9 gallons in when I refuel. I'm quite hesitant to try to travel further than the amount of gas I've put into the car. Luckily I find that a 400 mile range is adequate for me - certainly less refueling in my old car that only went 200-220 miles on a tank.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i often wonder if Toyota made a mistake by giving us some much detailed information on our mpg's without a comparable increase in the information regarding other aspects of the car.
    i still cant figure out why we dont have a separate screen for engine diagnosis and monitoring. what Frank can see on his scanner is something i think i should have the right to see if i choose to go to that screen (if it were there)
    weight sensors on the bladder would give us a very comparable reading no matter what the time of year. i am anxious to see what the new model improvements will be and whether Toyota will see fit to include this kind of data. with all the uproar over the fuel gauge inaccuracies, i find it hard to believe that they will not do something about it in the upcoming model change.
  11. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Before the TSB, we averaged about 8 gallon fill ups with the "add Fuel" light going off once and the bar blinking.
    After the TSB for the fuel guage and tank filler tube done, the most I have been able to get in is 6.6 gallons. REALLY really bad - the TSB really messed up.
  12. rflagg
    rflagg Member
    947
    Springfield, VA
    the last bar usually starts blinking on mine between 9.5-10.5 gallons.
    I'm able to have it do this though because I drive as far as possible on each tank. Car MPG x previous fillup gallons = how far you know you can safely travel. Since I've been making sure the car regularly gets 10-11+ gallons of gas in the tank (sometimes taking 5 minutes or more to fill, mind you), and then I regularly do not consider filling up until my car is in the range of Consumption MPG x previous fill - which of course figures out to 10 - 11 x my MPG.
    My car hasn't changed too much since the fuel TSB, though it does seem to be a little more stable as to when the last bar starts to blink.
    Its each individual's decision on how far they want to travel and possibly risking running out of fuel - but I suggest if you do decide to 'risk' it, to have a backup plan available (gas can in car, AAA, etc.)
    -m.
  13. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    I've encountered the blinking bar one time thus far. When I finally reached a gas station I was able to put in 9.5 gallons. Before this I was filling up at three bars every time.
    Regardless, I find that when I fill up slowly I can get more gas into the bladder. I guess this is normal?
  14. Hytec
    Hytec New Member
    236
    MS Gulf Coast
    For what it's worth.....my 2005 has been filled twice since delivery, both times taking about 10 gallons after 450-475 miles. In both cases there was only bar showing, but it was not blinking in either case. Does anyone know if the fuel guage algorithm was changed for the 2005s?
    Slightly off the subject, but still concerning the fuel bladder...each time the tank was filled, the nozzle clicked off around 7.5 gallons. Then I was able to add about 2.5 gallons more before fuel showed at the neck. About 2-3 seconds after the nozzle had been removed and replaced on the pump, there was a "burp" and a good pint of fuel spewed out the neck and down the side of the car. Is this normal for the fuel bladder? I've only had cars with metal fuel tanks and vent pipes, and the tanks always needed to be topped.
    Thanks for any info, Hank
  15. cybele
    cybele New Member
    406
    Los Angeles
    Don't overfill the tank - it's dangerous, it's not good for the tank and it's terrible for the environment.
    Yes, the bladder is what's causing this and it's not a defect, the manual clearly states that you shouldn't overfill the tank. Cramming more gas in there is just a waste - in fact, in some states with vapor recovery systems in place, that extra gas you think is going in there is actually going back into the recovery system tank.
    Just get used to the smaller fills and slightly shorter range, we can all breathe easier for it - and so will you - it takes less time and there's little chance of you arriving at the office stinking of gasoline.
  16. tag
    tag Senior Member
    2,526
    Chicago
    That happened to me........once. After numerous fillups, I have developed a pretty good sense of when to stop squeezing the nozzle.
    Today, the pump clicked off at around 6.5 gallons. I managed to squeeze in another 2.6 for a total of 9.1 gallons. I'm sure I could have squeezed another half gallon or more in there but I would have risked the "burp".
  17. Kurt
    Kurt New Member
    Supposedly some proprietary information I learned yesterday from a Toyota person.
    Toyota knows about the "gauge problem"...I'm not referring to the TSB recall. It's not a gauge problem per my Toyota contact. It has to do with the bladder. The fuel pump pulls the fuel AND the bladder at the same time pulling one side of the bladder up before the other side. This leaves several gallons of gas on the low side of the bladder that cannot be accessed.
    This isn't per me so I cannot give you any other information nor can I substantiate it. Just passing on the info. I'm in the same boat as all of you. I go down to the last bar, drive 40 miles then fill up (before the light blinks) and I max out at 8.3 to 8.5 gallons. It's all the same MPG but it would be great to be able to access the 3 plus gallons!!
  18. tntna
    tntna New Member
    131
    Central OH
    I just filled up when the last bar started blinking and 10.13 gallons fit in the tank. That was when the pump clicked off the first time. Only the second full fill up so I'll keep track to see if 10.13 is the norm.
  19. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    July 4, 2004. drove 73.0 miles after the add fuel warning, and filled up with 10.85 gallons. 51.3 MPG (MFD).
    Next tank, July 10, I traveled 73.0 miles after the add fuel warning. I figured I had a little over a gallon left, another 50 miles at least based on the previous fill and the current 52.1 MPG (MFD). I passed a gas station at 73.1. Ran out of gas at 73.3.
    To be safe, I no longer go more than 20-30 miles after the warning. I rarely get more than 8 gallons in when I fill up. The extra gallon or 2 would get me another trip to work and back.
    That makes sense about the bladder trapping gas. Sounds like they need to redesign the steel tank more like a funnel-shape to allow the gas to move to the pump and let the bladder collapse from the top.
  20. gwilliams
    78
    Columbus, OH
    Here, here! I'm with you.
    If I could trust that the tank could hold 11.9 gallons, I would be confident using the tank average MPG, say times 11 (to be safe) and use that number (minus the current mileage) as a calculated DTE (Distance to empty).
    Today, however, I drove 10 miles into "blinking bar" territory, and put in the lowest amount of fuel to date, 7.815 gallons. Sigh. I just cannot be sure what the ______ tank holds, when fillups are so inconsistent, and so much short of capacity.
    G.
