New tires - Costco options?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pkhoury, Dec 14, 2007.
  1. pkhoury
    pkhoury Proud TDI owner
    183
    I'm almost ready for new tires (I put the bald front ones in the back hoping to get some more life out of the ones formerly in the back that still have tread). I'm partial towards Costco because I can get my tires balanced and rotated while I'm shopping, plus the tread warranty for tire punctures (I wasn't that elated with the warranty coverage from the dealer). So what is a good tire to get? I can't recall what Costco suggested, but they warned against one of the cheapy $69.99 tires. Does anyone have any suggestions? I don't really want to spend a whole lot, and want something that lasts reasonably long, with low noise and good efficiency. Of course, everyone knows the Goodyear Integrity tires suck! I was fortunate and the tires in the front didn't go bald until 30K; I hear a lot of people have them wear out at 20K!
    Paul
  2. toyoprius
    toyoprius New Member
    109
    Boston
    Like you, my front Integritys were shot at 30K. I picked up a couple of Michelin X Radials at Costco. Now at 46K, I'm ready to replace the last two Integritys. I've been happy with the Michelins. As I recall, they were about $100 each installed.
    I've never had front tires go so quickly, or had such a different wear-life between front and rears. I wonder if the regenerative braking is a factor?
    Karl
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    At Costco, we got the Michelin Hydroedges put on Rudy.
    These are amazing tires, especially with the torrential rains and occasional snow/ice we get here.
  4. rufaro
    rufaro WeePoo, Gen II
    2,867
    72
    Lost Angeles
    I have about 25k on my HydroEdges and they are barely worn at all. The car has about 28k on it--I pulled the Integrities @ 3k.
  5. samdaman
    samdaman Junior Member
    75
    Eastern PA
    I went for the Hydroedge at Costco [when they had the added $60 off], but I have to say, my mpg took a fairly large hit - going from the low 50's to mid 40's with no change in driving habits. However, the ride is much better, and handling feels MUCH 'safer', so I consider it a reasonable trade-off.
  6. rufaro
    2,867
    72
    Lost Angeles
    Yup, the mileage took a huge hit. 25k later, I still have lots of tread and the mileage is MUCH better...:cool:
  7. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    I got the X-Radials, since they were more highly rated than the Hydroedges by Consumer Reports (and we don't have to worry about torrential rains in San Diego...). I've been very satisfied with them, and I didn't notice the huge mileage hit that most people had with the Hydroedges.
  8. rufaro
    2,867
    72
    Lost Angeles
    I got the hydroedges just before a winter x-country trip--NoCal to Montreal, via the Canadian Rockies. And we DO get torrential downpours up here in Sonoma County. They proved themselves in a sleet storm going over said Rockies when, with almost any other tire we researched for my particular needs, I'd have been hydroplaning off of a Rocky.
    And http://www.tirerack.com/ rated 'em high for all weather and wear. The mileage hit was DEFINITELY worth it for my purposes.
    It's all a matter of your particular needs, innit?
    OP--where exactly in LoCal (nomenclature courtesy of MarinJohn--blame him for amusing me!) are you geographically? Rainy bit? Do you travel a lot out of your home zone?
  9. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Yeah, the general consensus seems to be that although the performance might not be quite up to the level of the Hydroedge in certain areas, the Costco/Sam's X-Radial (or Michelin Harmony, Sears Agility, or Discount Tire Destiny) also doesn't take as big a hit in fuel mileage, either, and is still a vast improvement over the OEM Integrities.
  10. rufaro
    2,867
    72
    Lost Angeles
    My New Balance tennies are a vast improvement over the OEM Integrities...:eek:
  11. MO51
    MO51 Junior Member
    We just got the Michelin Hydroedge's for our '04. 'Haven't had a chance to check for MPG drop, but am wondering if any of you have upped the tire pressure over the #s recommended on the door jamb. I plan to try that, if the MPG turns out lower. I read that some folks are running replacement tires about 4 psi +, with some good results. Anyone tried this yet? That's well under the max psi stated on the tires' sidewalls. Our OEM integritys, even with rotation and religious attention to recommended pressure, wore on the outside edges, but had maybe 40% tread left in the center, with 34K. That's often a sign of underinflation. We get all our rain in winter in Sacramento, so didn't want to waterski through a season on those tires. The new Hydroedges ride better and quieter, but you'd expect that in a new tire with all its rubber hitting the road.
  12. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    I run the Hydroedges at 42/40, or thereabouts (sometimes it's 41.5/39.5). Mileage has taken a bit of a hit, but how good of MPG can you be getting if you hydroplane off the road?
    Oh, and the cold weather, and short trips, have more impact on my MPG than my tires do.
  13. F8L
    19,011
    4,082
    Grass Valley, CA.
    I have not driven in the hard rain (since we havn't really had any) with my Integritys overinflated but I can say that I'm not seeing any additional wear by having them inflated at 56/54. :)
    I'm considering the Sumitomo HTR 200 as a replacement unless Michelin comes out with something better before then. Or maybe the Nokian. Grr I can't decide. lol
  14. rufaro
    2,867
    72
    Lost Angeles
    What she said. Exactly.
    If you don't live in an area of extreme COLD precipitation (the occasional flurry or hailstorm's ok), but you do get lots of rain...I'll take the mpg hit over the hydroplaning in a heartbeat.
  15. 2PriusFamily
    2PriusFamily Junior Member
    2 Prii: one got Pilot Exalto 195/60R15, one Michelin X
    Our 2004 Prius got the Michelin X, an enormous improvement with no fuel economy hit. Very happy with handling & wear.
    Chose 195/60R15 Michelin Pilot Exalto for the 2005 Prius. Fuel economy hit of 2-4 MPG overall, with the lower, wider tires, but better handling than the X's. Speedometer reads high (47 MPH indicated is 45 MPH actual.)
    The X's have picked up nails as if magnetized; Costco's been great about patching.
    Either is a good choice.
  16. pkhoury
    183
    I ended up getting the X-Radials from Costco around the beginning of February (had a flat, which actually prompted me to get a replacement 4 days before I was planning to!). They do handle better, that I'll agree with, but I've taken about a 5-7mpg hit in fuel economy. This might also be partially related to the fact that 3 days of the week I'm only driving 1.7 miles to and from school and using the freeway more for longer trips instead of surface, but is anyone seeing this drastic of a change? I figured that the money lost in gas savings would cover a new set of tires each year anyways, although I still wonder how tire disposal/recycling works (so I'm not just helping contribute to the landfills more also).
    Paul
  17. PrematurelyGray
    PrematurelyGray Junior Member
    62
    Pittsburgh
    5 - 7 is quite large. So, are your shorter trips concurrent with the new tires? Shorter trips are very detrimental to MPG, so if those trips are new, they are definitely a contributing factor to your lower mpg.
  18. airpolgas
    airpolgas New Member
    108
    Glad I found this thread. I was told by the dealer after my last minor maintenance that I would need new tires "soon." I will probably spring for the X-Radials as well, but I will wait for the next run of Costco Tire coupons.
    What I found curious though is that this is my 40K maintenance and these tires are the ones that came with the car when I bought it new. Did I get freaky Integrities? I try to maintain 42/40.
  19. whodat
    whodat Member
    117
    Aptos, CA
    I also bought the Michelin HydroEdge tires with the $60 off sale for 4 tires at Costco.
    My old Integrities lasted 50K miles.
    I am experiencing a slight mileage hit. From about 58mpg to 53mpg.
    Air pressure is 42 front, 40 rear.
    The handling has improved significantly with the HydroEdge relative to the Integrities on both wet and dry surfaces.
    I'm at $56K miles and the treads are barely worn.
    Dave
  20. nagrath
    nagrath Member
    142
    47
    Putnam County, New York
    2023 Prius Prime
    XSE
    Hi Prius chatters.
    I just heard from my Toyota service (in for the 20,000 check at 21,800) that my tires were very wormn on the outer edges, and will need new tires "soon". That seems crazy to me! I see that most seem to get ~30,000 out of the (lousy) original tires. I asked about checking the alignment, but they told me you shouldn't check alignment with worn tires (this also sounds ridiculous--you can only align a car with new tires?). I am also suffering from SEVERE winter drop-off in mileage (Avg 35 instead of 47 in warmer months) but I am in NY and the winter has NOT been severe. Toyota shrugs and says that everything is controlled by the computer and there is nothing they can do. So I have 2 questions, maybe 3. One I think I know the answer to: misalignment will cause a dropoff in mileage, I would assume, due to increased friction. Do others experience this severe a dropoff in MPG in the winter? In previous years I've had more like a 5mpg dropoff. Have others needed tires at 21,000? I try to maintain 40psi pressure (though, oddly, after I take it to toyota, it's always back down to around 35psi). ( Just talked to Toyota again, and they said that's what they generally see on the OEMs--20-25k. ) Tried to talk me into Michelins, but I will shop around for 'em.
    I guess I am just ranting because they are not helping me with my mileage, my tires are shot at 21k, and my coolant pump is making weird noises but they say it is fine.
    Any comments would be great. I generally love my Prius, but really kinda hate my dealer service. Also, recommendations for a good all-season tire with better-than-oem winter traction that doesn't take too much of a hit on mileage,I'd be appreciative!
    John
