P0304 DTC Code - Cylinder #4 Misfire
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kocho, Mar 4, 2008.
  1. kocho
    kocho Member
    134
    Maryland
    I have been getting this as a "pending" code lately. I found the good advice here that I should try to swap the ignition coils b/w #4 cylinder (all the way at the driver side) with the one next to it and see if the misfire moves to the #3 cylinder. I will do that tonight and also check the plugs condition.
    My question is however, why is there no "freeze frame" data associated with this code? I cleared it once but it reappeared soon after, and I think it did it at start-up when the engine first got going, not while driving...
    Anyway, I'd appreciate any other suggestions in diagnosid/fixing this problem. I will report back how it goes with the coil swap. Btw, my plugs are only about 6K miles/4 months old and are OEM Toyota part - I put them in myself and have not had this issue come-up until recently only.
  2. kocho
    kocho Member
    134
    Maryland
    Well, the pending code cleared itself. So I'm postponing further diagnostics until the time it reappears, if it ever does...
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It's not that hard to swap the coil, see if #3 throws a code
  4. kocho
    kocho Member
    134
    Maryland
    Well, if the code does not re-appear the swap won't help, so I'd rather not do it before I need to - I'm lazy ;)
    I've only seen it twice in "pending" mode (no MIL was on) so far and that was recently. If it does show-up a third time though, then it will likely appear a 4th time later, so then I will do the swap and be ready for it.
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    Swapping the coils shouldn't be too difficult. Once you unbolt and swing aside that relay box above the coils, it's a lot easier to remove the coils and plugs
  6. kocho
    kocho Member
    134
    Maryland
    The code appeared again. So I swapped it, but I think I found the problem. The #4 coil bolt was loose and the coil moved about - no tools necessary to remove :(. That would have probably been enough to cause poor spark now & then and trigger the code. Hopefully, this was it. I'll have to recheck soon and if anything is loose, to put some thread locking compound.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Geez, there ya go. Don't worry I do things like that too. Here, have a drink
    Gluk gluk gluk gluk gluk gluk <clink>
  8. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Make sure water/crud didn't get down into the hole... and
    there's no chafing on the ignitor housing or the like..
    _H*
  9. kocho
    kocho Member
    134
    Maryland
    Good suggestion. I did this and all looks clean and dry. The one bolt was loose only a little but if the engine was washed or something like that water may have entered. But nothing like this seems to have happened - there were a few rains but nothing that would put enough water in that area to go over the rised edge around the spark plug/ignition coil hole in the engine cover...
    The spring inside the coil housing that makes contact with the spark plug and the spark plug end were also clean and dry, so things should be good, I hope.
    The plugs themselves were tight and I did not bother to remove them this time.
