Spark Plugs at 100k
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jsorger, Mar 11, 2008.
  1. jsorger
    jsorger New Member
    97
    Felt like changing mine (sale didn't hurt), perhaps the attached photo can be useful to someone who knows something about plugs. Best I could take without a macro lens.
    I haven't changed a plug in 16 years or so - and the whole notion of not 'gapping' them seems wrong (but so easy!).
    Replacing them had no noticeable effect.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    The plugs look great for having 100k on them.
    Did you have any problem removing them?
    There have been some stories of dificulties with frozen plugs.
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Wow, those look better than mine did at 55K!
    _H*
  5. patsparks
    10,664
    567
    Adelaide South Australia
    I hope you used a never sieze lubricant on the threads of the new plugs and tightened them to specs. If not they may be very hard to get out for the next change.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    I agree, they look great for the milage. I've taken out dozens (sets) of plugs from GM LS1 cars and 5.3L/6.0L trucks and they didn't look that good at 30k let alone 100k. :) I do have to admit that the NGKs tended to look better than the Delcos.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I used to have a 2000 GMC Sierra with a Vortec 5.3 litre V8. I think a similar motor is used by Holden, mine had aluminum heads and iron block
    I changed the plugs in 2002 at around 40,000 km and they were almost impossible to get out. Dry/partially seized and made a screeching noise while being removed. I'm surprised I didn't bugger the threads. GM recommended a 160,000 km interval, they would be impossible to remove at that point
  8. Patrick Wong
    18,200
    6,495
    The used plugs look great, good to know that the ECM is doing its job in providing the correct air/fuel mixture and the engine is not burning oil.
    Did you have an opportunity to measure the gap on the used plugs? The new plug gap is supposed to be measured and adjusted to 1.0 to 1.1 mm. When the gap reaches 1.2 mm, that indicates the plugs need replacement.
    Even though the 2G spark plug replacement interval is 120K miles (except 150K miles for CA and PZEV states) I suggest removing the plugs at 60K miles to inspect them, check the gaps, and apply antiseize lube. This will make them easier to remove when 120K miles arrives.
    I used to own a 1997 Ford Explorer XLT AWD with 5L V8 prior to buying the HiHy. The recommended spark plug change interval was 100K miles. I replaced the platinum plugs at ~80K miles which was a painful process, having to jack up the front, remove the front tires and going in through the wheel wells.
    Some of the spark plug wires (remember when high voltage wires were used?) were fused to the spark plugs so they had to be yanked off. One connector was especially hard to remove, I yanked on it with all my strength, the connector came off, and I scraped a few inches of skin off my arm on the access hole in the wheel well. :hurt:
    Obviously new spark plug wires were needed - I lubed the connectors with dielectric grease to make removal easier for the next owner or mechanic who decided to replace or check the spark plugs. (Why couldn't Ford manufacturing do this?)
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Those look almost perfect. 100K! What a cool car we own. Our car has to have the best fuel management in the business. Those are Platinums and are missing the little ball at the end of the center electrode. I don't know why that ball is there as my Ranger Truck will take a brand new Platinum and in 5K eat that ball right off & make it look like your plugs.
    I try to never let a plug go more that 25K before I break it out and re-apply anti-seize.I had one on a 78 T.A that was never changed out for 60K and I broke it off trying to break it loose. Stripped the plug hole. That was $$$$. Never again.
  10. jsorger
    jsorger New Member
    97
    Thanks for all of the feedback - I had no idea that they looked so good!
    I measured the gaps (after you mentioned) and they are approx 1.1.
    No problem removing them whatsoever, so I didn't use any anti-seize. Made a slight squeaking noise but that's par for the course. I had read about others' problems but did not have any.
  11. patsparks
    10,664
    567
    Get some never-seize and take them out and use it on the threads. Spark plugs shouldn't squeak going in or coming out. You can use molybond grease too.
    If the plugs seize in the head you will do hundreds of dollars damage at the next change.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    Even stripping the threads in a lawnmower engine is a royal PITA. At least it's easy enough to take off the head, heli-coil it, and reassemble. It's a major job on a car though!
  13. hesty24
    hesty24 Junior Member
    San Antonio, Texas
    Jayman, I just popped my plugs out on an 07 Prius with 130K mileage. I hear ya on the screeching noise and tough to get out. I put a light coat of antiseize on my plugs (apparently Toyota advises against it) your thoughts?
