How To Section
Discussion in 'PriusChat Website Questions' started by bat4255, Mar 12, 2008.
  1. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Can a "How to" section be added, for common everyday tasks such as
    Engine Oil Change
    Trans axle Oil Change
    Changing Brake Pads
    Bleeding Brakes
    Changing cabin air filter
    Engine Block Heater
    Blocking the front grill
    etc.
    Keep it limited in size, to aid the search process.
    Perhaps it could be just the links to the appropriate threads.
    It would be one way, to navigate the abundant information the forum has accumulated.
    It took me 1/2 hr. to find information on doing an oil change
    http://john1701a.com/prius/documents/Prius_Maintenance_Changing-Oil.pdf
    If the is a How To section here, I cannot find it. Of course, I may also be blind:help:
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    There's a project in the works. In the mean time John's user's guide covers lots of that stuff very well.
    Bleeding of brakes probably will not be covered as it requires the scan tool to complete the project.
  3. bat4255
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
  4. efusco
    19,891
    1,196
    Nixa, MO
  5. bat4255
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
