Quick - What's your MPG read right now?
Discussion in 'Gen 2 Prius Main Forum' started by vintagebob, Jun 25, 2004.
  1. desynch
    desynch Die-Hard Conservative
    607
    Lakehouse
    27 miles @ 56 MPG.
  2. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    57.8 MPG at 276 miles into this tank with outside temp low 30F ... bring on those spring temperatures
    Gabe
  3. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    74.4 after 331 miles.
  4. My2008Prius
    My2008Prius Junior Member
    96
    Amelia Island / Fernandina Beach, FL
    ... 48.7 mpg @ 328 miles ...
    P&G and stealth has increased this tank up .5 mpg.
  5. cf_coder
    cf_coder Junior Member
    Chandler, Arizona
    52.3 MPG with 198 miles on the current tank. Still haven't managed to shove more than 9.2 gallons of gas in to this sucker.... ;-)
    cf_coder
  6. saminjax
    saminjax Member
    769
    Jacksonville, FL
    51.3, just filled up, on my third tank as of yesterday. I'll check my total mileage when I drive home tonight, but I think I am a little over 1000 total miles.
  7. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    53.0 MPG ---- 303 miles
    Isn't it a riot that we all have this in our heads ? :tea:
  8. Brodie
    Brodie New Member
    162
    Rhode Island
    46.6 on a hundred and something miles into this tank :(. But the car only has 400 miles on it, and I haven't touched anything since I left the dealership (ie tire pressure etc.). Plus I'm learning that my commute is a little too short (7 miles) to really get good mpg.
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    47 mpg
    12 mile commute to work with sucky hills.
  10. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    51.1 at 300 miles on tank. 33 miles to work one way. usually have to go at least 65 to keep from being run off the hiway.
  11. Mike F
    Mike F New Member
    Hi all, my first post here.
    I have 59 mpg at 435 miles. That is UK gallons.
  12. MaulWalker
    MaulWalker New Member
    Marietta GA USA
    200+ miles, 59.2 mpg
    Lynn
  13. Blue Nimhrod
    Blue Nimhrod New Member
    Ashland, MA
    46.0 MPG in Massachusetts
  14. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    44.7 in Scripps Ranch on 2nd tank....currently have 3 "pips" left
  15. diamondlarry
    559
    Elkhart, IN
    75.6 after 406.9 miles with 5 pips showing.
  16. sdtundra
    1,314
    194
    Sacramento, CA
    :eek::eek::eek::eek::blink::blink::blink: how!?
  17. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    46.3 at 418 miles.
  18. spf
    spf Junior Member
    70
    Hey SDTundra,
    How much did you pay for your package 2 and where did you wind up buying it?
    Stan
  19. diamondlarry
    559
    Elkhart, IN
    Most of my driving is on county/rural country roads and I plan my routes to avoid city traffic unless it can't be avoided. I also plan trips to try and avoid heavy traffic times. Also, trip planning helps to ensure that I'm not running late and have to drive faster than necessary to get somewhere. Heavy P&G driving also helps a bunch.;) Gentle acceleration with no assist arrows going to the wheels whenever possible is another technique I use. I have an EV switch but I use it sparingly. One of the games I play is trying to go all day with the battery showing 6 bars the whole time.
  20. diamondlarry
    559
    Elkhart, IN
    I figured that just in case someone tries to call BS on my claim, I'll post a picture. The miles are a bit more since my original post and the mpg is now at 75.8 mpg. Forgive the quality since I'm not a photographer
