Hill Start Assist
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Jan 1, 2005.
  1. Tideland Prius
    16,551
    To quote Toyota Canada:
    "...Uphill Assist Control engages if it senses the vehicle rolling backward when starting on an uphill grade. It first increases the engine torque to resist any rearward motion. If more assistance is required, the brakes are applied to the rear wheels, and the brake light goes on. The system is designed to resist rollback long enough to enable the driver to move between the brake pedal and throttle..."
    I've tried it on a parking lot ramp and the Prius rolled backwards. I did not see the brakelight come on either. Has anyone else tried this?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it may be disabled. They turned off a handful of features when producting this car. I have had the prius roll back too.. it's more of a slip when going backwards.. you can tell the idle is trying to keep you going forward. Kindof a strange sensations.
    Another featuer they turned off was the speed volume control. As the car goes faster, the volume would gradually get louder. Even my brothers F350 has that, with seat heaters, and a moon roof.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    never made it to production, we discussed this back in January of 2k4 on PC
  4. Tideland Prius
    16,551
    Wow, another boo boo in their 2005 Prius article? I would understand if it was teh 2004 Prius article. Ouch.
