142MPG? I need some help here.
Discussion in 'Gen 2 Prius Technical Discussion' started by anti-gas, Apr 1, 2008.
  1. anti-gas
    anti-gas Reduce, Reuse and Conserve
    56
    South Florida
    Well, I would like to think I am getting close to 142mpg, however I doubt that is happening. This is my 4th fill-up on my 2008 Prius and my fuel gauge still says I have a full tank. One time I went to 118miles before it dropped down a bar and then the bars went fast, and the other 2 fill-ups seemed to be normal in the display. Has anyone else had this problem?
    I am trying to determine if I should wait a bit longer, or bring it in for service as a possible bad sender unit in the fuel tank.
    Any ideas, comments or suggestions??
    Thanks.
  2. richard schumacher
    7,664
    1,046
    United States
    Wait, what makes you think it's getting 142 MPG? How many miles total have you driven it, and how many gallons of gas total have you put in it?
    The fuel gauge is very nonlinear and the tank volume itself is variable, so you can't judge anything from how fast or slowly the bars on the fuel gauge fall. Or are you saying that the bars never change? (But then how did you know when to buy gas?) In that case, time for a trip to the dealer for warranty repair.
  3. anti-gas
    56
    South Florida
    Sorry, maybe I was not clear in my rambling. Since I have filled up my tank, I have driven over 142miles and my gas gauge hasn't dropped. It still shows that I have a full tank. That is my concern. My last fill-up took 12.2 gals of gas and I don't ever top off, just put the nozzle in, and when the thing clicks off, I'm done.
    So I'm wondering if something is wrong as I would assume that I should at least shown 1 or 2 bars down on the fuel gauge.
  4. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Sometimes that's just the way you're fuel tank will react. One time in the late-summer I got over 185 miles before losing the first "pip" on my tank readout. And I wasn't even getting 50mpg.
    The readout will catch up eventually - 1 "pip" does not mean 1 gallon.
  5. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Your gauge is normal. Because of the odd size and bladder system in the tank,
    you may go 150 miles before the first pip disappears on the gauge. I've found that if the tank is completely full in the summer I can use three gallons or 150 miles before the gauge changes. Then it's about a gallon or less per pip for the rest of the tank.
  6. anti-gas
    56
    South Florida
    Weird. I will wait it out then, I should see some movement in the gauge today then, as I will be driving another 10 or 20 miles later on. I would like to think I am getting 142mpg, but I know that is simply not the case. I have been getting a steady 49mph lifetime since I bought the car about 2 months ago.
    I sure do love this little gas sipper! I only wish I could run electric only cost effectively, but that is a discussion for another thread.
    Thanks, and I will keep watch on the gauge today.
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Yeah, I feel that if you take it into the dealer, they will hold it for a day and then tell you that they replaced the Flambo-Regulator Device (FRD), reprogrammed the Fuel Regulation Computer (FRC), and reconfigured the Anti-Nozzle Inverter (part# 1D-10T). This will cost you $120 plus three hours of labor.
    "That should fix it but if you see it again, be sure to bring it back and we'll be happy to take another look at it for you."
    I'm never concerned with that's going on in the upper reaches of the guess gauge. It's on the lower end that I pay attention.
  8. Patrick Wong
    18,210
    6,511
    It's too soon to say if anything is wrong with your car.
    My question is, how did you manage to pump 12.2 gallons into a bladder-equipped Prius fuel tank? Most owners are lucky to get 10 gallons in, even with multiple click-offs.
    I am wondering if your gas pump cheated you.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    12. 2 gallons into a 11.9 gallon tank and you still delude yourself into thinking you did not top off?? you are either
    1)getting ripped off by the gas station you used
    2) using a gas pump that was malfunctioning,
    3) putting WAAAAY too much into the gas gauge (more commonly referred to as "guess gauge" btw)
    the only thing i would go by is that when the last bar starts blinking you should stop and get gas. everything else on that gauge is a very loosely formed guideline and should never be used to determine what your gas mileage is...
    and btw, what does your display say your mileage is?
  10. anti-gas
    56
    South Florida
    You know its funny you mentioned that because prior to this fill up, I haven't been able to put more than 7.9 gallons into the tank and I would fill up at 2 bars remaining. This fill-up I drove about 10 miles on one bar remaining. I just set the pump and when it clicks off, I hang it up.
    Heading out right now to drive some more. Will see if the gauge moves.
    Thanks.
  11. anti-gas
    56
    South Florida
    I somehow thought that the gas tank held 12.9 gals. I'm on my way to the gas station right now to complain. I'm brining a 5 gal. gas can and going to see if that pump is accurate with 5 gallons. If not, I'm bringing it to their attention with my receipt that clearly shows over 12 gallons into a 11gal tank!
    Let you know my findings.
    :mmph:
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I have unintentionally (poorly adjusted pump) completely filled the tank twice and intentionally done so another few times. Each time I go about 200 km or 120 mi or maybe a bit more before the first pip goes out (highway). In the city perhaps a bit farther.
    I -always- check after filling to see if I can see the fuel level in the cars' filler pipe. If I completely fill I can, but if I rely on the shutoff of the pump I never can, just the bubbles which settle out out of sight quickly.
    Completely filling the tank is not really a good idea. The fuel can be forced into the vapour recovery system and get between the bladder and the tank body, where it will cause corrosion damage. New tank is $400+!
    What happens (I think), is the fuel expands after you pump it in. It has nowhere to go so pressure builds up and forces it through the vapour recovery system. If it's cool out (less than 50F) or if you immediately head out on the highway and burn at least a gallon in the next 30 min you would be ok as that's about how much the fuel in the tank will expand (about 2.5 litres - 50F fuel and 80F ambient temp - last time I calculated it).
  13. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    12.2 gallons? Yeah, something's fishy there. I can rarely squeeze more than 35L (~10gal) into my Prius, even when near-empty. However, if your tank was "very" topped up, it would explain why the first pip took so long to disappear.
    On a totally different tangent, is there another driver on your car who may be playing a trick on you by topping off your tank after you've driven some 75 miles or so? It won't reset the Consumption screen 'distance' automatically with a small fill.
    Remember, it *IS* April 1st, after all... :cool:
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i dont think the OP is using the consumption screen. just going by the gas gauge thinking each pip is a tenth of the tank.
    all in all, the display is very accurate at telling you what your MPG's are. many complain it reads to high, etc...but i think its by far, more accurate than pump readings, etc...
    to really get a true picture, you need to track both the display readings (making sure you manually reset every time you fill up. use trip A or B also so you get mileage in 10th's) for several fillups. i would not even start to make conclusions until you have done a minimum of 3-4 fillups.
  15. richard schumacher
    7,664
    1,046
    United States
    Nope, it's not nearly that linear. Whatever the MFD shows as your current MPGs is pretty nearly correct because it counts actuations of the #1 (?) fuel injector. It doesn't use the fuel gauge.
  16. hill
    8,898
    I think the record I've seen on PC was over 200 miles on the first pip. I'm certain that the insane hypermiler that went over 1,000 miles on one tank probably put the 200 mile pip to shame, too.
  17. anti-gas
    56
    South Florida
    Well, drove some more miles and my fuel gauge after driving 168miles since my last fill-up still shows that I have a full tank.
    Or should I start calling it my guess gauge?
    The first 3 fill-ups the fuel gauge seemed to work fine, this time though it seems like it is stuck. I was thinking of releasing my gas cap to see if there is excess pressure in there or something. Maybe I'm crazy, but I have to try something. I really don't want to bring my car to the dealer and have some yo-yo start replacing parts on my brand new car unless I have to.:confused:
  18. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I wouldn't even start to worry about it until you get to over 250 miles. On the flip side I was down to just 1 PIP and only had a $20 bill on me, so I just put the $20 in the gas tank (6.5 gallons @ $3.069) and my gauge only went up to 4 PIPS and has stayed at the 4 pip level for 85 miles now.
  19. spf
    spf Junior Member
    70
    I'm a new Prius ownere and need some input here from you kind folks. Maybe I'm a little slow (my family would say "yes!"), but let's say I'm going on a trip for a thousand miles, and I don't want to fill up the gas tank until I'm down to my last 50 miles or so. If the gas gauge is not that accurate (at least until the last pip starts blinking), then how will I know how much further I can go?
    Should I just use common sense and assume the MFD mpg (let's say it's showing 48mpg) is fairly accurate and multiply the mpg by, say 10 gallons and therefore conclude that I can go at least (48mph x 10 gal = 480 miles) without having to worry about it?
    On previous cars I liked to take the fuel gauge down to a pretty low level at times just to see how many miles I can get out of it, but on a trip I wouldn't want to get stuck out in the middle of nowhere by assuming I had more fuel than I really did.
    Any thoughts/suggestions/ramblings are welcome.
    Thanks!
  20. Patrick Wong
    18,210
    6,511
    It is not wise to assume you have 10 gallons of fuel in the tank. In the winter, since the bladder shrinks, you might only have 8-9 gallons.
    Since the fuel tank capacity is variable and the guess gauge is not aways predictable, your desire to drive until you have 50 miles remaining (which means one gallon of gas) may result in out-of-gas situations.
    Unless you don't mind running out of gas, its better to be conservative and refuel when you see two bars (or more) remaining on your fuel gauge.
