Motor Silk? Oil additive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bill Merchant, Apr 4, 2008.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I was at The Better Living Show in Portland last weekend and talked with a local distributor of Motor Silk. He said his "tech guy" drives a Prius and got 70 MPG on a 40 mile highway trip recently. I haven't talked to his "tech guy" yet, but I though I would ask here if anyone has used this product or other boron based additives. The description of the boron crystal lattice structure seems plausible. They claim testing by Argonne National Lab.
  2. gman11377
    gman11377 New Member
    66
    South Georgia
    Very interesting, boron coating of metal can be done in a solution, as they claim, and they seem to have plausible/reasonable goals that their additive achieves over a reasonable amount of time. Will definately have to look into this further...Might even have to try it. Have watched all of the informercials for the different products come and go, although it was fun watching them drive a car without oil, shoot it with a laser, and grind on it with an angle-grinder, all of that amounted to nothing when it comes to what the product could actually do. Heck, Z-max even turned out to be not much more than tinted mineral oil. Gonna look into this some more.
  3. Winston
    Winston Member
    614
    SF Bay Area, California
  4. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    that's very interesting. dont most prius owners advise against oil/fuel additives though? I used to run slick 50 in my oil in regular car and it did improve MPG ever so slightly. Keep us posted!
    from the site it seems 12.8 oz. would be more then enough for our small engines..
  5. joeszabo
    joeszabo Junior Member
    39
    I have been using a certain synthetic metal conditioner product called Militech-1 over the last 15 years or so now and while I can't be 100% sure (maybe just a placebo effect), I suspect it has always improved the engine performance of my vehicle's by conditioning the metal in the engine to reduce friction. This said, my main reason to using this was to extend engine life, and I have never had any engine wear issues. I saw a (dramatic) trade show demo of this product, where they would apply pressure to a bearing treated with various oil additives (one at a time) and then measured the torque required to stop the bearing. Most products like Slick 50 and others would allow lower levels of friction to stop the bearing, while this product made it very difficult to (about 15-25 times the force) stop the bearing.
    When I added this product to my '08 Prius, it's shown almost an immediate improvement in mpg (2-3 mpg / I drive 180 miles daily) on the first two tanks of gas with it on my oil change. The downside of this product is that it calls to be added at each oil change at about 2 ounces per quart (7 ounces for 3 1/2 quarts) and it cost about $55 for two 16 ounce bottles. Since I intend to change my (0-20 synthetic) oil at a longer intervals, 10,000 miles (or every 3 months with my current commute) this may easily pay for itself on my ’08 Prius.
    Militech’s web-site (warning- it’s a bit hokey so I don’t want to provide a link – you can google it if you like and find it) does have some state MTA testing data to support the reduced engine wear claims and better mpg, but surprisingly the product is primarily intended to be used for firearms lubrication and friction reduction.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The EPA has tested these claims, and unless you believe there is a Conspiracy going on, most have been debunked. The ones that did work had minor improvement
    The way you drive will have the biggest impact on your fuel economy. SLowing down from 75 to 55 mph will provide the most improvement
    As far as massive doses of boron or other chemicals/compounds, what effect will they have on the o2 sensor or catalytic converter?
  7. Bill Merchant
    4,096
    87
    Why would boron in the oil have any effect on the O2 sensor or catalytic converter? I don't understand.
  8. Winston
    Winston Member
    614
    In general, if there was a significant effect on mpg with some additive, the mfg's would put it in the oil. The reality is, over the past 20 years they have found things that reduce friction and decrease wear in engines. Today's oil is quite a bit different than it was 20 years ago. If you purchase a name brand oil, it will have all the latest additives included already. They will be added at proper amounts to be optimally effective too.
    That 3-ball wear test that they did at the state fair, does not relate to the way that motor oil lubricates your engine. Good 3-ball wear test does not equal good motor oil.
  9. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I haven't tried it and probably won't.
    With the cost of their $77 treatment package, I can drive my Prius a couple of months.
    I find it interesting that their EAC-3&4 packages include "Gear Treatment for Manuel Transmissions". Must be for Mexican transmissions!:eek:
  10. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I'm curious if the auto trans product is compatible with the Prius CVT.
  11. Bill Merchant
    4,096
    87
    More on Boron Oil additive
    I have a bit more information about using boron as a lubricant. The research was done by Ali Erdemir at Argonne National Laboratory in Illinois. Here's a link to Nano-boric acid makes motor oil more slippery.
    Paul Osterlund, the "tech guy" at Green Lubrication Solutions, the local distributor of Motor Silk, had lunch with The Portland Area HSD Meetup Group today. He freely admits that his high MPG in last week's rally was due to a confluence of good factors: warm weather (it hit 80° F, today it's 44°), tires at 50 psi, lucky breaks with traffic lights, a tanker truck in front of him on the interstate portion, and mostly his pulse-and-glide technique. He doesn't claim Motor Silk will give everybody hypermiler capability, but he thinks it helps.
    Paul treated his oil a few thousand miles ago. He said it took about 800 miles to notice any difference, but now he thinks the ICE starts more easily (making it harder for him to feel the transition, so P&G a little harder). He also said that the treatment is a one-time thing, so boric acid isn't used as an oil additive with every oil change.
    I asked him if he had thought about adding the compound to the PSD. He hasn't done that.
    I'm interested in the possibilities of lowering friction and improving fuel efficiency. I'll let you know if I try this stuff. You can see I'm the worst Prius driver.
  12. diamondlarry
    559
    Elkhart, IN
    Thanks for the update Bill. I put some Motor Silk in on 4/17/08. I'll keep checking my past fuel logs to see if there is any difference in last years numbers. Also, Kimberly from Evergreen told me that their auto-trans formula won't work in the Prius CVT.:(
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Re: More on Boron Oil additive
    Ah, this is starting to make sense now. It's very misleading for the Motor Silk guy to brag about what great mileage his Prius is getting, then admit that
    I would like to see instrumented lab testing performed by the EPA to confirm this. The following EPA site does test claimed fuel saving devices or additives
    Gas Saving and Emission Reduction Devices Evaluation | Cars and Light Trucks | US EPA
    The ANL research is pretty exotic, I really don't see how Motor Silk could replicate this if ANL is still in advanced lab testing.
    It's important to do advanced lifecycle testing to ensure the long-term stability of emissions control equipment. For example, the ACEA has a pretty long list of "banned" metals for cars that are expected to offer California Emissions performance.
    ZDDP is a proven antiwear additive that works especially well for "sliding" point contact, the best example being a hydraulic or solid lifter on a camshaft. Camshaft lobes are only surface hardened.
    The phosphorous in ZDDP will apparently reduce the life and effectiveness of both O2 sensors and catalytic converters. Since very few modern vehicles have camshafts with pushrods, ZDDP is no longer needed. The few vehicles with pushrods, such as the GM Vortec V8's used in pickup trucks, use roller lifters to eliminate that sort of sliding friction
    Fuels can also effect emissions. The former Ethyl Corp - now Afton - pretty strongly denies any link between their MMT antiknock additive and reduced catalyst and O2 sensor life. All the car makers state to avoid MMT gasolines, and ACEA also forbids it.
    The Boron that is now in motor oils, and the nanoparticle boric acid work being done at ANL, is quite different. As now used in motor oils, boron is an antiwear additive. Like any other additive, careful attention has to be paid to additive levels and the impact on O2 sensors and catalytic converters
    I believe the ANL research on nanoparticle borics hold a lot of promise. It will probably be awhile before such additives show up in conventional oils
  14. Bill Merchant
    4,096
    87
    Perhaps I misstated the connection. You can see from the rally results he had the best MPG score, with 71.18, AND he uses Motor Silk and believes it helps. I don't think he ever claimed directly that Motor Silk gave him 71+ mpg.
    The hydrogen orthoborate which reduces to boric oxide in Motor Silk is a direct development from ANL and is available now. One thing Paul Osterlund emphasized is that Motor Silk is a metal treatment, not an oil additive which must be present in the oil to be effective. It is in an oil-based carrier, since engine oil contacts all the wear surfaces that you want to form a boric oxide boundary layer on the metal substrate. Put it in once and you're done, you don't need to add it again.
    As I said, I'm intrigued by something that may reduce engine friction by up to 80%, and engine wear by up to 90%. And yes, it does seem almost too good to be true. That's why I asked all the open-minded people of PriusChat for their take.
    I'll probably do a Motor Silk treatment at my next oil change and will share my findings. I'll be very interested in your results, too, diamondlarry. Osterlund said it took about 800 miles in his Prius before he started to notice any difference. It's a shame Evergreen America won't vouch for Boron CLS effectiveness for the Prius PSD, I would think that to be an ideal place to reduce friction and wear. I suspect they don't want to risk having any liability for replacing a PSD.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Bill
    Hydrogen orthoborate *is* boric acid by another name. Please verify this by the general description
    BORIC ACID
    The Argonne development of nano boric acid is entirely different. ANL did *not* "invent" boric acid, it was first prepared from borax in the late 1600's.
    The ANL has done pioneering work on creating "nano" particles, in particular "nanofluids." This work is still experimental
    Argonne Transportation - Nanofluids
    Argonne Transportation - Near-Frictionless Carbon Coating
    Call me a skeptic, but I want to see third-party verifiable results from "official" sources. A lot of the Snake Oil claims are dubious at best, eg Slick 50
    jay
  16. Bill Merchant
    4,096
    87
    Jay
    I know hydrogen orthoborate = boric acid, also called orthoboric acid and trihydroxidoboron. But ANL did not develop the technique for producing 3.18 Ã… thick "nano" boric acid crystals, that just happens. Thank you for your insight and opinion. For anyone else following this thread, here's a photomicrograph of boric acid showing the crystalline layers and a ball-and-stick diagram showing how hydrogen bonds (---) make B(OH)3 form layers.
    [​IMG][​IMG]
    Boric acid also makes a good ant and roach killer.
    Maybe this discussion belongs in the Chemistry Forum...
  17. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Bill,
    I could be wrong and have demonstrated my ability to be so before, but I don't think Jay was attacking your find per se. It appears he was just trying to say that any additive or change to the oil system could have other effects than the one you want.
    It seems that any product is a trade off: desired plus possible unknown or not desired. Maybe it is a balance we just have to make an informed choice about.
    Thanks for the find. I will examine it further also. In the past I was one of those who thought Slick 50 was good stuff. It just goes to show that my education was so compartmentalized that I knew nothing at all when I really needed it.
    It would be great if this product was all positive and no negative wouldnt it?
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    Bill
    I'm not in any way attacking your character or your mention of this product. However, I'm skeptical of any claim that a fluid alone will increase fuel economy 5-10 mpg
    I've used everything from 15W-40 HD diesel motor oil (In hot summer temps, never in cold temps) to Mobil 1 0W-20 in my Prius. In summer driving, perhaps 2 MPG difference between the 15W-40 and the 0W-20
    In bitter cold winter driving, perhaps I can average 3 MPG more running Mobil 1 0W-20 vs Mobil 1 0W-30. I'm absolutely convinced, and this is also proven with testing, that high quality light viscosity motor oils improve fuel economy and engine protection in cold temps
    Where I have issue is when a company makes rather extrodinary claims with no independent third party verification. The only way to eliminate such factors as wind resistance, temperature, driver variability, is to instrument an engine dynometer and perform very closely controlled testing
    Unless I missed it, nowhere in the ANL site did I see mention that this product is already in use. I'm sure once ANL has proven the product in advanced lab testing, we will see the major oil companies market it
    A concern I have is someone applying this product and actually causing damage, eg to the Prius cvt or to a conventional automatic transmission. I've had a coworker who - through good intentions - applied a snake oil treatment to her automatic transmission, which started slipping.
    A very costly rebuild was necessary. True enough, her transmission was probably already worn out, but the snake oil either contributed to the demise or did nothing to prevent it.
    As far as currently available synthetics, I first started using them 24 years ago due to their proven low temperature performance, including protection from sludge at very cold temps. I discount any claims of magic fuel economy improvements from these oils.
    One thing everybody should keep in mind regarding the API/ILSAC, and even the ACEA, fuel economy "improvement" test: the reference oil is a HD 15W-40. So any claim of fuel economy improvement is in relation to running a 15W-40 at normal operating temps
    The usual order of "gain" is around 2% for a 5W-30, and around 3% for a 5W-20. If you're getting 20 mpg, you will gain - at most - 0.6 mpg. If you are getting 50 mpg, you will gain - at most - 1.5 mpg. This is within statistical variation
    jay
  19. Winston
    Winston Member
    614
    I dont think there is much energy used to overcome friction in an engine. Anyone know what percent of fuel energy is used to overcome engine friction? I am guessing no more than 5%. So, a 20% reduction in friction will only give you a 1% improvement in mpg.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    There isn't much data out there
    Advanced Technologies & Energy Efficiency
    Euro Auto - Coatings To Improve Performance - 05/06
    According to most of the literature, around 15-20% of motor energy input is consumed by internal friction, which will show up as heat. Rather than using a magic elixir, special surface coatings have to be applied directly to the materials: piston rings, cylinder liners, camshafts, and bearings
    Just by using low tension moly rings, we have achieved some progress. It's obvious that more has to be done
    Work has also been done with very large industrial motors used for power generation and co-generation. A Waukesha was prototyped and they discovered that by reducing friction 50%, fuel consumption was reduced 2%.
    Information Bridge: DOE Scientific and Technical Information - - Document #890706
    That will obviously pay off for power generation, if oil consumption and durability can be controlled
