Tire Pressure - MPG/Harsh Ride?
Discussion in 'Gen 2 Prius Main Forum' started by Ronald56, Apr 12, 2008.
  1. Ronald56
    Ronald56 Junior Member
    51
    Stony Brook, New York
    I have a 07 Prius with Goodyear Comfortreds P185/65R15 which I traded for the day I picked up my car. I have only been getting around 42-45 mpgs over the winter (New York), most of my travel is highway. I noticed my inflation this morning was only between 32-35. I have read posts regarding proper inflation - with most people mentioning mpgs v. ride etc. I guess there is a balance. I would not like a really harsh ride, but on the other hand I would love to get better mileage. Is there a happy median for this? Thanks.
  2. eestlane
    eestlane Member
    110
    Space Coast, FL
    38 in front and 35 in rear (I rarely have rear passengers or weighty stuff in trunk) seems to be a good happy medium for me regarding mileage vs ride quality. :)
  3. sandman
    sandman Member
    277
    32
    kentucky
    I am running 44(front)/42(rear) tire pressure I think it has a great ride but I was used to my truck that has over 590,000 miles so I would up the air pressure and see what you think if you dont like it let it back out...:) I am also very happy with the MPG's that I am getting ...
  4. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    I drive in NJ, so I know how bad the roads are here. After much experimentation 38/36 is about the most I can stand in my stock tires. It did help the mileage a little.
  5. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Warm Weather + 40/38 PSI Should = 46/48 MPG
    I keep my Comfortreds at 40/38 and get around 46/48 MPG with 75% highway driving at around 72/73 MPH (how fast can you go on the LIE?). I don't notice a harsher ride with the higher PSI, but the Comfortreds are MUCH quieter and smoother than the crap OEM Integrities.
    Every so often I'll average 48/50 MPG when I leave for work early, hit more traffic and average around 68/70 MPH (like this week).
  6. Patton
    Patton New Member
    Forgive the noob, but I noticed you guys are getting mid to upper forties mpg. Im getting mid 60's average, half highway and half city. What do people normally get? I might drive differently than most though, I work the throttle to go to neutral when I see a red light in the distance, hardly EVER use my caliper brakes, and never see speeds over 60mph. Drag sucks, literally.
    Also thanks for the PSI info, but I was wondering what is a realistic max PSI that I shouldn’t exceed? Just what’s posted on the tire? I don’t care about the harshness of the ride, I went to the Prius from a ZR1 so the tires could be made of tungsten and I wouldn’t notice.
    Also wondering what tires have the best rolling efficiency,
    Thanks again!
  7. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Mid 60's? I'm jealous. Between winter temps (even with engine block heater) and AC in summer I can only manage the mpg below, half 65 mph freeway and half surface streets. Average for all drivers looks like 48 mpg, see Hybrid Mileage Database - GreenHybrid
    I run 40/38 (mostly, they seem to leak slowly) on original Goodyears, no complaints from the wife about a harsh ride, handles ok for me. Some people run much higher than that, there's probably a gradation into higher failure rate, such as from hitting a pothole at 48/46. For tires, the search engine is your friend! Welcome to PriusChat!!
  8. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    40/38 when I bother to check it. I'm getting 50.6 lifetime avg, without even trying. Also have over 63,000 on the original Goodyears. 99% highway driving. YMMV. :)
    I'm happy with the ride and handling, for what it is.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    You can always try to run crazy pressures like some of us (60-70psi) and see if you can get used to the harsher? ride. Then if it is unbearable drop it down into the mid 40s and it might feel like a Cadillac. lol
    Personally I don't mind the high pressures except for the noise/vibration when going over chopped up roadways.
