What is the little key do.....
Discussion in 'Gen 2 Prius Main Forum' started by Artofprius, Apr 14, 2008.
  1. Artofprius
    Artofprius New Member
    Sacramento
    Was wondering what happens if your prius remote runs out of battery does the little key only open the door or it actually starts the car from somewhere. thx guys
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    the mechanical key only opens the driver's door. You still use the fob in the slot to start the car...that's a passive process for the fob and doesn't require a working battery.
  3. Artofprius
    Sacramento
    Thank you very much
  4. sfl109415
    sfl109415 New Member
    TN
    Thought I would hijack this thread since the OP got his answer.
    About that little key. We bought our Prius about a month ago. The dealer ordered a second key for us. It arrived yesterday in the mail. I went to the local dealer and paid 37 bucks to have it programmed however the little mechanical key was a blank and was not cut. The dealer told me the key should have been cut at the factory and now could be cut by no one.
    Can anyone confirm this one way or the other. Doesn't sound right to me.
    Thanks
    SL
  5. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    can't confirm or deny for you, but i dont see why someone at your local home improvement store couldn't cut it for you, especially since you have the blank.:D
  6. sfl109415
    TN
    Yeah I was just thinking the same thing, I will try that tonight and report back.
    Thanks
    SL
  7. qbee42
    3,076
    The mechanical key can be cut by anyone with good key cutting equipment. I prefer a lock shop or locksmith, since they have more experience.
  8. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    A new Prius normally comes with 2 keyfobs with the mechanical keys already cut for that car.
    Extra keyfobs available from the parts department come with uncut keys. The car has to be programmed for the new keyfob, and the mechanical key cut. $37 for programming is less than many people have paid, so that's not a ripoff. But not cutting the mechanical key is rather poor service.
    A good reason to have the dealer cut the mechanical key is that they have the proper equipment to do it. I took one to my local hardware store, and the machine couldn't hold the little key properly. They botched the job, and I had to get another blank ($7) from a dealer.
    The real reason to buy a cut key from a dealer is that they have a supply of blanks to waste until they make one that works...
    The local hardware store is a good place to get $2 copies on ordinary Toyota key blanks. I carry one on my keychain, as it's much more convenient than taking out the keyfob one.
  9. MyBlueC5
    MyBlueC5 The Corvette Guy
    Phoenix
    You should be able to just go to a Lowe's or Home Depot or something and get it cut.
  10. sfl109415
    TN
    Thanks guys, I went to Home Depot tonight. The guy cut the key in about 5 seconds and said no charge since I had the blank. Went out to the parking lot and it worked perfectly. Thought I would post so others might know.
    Thanks again
    SL
