Anyone Have A Rear Spoiler On Their Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Grocked, Apr 21, 2008.
  1. Grocked
    Grocked Green Patriot
    71
    Los Angeles
    Anyone Have A Rear (Aftermarket) Spoiler On Their Prius?
    Any pictures would be appreciated! I think it would be like a Prius mullet! :eek:
    business in the front.........PARTY IN THE BACK!!! :mullet:
  2. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    I take it you mean an aftermarket spoiler? Because all 2004 and up Prii have spoilers, and the touring has a slightly larger spoiler than non-touring models.
  3. Grocked
    71
    Los Angeles
    Yes, aftermarket spoiler. Thank you. I'll correct it.
  4. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Where would you put it? Why would you even think of having one?
  5. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    So you want to do this to a Prius???
    Or worse yet....
  6. hill
    8,803
    Maybe some big 'ol side scoops like the ferarri testerosa, too?
    :D
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    From my years of owning a 3rd gen RX-7 (with a "stock" rear spoiler).
    A rear spoiler:
    1. Makes the hatch too heavy for the pressurized lifts to push it up.
    2. Makes it hard to back up, as it blocks the view (white cane comes out and drivers door is open).
    3. Makes the car look a little "ricey", though not always. Sometimes it looks ok (the stock RX-7 one was ok), sometimes it looks ridiculous (see previous post)!
    4. Sometimes it actually provides -some- downforce at legal speeds, though usually not. i.e. Last Supra spoiler provided 80 lbs of rear downforce at 100 MPH, spoiler weighted about 40 lbs. It did little at 75 MPH. Rx-7 one did nothing.
    Now, let's get positive. Add a front "chin spoiler", made of urethane rubber (so you don't break it). Add a rear diffuser (goes under rear of car and directs air out the rear instead of the sides), which reduces rear lift without adding drag. In fact, a rear diffuser reduces drag by helping to fill the hole in the air the car makes while moving. Of course, both of these begin to have an effect only above about 70 MPH. Do you drive your Prius at these speeds?
  8. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Rice is as rice does.:p
  9. discoganya
    discoganya Junior Member
    37
    SF Bay Area
    Someone should attempt this on a Prius:
  10. powerjo
    powerjo Member
    112
    42
    Hong Kong
  11. TruSound
    TruSound Member
    246
    32
    The 818
    FIP violation for sure...Fédération Internationale de l'Prius
