Ever Seen or Done This?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hill, Apr 23, 2008.
  1. hill
    8,794
    Just curious.
  2. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    Looks like someone smeared some blue boogers on your lug nuts to make sure they don't back off?
  3. Grunthos
    Grunthos Senior Azgoth Poetmaster
    81
    Minneapolis, MN
    Uh...why? What is the point?
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    Trying to determine if someone is loosening your lug nuts?
    I used to have a coworker who was paranoid about someone entering her office when she wasn't there so she stuck tape across the door and doorjamb. We discovered it when someone entered her office when she wasn't there. :D
  5. Austin50mpg
    Austin50mpg Prius Driving Right Winger
    197
    Austin
    Ok Hill what is the blue crud?
  6. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    thread lock on the outside of the lug nuts and the valve stem cap . . . looks a little like paranoia :boink:
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Is the oh-so-chic valve stem cover significant?
  8. bwilson4web
    16,192
    One wheel or all four?
    Can you take the valve cap off?
  9. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    did u leave a note on the drivers windsheild, excuse me sir but why did you do this?
    maybe its supposed to look cool when the wheels are spinning
  10. hill
    8,794
    Yep, anti paranoid compound. The aerospace industry calls it anti-tamper compound. After experiencing several shops 'saying' they rotated tires, this seemed a sure fire way to assure the job was done. Killing 2 birds w/ one stone, read a few blogs outside PC. More than a few have had hate mongers loosen lugs. The valve stem has it because 100% of the time that I ask the shop to LEAVE the PRESSURE alone, they still re-set it to 36lbs. What the heck, it only took a half minute to do it, and maybe a minute to reapply it after the rotation. OK, I admit it. It's over kill :D
    But ya neva neva know.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    That is very odd.
  12. hill
    8,794
    That's just a costco thing ... they put on green so it lets 'em know its filled with nitrogen. But don't get folks started on the nitrogen thing ... it's already been beat to death.
  13. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    Why not just put green valve stem covers on only one set of wheels? If they are rotated properly the valve cover will have moved with the tires? You could also use a "tire crayon" and mark the tires F, R and then you'd know if they were moved...???
  14. dogfriend
    7,512
    1,190
    Carmichael, CA
    I think if you can't trust the shop to rotate your tires, you either need to find a different shop or do it yourself.
    I took my car to the dealer for the 1st service. They:
    1. Overfilled the oil by about 1/2 pint.
    2. Didn't tighten the valve stem caps which I discovered when I checked the pressure a couple of days later and found one missing and another about to fall off.
    3. And, as a result of discovering #2 above, I checked the lug nuts with a torque wrench and found 3 lug nuts that were loose.
    So, now I change the oil and rotate the tires myself.
  15. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    I just went in monday for my first oil change and they rotated the tires but only reset one of the tires back to 36. I was shocked when I went to the next tire to find that it was still 42psi. There was enough greasy finger prints all over my rims to tell that they must have rotated them. Unless They just do that for show.
  16. qbee42
    3,079
    Time for the high-voltage car body fence charger. :D
