Alignment=5-10mpg
Discussion in 'Gen 2 Prius Main Forum' started by problemchild, May 6, 2008.
  1. problemchild
    problemchild New Member
    429
    37
    I picked up my new prius with an alignment issue. I was finally able to bring it in to get it fixed. My avg. mixed mileage before was 42-43mpg. My avg freeway was 44.3. Now Im getting 54-55 on the freeway and mixed of 48-49.
    I cant believe what a difference a slight alignment issue can make.
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    really! Mine pulls slightly to the left but I was gonna wait for my 5K service. (2K more to go) I get about 50mpg now. interesting to be sure!
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Because I drive so little and had my alignment done in the middle of a New York winter, I cannot say how much the alignment increased my mpg.
    However, I can say that within the first 100 feet of driving slowly away from the dealer's service bay, I felt that the car's traction and handling had seemingly improved greatly. It was similar to the feeling I immediately had after I put wider Goodyear TripleTred tires on the car.
    EDIT: Sheepdog - when you go in for your alignment, you should also ask them to make sure the steering wheel is centered.
  4. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    although my recent alignment fix is not 100% spot on in regards to the print out, i have noticed a marked improvment without trying..im now at 48.2...was at 49.5 last month..but have gotten lazy with P&G and other areas..just driving it again...to ADD to keep up with it
  5. patsparks
    10,664
    569
    Adelaide South Australia
    I agree Boo, mine wasn't centred at my last alignment and it is a pain because the cruise control switch is in the wrong place. I won't go back where it was done, I have lost faith in them now due to that and other issues.
  6. Sheepdog
    1,125
    Sanford FLorida
    I will Boo. I wondered if the little car leans a bit towards the left because Im sitting there driving. I weight around 350 so definitely the car has to notice it.
  7. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    What clued you into needing an alignment at such low miles (2008 Prius)?
  8. Boo
    5,051
    488
    97
    Flushing, NY
    I highly doubt that a driver's weight while driving solo is the problem.
    This "right off the boat" misalignment problem has been well documented. Usually it manifests itself as a "pulls to the left" / "need to slightly turn the steering wheel to the right to go straight" issue. The problem apparently comes from how Toyota secures the Prius on the shipping boats.
    At first, the problem was the subject of a Toyota Service Bulletin which said that if a customer complained about the alignment, the dealer was to fix it for free. This TSB "warranty" then eventually made its way into the Warranty Booklet which now expressly and separately warrants the alignment for 12 months / 20,000 miles.
    I mention the related issue of centering the steering wheel because a car's alignment can be OK but the steering wheel is still off-center.
    When you bring your car in for alignment, you should
    (1) insist that the alignment be done to spec (and not merely to acceptable tolerance),
    (2) insist on getting a printout of the alignment job, and
    (3) as previously mentioned, tell them to make sure the steering wheel is centered.
    Good luck.
