Cabin air temperature gauge?
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, May 19, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I'm trying to learn the AC and heat functionality.
    I assumed that if I set the desired temperature to, say, 72, that the car will be smart enough to add heat or add AC to the cabin to get to that temperature. Well, not in my car.
    Example, After 10 minutes of driving in 65 degree outdoor temperature, I set the cabin temp to 72, for my wife, and we both felt cold air come on and stay on. The AC function came on since we set the climate system to AUTO. We finally shut it off, or get freezed out. Weird.
    Anyways, any tips, cause the heating/cooling system aint logical.
    Oh, on the same note, Does the Prius tell us what the cabin temperature is, which I can use to set a higher or lower temperature?? Right now the only way I can get an idea of the cabin temperature is to change the desired temperature and watch the automatic fan speed. I noticed that the fan speeds up if the desired temp is farther away and slows down if the desired temp is close by.
    ZC1
  2. richard schumacher
    7,664
    1,046
    United States
    You should have got heat. Either there is operator mis-understanding, or mine, or a problem with the car.
    I know of no way to directly read the current cabin temp from the MFD.
  3. Rest
    Rest Active Member
    1,210
    CA
    Toyota doesn't want us to have to much information, like cabin temp, or water temp, or voltage, or oil pressure, or tire pressure. They think we are idiots or something and can't use all that info.
  4. Russ33
    Russ33 Older Junior Member
    Long Neck, DE.
    What are all those things you are talking about?
    Just kidding.
    Russ
  5. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Although the AC light is on, it does not mean that the AC compressor is running to cool you down, instead it may be used to dehumidify instead.
    I'd recommend buying a thermometer.
  6. qbee42
    3,079
    The A/C light indicates that the air conditioning compressor is enabled, not that it is running. When enabled, it will run as needed to cool or dehumidify.
    In auto mode the climate control works just as you would expect: it controls the vents, heat, and air conditioning to try and stay at your desired temperature setting. To do this it looks at cabin temperature, humidity, and the solar radiation sensor on the dash. You will find that you need to adjust the temperature setting up or down to your liking, as comfort is very personal. The actual temperature will hunt up and down a bit with changes in the sun and other perturbing factors. Don't worry about it. If you are cold, bump the setting a click or two. It's right there on the steering wheel.
  7. Yankees251
    Yankees251 Black Touring HI Package
    96
    Danbury, CT
    Where is temp sensor located in cabin?
  8. Qlara
    Qlara New Member
    488
    Did you try to crank the Auto Temp higher (like 78F) and see if hot air comes out?
    The ICE maybe not running long enough to have hot coolant for heating yet.....but it should be running (even when driving slower speed) whenever you crank up the heat setting.
  9. qbee42
    3,079
    If you go to max heat, the electric heaters will kick in. The suggestion to adjust the heat up and down is sound. You have to play with it a bit to get a feel for how it works. Sometimes I'm hot at 68°, sometimes I'm cold at 72°. Comfort is a funny thing, and it depends on a lot more than ambient air temperature. Radiant heat and humidity make a big contribution.
    As for the location of the cabin air temperature sensor, I don't know. We'll have to get someone with tech manuals to chime in on this one.
  10. JEFNLSA
    JEFNLSA New Member
    29
    Phoenix AZ
    As the owner of a new '08 Touring, I have one A/C gripe: You can adjust the temp on the steering wheel but you can't control the fan speed. In order to kick up the A/C (fan) you have to go into the "climate" screen....why?..or am I missing something? :confused:
  11. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    The steering wheel controls are best suited for use with the auto a/c mode. In this mode you don't have to adjust the fan speed as it does this for you. Once you manually override the fan speed you're no longer in A/C mode. I leave mine in auto mode all the time (I'm also in Phoenix). Whether I'm in Phoenix or Flagstaff I just click the temp up or down a few degrees as needed and it will automagically adjust the fan speed appropriately. I usually have mine set between 68 and 72 degrees year round.
    BTW, a bit off topic but have fun in the 110 degree weather today. Summer has hit us with a vengeance. :eek:
  12. JEFNLSA
    JEFNLSA New Member
    29
    Phoenix AZ
    Thx 4 the info, that makes sense to me & I'll give it a go. :)
    And boy do I hear ya' on the HOT weather issue...of course, we knew it was coming but...:eek:
  13. qbee42
    3,079
    We are almost up to 60° F today. :p
  14. richard schumacher
    7,664
    1,046
    United States
    No, that's how it's set up. The temp setting can be used as a proxy for the fan speed...
  15. ZC1
    711
    Metro Detroit
    What I started doing was turn off the A/C and just hit the fan speeds.
    If the temp setting is high enough I get warm air.
    Previously on Auto mode and 76 degree setting, I was getting warm air at my feet and cool air at my face, my wife wasn't too happy about that.
    So now, after advice in this thread, I'm going to go back to Auto mode and crank up the temp, then see what happens.
    Glad the AC compressor doesn't run even though the AC light is on.
    I think it would have been better if they called it Climate Control, not AC.
    ZC1
  16. richard schumacher
    7,664
    1,046
    United States
    Yes, "climate control" may have been clearer for US customers and perhaps others. We tend to interpret "air conditioning" as "cooling".
  17. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I fully agree with this. In fact I'm still trying to convince my wife this is the case and she's owned a few "Auto A/C" vehicles over the last several years.
  18. DieselConvert
    DieselConvert Member
    121
    Central Coast, CA
    There is a way to fool the system (accidentally) into going to MAX COOL, but I can't remember the sequence that caused it in my 2004 several years ago. It was warm outside, and needed cooling, but not THAT much. I remembered my son's advice for computer-controlled malfunctions: "Power down for a minute or so, then power up again. The computers need to reboot to overcome various anomalies that confuse their control systems, sometimes." I did that, and the system worked perfectly through the rest of the time I owned it.
    I would have it reviewed for error codes by the dealer, if other responses in this thread haven't proved effective.
  19. zeeman
    zeeman Member
    211
    where are those heaters located?
    i did not know that prius has electric heater, i thought that only engine was providing heat.
  20. AltonGrey
    AltonGrey New Member
    Austin, Tx
    I love the climate control function in the Prius.
    My previous car, an 05' Subaru Legacy, only knew two fan speeds, breeze and gale force. Even if the interior temperature was just a couple of degrees off, it would kick into high fan speed.
    It was a bit spastic, and I always ended up working it manually.
