"Voice-Activated" DVD Nav?
Discussion in 'Gen 2 Prius Main Forum' started by sktn77a, May 20, 2008.
  1. sktn77a
    sktn77a Member
    303
    NC
    We got the DVD navigation system with our 05 Prius but there was little if any mention of "Voice-Activation" in the owners manual. I noticed it looks pretty much the same as my 08 Lexus IS250 so we've recently been using the DVD-Nav supplemental manual that came with the Lexus for the Prius. Most things seem similar but is there an online manual anywhere for the Gen 4 Toyota system?
    Also, is the DVD Nav rearview camera retro-fittable to the 05?
    Thanks!
  2. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    You might check out Toyota.com. There is a very good demo on using the NAV system. Go there and select Prius, then select the Demos/Videos tab, then select Navigation System. It will walk you thru all of the NAV systems usages including inputs and deletions. You may be able to view or order a NAV manual that you are searching for.
    Good Luck!!!
  3. sktn77a
    sktn77a Member
    303
    NC
    Thanks, that's great. Interestingly, the frequently referred to "DVD Navigation Manual" does not exist in my documentation. Maybe the 2004/2005 models didn't have detailed instructions (odd). But "Google is your friend" and I got the complete list of the commands here on PriusChat (strangely, the PriusChat search function didn't find this post or, if it did, it was buried among other posts).
