headlight failure?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bestroofer, May 29, 2008.
  1. bestroofer
    bestroofer New Member
    ohio
    My Car: 2007 Prius
    Package: #7
    [​IMG] headlight failure
    hi folks,
    newbie here, was wondering about the latest updates on head and taillight failures.
    also does my extended warranty cover these items?
    thanks,
    bestroofer
    07 touring failure @ 36705 miles both front and one rear
    [​IMG] [​IMG] [​IMG] [​IMG]
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The headlamps have a history of HID module failures. Talk to your dealer, the modules should be covered, though you may have to escalate to Toyota. The bulbs are not, they are considered a "use up" item. They are expensive, so be careful. Perhaps best to let the dealer mess with them. If you have Halogen headlamps, it's just the bulb, and that is not covered. They are inexpensive but a little difficult to replace. Don't touch either bulb glass when replacing. It puts oil on the bulb envelope which will cause it to overheat and fail again.
    The tail lamps are bulbs, and are not covered. They are inexpensive and easy to replace. The brake lamps are LEDs, and should be covered (they don't "wear out" in the conventional sense).
  3. qbee42
    3,081
    HID capsules can be purchased through eBay at prices much better than the dealer's. Specific eBay sellers are listed in some of the headlight threads on this site.
  4. bestroofer
    ohio
    thanks guy's,
    i'm finding more info on this site,....very useful but discouraging!!
    i am a slooooow typist, as most can tell and having some difficulty navigating through this site i.e. posting vs threads and welcome suggestions.
    thanks in advance,
    best roofer
  5. Abq Richard
    Abq Richard New Member
    59
    Albuquerque, N.M.
  6. resoh02
    resoh02 Member
    140
    Northern OHIO
  7. BitShifter01
    BitShifter01 New Member
    91
