automatic car wash -- what happened?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by courtgal, May 31, 2008.
  1. courtgal
    courtgal New Member
    Columbia, SC
    I went to the car wash today, and after finally getting the car in neutral all seemed to go well until I reached the end of the wash. I felt a bump and sat there, realizing the car behind me was getting closer and I was not moving. The little wheels on the car wash came up behind me but would just roll under the tire. It seems I came off track, and the attendant had no idea in the world as I waited desperately hoping he would help me.
    Split second decision, right or wrong, I put it in drive and went (and slid and the traction light came on in the car) and I finally got out and was able to drive off.
    I'm new with the Prius and this is my first car wash. Was it a fluke it came off track, did I do something incorrectly, or is an automatic car wash in a hybrid car not a good idea? The car did not come out of neutral until I put it in drive, so I have no idea why it came off track on the line.
  2. Eve
    Eve Junior Member
    59
    S.Florida
    :eyebrows:
    OK i will say it.. cause these guys are too nice to say it
    Your prii was protesting, cause you took it to an automatic car wash...:)
    Technically speaking I haven't a clue!
    So I will leave that to all these beautiful people here, who answer all my inane questions.
    I am sure they will be along shortly:D
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    eve is correct, wash it yourself. it is your baby. would you send your baby thru a mechanized cleaning system. i live in s fl and i know it gets dirty, but , i wash it once a week and take pride in the results and no scratchs either.btw i'm almost 60 years old so no excuses.
  4. Patrick Wong
    18,200
    6,498
    I'm not sure what happened - but whatever the problem was, it was unrelated to the Prius being a hybrid. I'm glad that you quickly decided to exit under your own power.
  5. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    This is exactly the basis for the stuff of NIGHTMARES.
    ZC1
  6. courtgal
    courtgal New Member
    Columbia, SC
    I thought I was being environmentally contentious. I have read car washes use less water than home washes and also recycle the water.
    :washing:
  7. cyberprius
    cyberprius Mtn Bikes don't need foglights
    185
    oregon
    They do. On the other hand, I like to help out the "neighbor kids" and usually hire them to do the wash jobs around here. What's a few gallons of water vs. helping some budding young businesspeople....btw, my closest neighbor is half-mile away and closest neighbor kid is about a mile...so actually I usually convince my nephew or niece....
  8. rkskeet
    rkskeet New Member
    91
    State College Pa
    If you want to use an automatic car wash, try another to be sure it wasn't something to do with the track system that moves the car forward. Or, go to an auto wash where your car stays still and the boom moves over the car to dispense the soap and rinse water.. If you should try the auto car wash again (the type you tried before), I would be interested to know the outcome. Where I live in the Northeast, it snows and a car wash is usually the method of cleaning the car in the winter time. All other seasons it is washed in my driveway.. Best
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    I've turned my driveway into a 'raingarden'. Well, not really, but instead of the runoff going down the sewer it soaks into the ground of my driveway. No automatic carwash can wash your car like you can. You can even learn to detail it.
  10. richard schumacher
    7,664
    1,045
    United States
    You might try a commercial do-it-yourself wash. Get some of the advantages of both.
  11. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    Next time find one of the toucheless car washes. You simply pull in and put it in park. The machine moves around you (never touching the car) and a few minutes later you are done and you prius is clean.
    Its not as clean as if you did it yourself, but its quick and easy and won't scratch your car or otherwise hurt it.
  12. NoMoShocks
    1,292
    82
    Camas, WA
    The automatic car wash may use less water, but the hand wash uses less sand blasting.
  13. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I've never had trouble at the local Octopus car wash and that the only commercial one I've ever used. Didn't notice where the OP is from. Around here its nearly impossible to wash your own unless you do it after dark or get up at 0:dark:30 in the morning. The water is so god-awful hard that if the sun is shining or its hot you will have calcium/arsenic spots that will still be there when you finally sell your baby. I tried that once... and had spots on the windshield for about 6 months, and that was using the Mr Clean gun with the soft water rinse cartridge. I think those cartridges last for half a wash here before they're overcome by the hard water. Now it's to the Octopus car wash where they do everything and costs less than $7. I never want those spots again...
  14. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I hear your pain, I lived in Arizona for 7 months and luckily i had a soft water loop put in at my house but my neighbor wasnt so lucky. I could wash it and then leave it with no water spots
  15. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    This old crip of a guy uses a no touch commercial wash to clean the car. It works well and makes for a good start of a zaino polish. I get to park outside as the wife takes the garage first . My car still always looks better tho!
  16. jyl
    jyl New Member
    84
    Portland
    It sounds like the car was shifted from "neutral" to "park" during the wash, when in park the car will not move on the track. You may have, without thinking about or noticing it, done this - sort of on mental autopilot?
    I did something like that once, the first time I took my Prius to an automatic car wash.
    If that is not what happened, then there is no obvious explanation.
  17. dryismyquest
    dryismyquest New Member
    Clearwater, FL
    Bravo! I think you did precisely the right thing! :first:
    What you described happened to me once in another car. The car behind me not only made contact, but when he did, it bumped my car up a few inches, and while my car re-bounded, he bumped again because that car was still getting pushed by the rollers, yet mine was still in place, just a few inches ahead.
    Stuff like that just happens. Nothing to do with your Prius/hybrid.
    I use automatic car washes all the time. The kind where you leave your car, and a bunch of people attack it, run it though the wash, and attack it again on the other end. Never had any issues, probably 1-200 washes like this over my entire life, with only that one incident.
  18. patsparks
    10,664
    567
    Adelaide South Australia
    Why would anyone forgo the pleasure of caressing the sensual curves of their Prius at car was time?
