Morning TV on my MFD during commute to work
Discussion in 'Gen 2 Prius Main Forum' started by chrisspaulding, May 30, 2008.
  1. bac
    bac Active Member
    863
    52
    Pennsylvania
    :rolleyes:
    ... Brad
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    if tv is so bad, then how come every prius in japan comes with it
  3. mcfly2
    mcfly2 New Member
    48
    Austin, TX
    I'm curious, to the people that are ok with others driving while watching TV, do you have children? Since I've had children I've found that I'm alot more sensitive to the reckless behavior of others.
    And to the ones that insist that they would never glance at the TV for more than a half second, I bet there are things that would grab your attention for longer than that. (Hot girls in bikinis, interesting sports replay, newscast of a horrific car accident, etc.)
  4. qbee42
    3,079
    I fired an early shot in this thread by posting a "crazy" smiley face, but otherwise I've sat back and watched from the sidelines. After reading all of the posts I have some comments and personal observations:
    1) I am not categorically against TV in automobiles. I am against distractions - they need to be minimized. A competent driver knows when to turn off controllable distractions. I turn off the radio when driving gets too intense. I would do the same with a TV.
    2) The distraction level of the radio, a TV, or the MFD varies depending on the subject matter. Content demanding attention is more distracting, obviously. The consumption screen on the MFD is less distracting than the NAV screen. Music on the radio is less distracting than following a debate. A phone conversation is almost always distracting because the person on the other end demands your attention, although obviously some phone calls are more distracting that others.
    3) Some drivers are more responisble than others. In this country we tend to legislate for the lowest common denominator. TV in cars aside, I've seen drivers shaving, putting on makeup, spraying their hair, changing clothes, and using two cell phones at the same time. We need better drivers, or fewer bad ones.
    4) There were some posts comparing flying to driving. As a pilot, I can attest that flying and driving differ in the demands placed on the pilot and driver. With flying you generally have a lot more time to fuss with switches and play with radios. While the speeds are higher, the seperation is much greater. With driving you are always about a second from disaster. Flying switches to this mode during takeoffs and landings, and any time in traffic. In these situations, cockpit distractions become a huge problem. Otherwise you have a lot of time to sit back and chill out. This is true with older aircraft as well. Think of it as city driving verses empty interstate.
    5) There was a thread on carputers a while back. The OP of that thread expressed suprise over the hostile replies in this thread verses his carputer thread. I think I can explain that. A carputer and a TV carry the same risk of driver distraction, so it's not that. What differs in these two threads is the OP's tone. The carputer OP posted as a technical challange. The OP of this thread attempted to do that, but took a fiercely defient and agreesive tone right from the first post, and has continued this tone through the entire thread. It's almost as if the OP said "I'm going to drive irresonsibly and it's none of your business, so shut the f*** up and get out of my thread...". If the OP wanted to get beat up, he couldn't have picked a better way. Instead, if the first post had simply said "I want to hook a TV up to the MFD, does anyone have an idea how to do this?", he would have receieved technical advice without as many safety comments. The aggresive posture throws fuel on the flames, and now it's hard to have a civil discussion since everyone has their blood up. Wording is very important, especially in written discussion where body langauge and facial expressions are not present.
    That's my two cents worth, or maybe more like a nickle.
  5. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    Well said qbee42.
    I have since thought I should have kept my mouth shut ;), but I have trouble with that - easy to accelerate from 0 to 10!
    Working on that and appreciating good posts like this.
  6. chrisspaulding
    556
    24
    Kentucky
    Good question.
  7. Winston
    Winston Member
    614
    SF Bay Area, California
    I am absolutely stupified at how everyone feels the need to tell the OP about how this is such a bad idea. Instead of having anything usefull about how to hook up a TV to the MFD. All we have is 15 pages of people acting like a know-it-all nanny. If you really wanted to say it was a bad idea, why didn't you show a bit of courtesy and start a new thread about it. This thread is pathetic.
    Most of you are just talking out of your A@@ anyway. Show me some controlled study data or save it.
  8. problemchild
    problemchild New Member
    429
    37
    How is this any different then the P&G peeps that constantly watch their monitor trying to eeek out another 1mpg?
    Get a gyro stabilized Sat antenna and watch Dish TV.
  9. problemchild
    429
    37
    X2
    Welcome to this forum. Its filled with negative Nellies that hijack threads and take the thread way off topic. They do it to me every time I post.
  10. chrisspaulding
    556
    24
    Kentucky
    I absolutely agree!!!!!! I've been going horse trying to get the 'controlled study' point across!
    But I also agree w/ qbee42 too.
    This thread has been entertaining & thought provoking(imo), although, in a point I made earlier, this thread probably sux for a newbie just wanting the answer.
    I would post a write up thread with pictures on how this was successfully achieved OEM style (if I really went through with it), but then I'd be concerned for my general wellbeing. :)
  11. cmympg
    cmympg Who knows? Who cares?
    97
    Tidewater Virginia
    I just tried to find more information about this and failed. I obviously am not using the right search paramaters. Do you have a link to this information or is it from personal experience?
    Thanks
  12. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    They drive on the left side of the road in England, but I'm not going to try doing that in the US.
  13. mcfly2
    mcfly2 New Member
    48
    Austin, TX
    The also stone women in Iran. I'm not going to suggest anyone do that here, and I don't need a controlled study to tell me it's wrong. And if anyone posts asking how to do it, I'll post to say that they shouldn't.
  14. cmympg
    97
    Tidewater Virginia
    Thanks for the information.
    If I'm reading the quote below correctly, then you can't watch TV or a DVD or an iPod video while the car is in motion.
    安全のため、走行中一部操作・表示できない機能があります。
    For safety reasons, running some operations functions may not be shown.
    また、テレビ放送・DVD再生・iPodビデオ再生など(前席ディスプレイ)は、安全のため走行中は画面が消え、音声だけになります。
    The television broadcast video iPod and DVD playback (previous seats displays), running for safety on the screen will disappear, only voice.
    If I'm correct, then the argument that watching TV while driving is practiced in Japan isn't valid.
  15. Winston
    Winston Member
    614
    Asking how to stone women is a bit different that hooking up TV to the MFD. Still, people who fill up a thread with with posts about why not to do something, when the OP specifically requests the thread to remain a "how-to" thread not a "should-I" thread are rude and self-centered.
    If you feel it is a bad idea, that is fine, but start your own thread about it. Of course, you can and will do whatever you want, but the polite thing would be to start your own thread debating the pros and cons.
  16. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    I got the coolest little mod for my Prius. It picks up signals from this new thing called "radio" - you may want to Google this, I think it's going to be big. No more boring commutes, and I get to keep my eyes on the road to boot!
  17. Tideland Prius
    16,547
    That's pretty good. One up from here where you don't even get audio if the car's in motion.
  18. mcfly2
    mcfly2 New Member
    48
    Austin, TX
    Sorry for being inpolite. I tend to get that way when people ask how to increase the chances of my wife and 2 year old daughter getting killed on the road.
  19. cmympg
    97
    Tidewater Virginia
    I have no problem with someone listening to TV while they are driving. That's no different than listen to radio.
    I could see some problems at stop lights where drivers become so engrossed in what they are watching, they don't move when the light changes.
