Goodyear Comfortreds Ain't All That
Discussion in 'Gen 2 Prius Accessories & Modifications' started by gil123, Jun 5, 2008.
  1. gil123
    gil123 Junior Member
    25
    Philadelphia
    Sorry to start yet another replacement tire thread and sorry to knock the trend of folks who sing the praises of the Goodyear Comfortreds as a great replacement tire, but I wanted to give my contrarian view.
    I replaced the stock Integrity tires shortly after I got my 2005 Prius. Chose the GYCT largely based on positive info on this site and TireRack.
    My observations are:
    Yes they were an improvement over the stock tires but that's not saying much.
    They were pretty decent in snow and rain the first year or so, and then went downhill quickly.
    I would say I got no more than 15-20k of decent traction from them and the last 20k have been miserable on anything other than dry pavement. At 42k (about half their rated life) they are useless and unsafe and I am about to replace them with Michelin Primacy MXVs. If anything whatsoever falls from the sky, they slip and traction control comes on frequently--- and I am not an aggressive driver.
    The other comment I will make is more general and may apply to other tires. Part of the reason for the premature wear seems to be consistent with overinflation. I never put more than 38 rear and 40 front (and I know some of you go even higher), and was religious about maintaining PSI. I rotated and aligned on a regular basis.
    The two strips of rubber down the middle of the tire are worn totally smooth, yet there is tread left on the outer and inner edges. Clearly follows the wear pattern of overinflated tires, even though I was only going a few PSI above Toyota recommendations.
    So my lessons learned and 2 cents for what they are worth is:
    I would not but the GYCT again.
    Whatever tire I use on this car, I will stick to the factory PSI because the GYCT tires cannot tolerate the higher inflation rates recommended on this site. If there is a marginal mileage gain from overinflation, it is more than offset by cutting half the life from the tires. I would prefer a little extra traction, safety and tire life than be slipping and sliding to squeeeze out that extra MPG. ;)
  2. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    The Goodyear manager told me it wasn't worth the extra cost to upgrade to the comforttred or the tripletred. He said the Integrity was decent enough for normal driving--just lower tread life than the others.
    Somebody on this site said they found the best pressures were around 38/36 for mileage, handling and wear.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Your center tread wear problem is not consistant with the observations based on the Integrity tire. My guess is the construction of the GYCT is different such that even a bit of overinflation can cause a problem? I have the opposite effect, super overinflation is causing a TINY bit more wear on the edges. It's barely a noticable difference though.
    Good information on the GYCT. Thanks! :)
  4. Devil's Advocate
    922
    Las Vegas, Nevada
    I got about 50,000 miles out of my comfortreads before they actually self destructed! Now trying some Pirelli 3000's. But the Goodyear's were OK up until within the last 1000 mikes they just got weird bulges and self destructed. Went through 4 tires that way. Did get some money back because the tires were rated for 80,000.
    So I don't think I could recommend these. But I will say that I don't recommend spending over $200-$250 for a set of tires on the Prius installed.
  5. bulldog
    bulldog Member
    224
    CA
    I only have 33K miles on my GYCTs, but so far they have treated me very well. I will see about rain traction this coming winter, but I have well over 20K last winter in the rain with no issues. We don't get snow around these parts so no comment on that. I have not noticed any of the wear issues at this time yet either. I use them with 42/40 PSI in the front and back.
    One of the reasons I got the GYCT was for less road noise, where they have done very well. I was also able to trade the INtegrities on these GYs so the price was very good.
    Funny enough I was also thinking about a Michelin low rolling resistance tire for the Prius in the future. Let us know how you like the Michelins in terms of noise, comfort, traction and MPG compared to the GYCTs.
  6. Tideland Prius
    16,548
    You might wanna check the PSI again. Keep in mind, the PSI we use are for STOCK tyres. Once you change to something else, all bets are off. My Nokian WRs are rated a higher PSI than the Integrity so it's up to me to decide the PSI. If I had run the stock PSI, it would definitely be underinflated just because it's not maxed out at 44PSI but some higher figure (which escapes me at the moment).
  7. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Love my GYCT's.
    Replaced my Integrities at 15K miles and there's a world of difference between the quiet, better wet traction, longer wearing GYCT's and the crap OEM's
  8. driverx
    driverx New Member
    60
    N. Cal
    I would not buy the GYCT again either. I bought it based on positive comments here and other sites. Handling wasn't all that great and reduction in MPG is just not cool (Avg 37MPG) :mad: I didn't buy Prius for handling, I bought it for MPG.
    Anybody want to trade your OEM tires for slightly used GYCTs?
  9. rkskeet
    rkskeet New Member
    91
    State College Pa
    I replaced the OEM Goodyear Integrity tires with Goodyear Comfort Tread all season tires shortly after purchasing my Prius this past March. Therefore, I haven't had the opportunity to test the car in pure winter (snow) conditions yet. I live in central PA and will encounter snow during the winter. Generally, the roads are well plowed and treated when snow hits. But where I live is in a home development that gets plowed on the later side of the plowing schedule and the roads can pile up some snow amounts..
    I am interested if anyone has had any or some experience with the GY Comfort Treads during the winter season while driving their Prius?? Interested to hear your comments, thanks..
  10. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I used to be very happy with my ComfortTreds, and even bought a set for my wife's Prius too, about 8 months after getting them for mine. But these days, after about 25K miles, they are begining to act like the stock Integrity tires used to.
    When I got them, they worked great. No more slipping on wet pavement. I could gun the engine onto a busy road on wet pavement, and at most I got a little chirp from the tires and no traction control engagement. For about 14 months they've been great.
    But this spring, 25K into the tires, with lots of tread left and proper inflation, I'm slipping all over the place on wet pavement. If I'm not real careful, the traction control will engage when I pull out into traffic on wet pavement. There's been a couple of times when it engaged two or three times in a row while trying to get up to speed after turning right onto a busy road. They're not behaving any better than the stock tires did.
    I will not be buying them again.
  11. gil123
    25
    Philadelphia
    Wow, sounds like I am not alone in my experience re the traction problems as soon as you get some miles on them. Glad to hear it is not my imagination. I agree with the assessment that after a year or so these tires do not offer signifcantly better traction that the Intergrities.
    I also got a good tradein on the stock Integrities to the CTs cost me next to nothing, so I can't complain (but I will anyway). Just that if I am going to shell out $400 for a new set I can't see going with them again.
    Ineterstingly enough, a number of posters here are, like me, from PA (near Philly in my case). We often get a "wintry mix" of light snow, sleet, and freezing rain all in a single storm- and plenty of plain old rain the rest of the year.
    I think it points out the importance of choosing a tire appropriate for your geography. While these GYCT may work out fine for all you SOCAL folks, they are really probably the wrong choice for the Northeast IMHO. Would be interesting to hear from anyone who put substantial miles on them at normal PSI to see whether the experience was different.
    On the same note, I read a number of complaints about SOCAL drivers saying the Michelin Primacies wobble on grooved roads. I can't think of any grooved highway anywhere in the area, so that matters a lot less to me than sticking to the road.
  12. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    For what it's worth, I haven't had these problems with ComforTred's cousin, TripleTred.
    On my prior car, which I still drive on occasion because I gave it to a family member, there are now over 40,000 miles on the TripleTreds. When I saw and drove it last month, the TripleTreds' tread was still deep and they still seemed to grip the road like glue.
    But I do recall one PriusChatter reporting that he started noticing a significant decline in wet traction on his TripleTreds after about 40,000 - 45,000 miles.
  13. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    AquaTred??? They haven't made those in several years. I think you mean TripleTred - especially since that's what your sig says.
  14. Boo
    5,051
    488
    97
    Flushing, NY
    LOL. Yes, I meant TripleTred. I'll edit my prior post.
  15. gil123
    25
    Philadelphia
    Yes but TripleTreds are a very different animal than ComfortTreds and got better reviews for traction. They were also on my shortlist for replacements but I decided on the Michelins instead because I didn't want to change the original tire size if possible, because the TTs seemed like they would be great in rain but the tread design does not look like it could handle substantial snow, and because I have become a little allergic to Goodyear from my experience with the Integrities and CTs....
  16. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    my old comforthread set gave me roughly 40 to 50k miles. stock gave me 15 to 20k
    get your alignment checked.. and turn down your psi...
  17. demerittca
    demerittca New Member
    I replaced the Integritys with ComforTreds the day my '06 Prius was delivered. $$$! Remarkable difference - quieter, better ride, better handling. By 42K, they had worn down to 4/32 (2/32 is TOO little tread!), and after a lot of arm-twisting, my local GY tire dealer reluctantly submitted my claim of premature wear to GY Corporate. I had phoned GY and set up the case file.) They graciously replaced two . (The other two had been "adjusted out" for nail punctures at more than new ones cost at TireRack! Thanks a bunch, local GY tire dealers!) I would love to try Michelins next time (I've always had good luck with Mics!), but they're pricey and reputed to be noisy on this car. ComforTreds drive great, but only for about HALF the life expectancy! Then, performance drops. The tread depth is simply no longer there, and tread is the padding and gripping surface between the wheels and the road. I run 'em at 40/38 with even wear, and check tire pressure twice per month. Mostly highway driving. NOTE: If shopping for tires, watch the revs per mile - it affects speedometer accuracy and fuel economy. Tire tread design and compound affects noise, traction, performance, as does construction. Cheap tires are intrinsically less safe than better tires, and keeping pressure laterally equal and balanced is invaluable! Never exceed the max pressure on the sidewall, and never undercut the car mfr. recommendation.
  18. gil123
    25
    Philadelphia
    I think that the wear rating and warranty on the CT is misleading and it is by no means an 80.000 mile tire. If others, like me, are getting only around half the rated life and experiencing significant traction loss at around a quarter of the rated life, these tires are overrated or have a design flaw.
    Anwyay, with a few days on the Michelin Primacies I can say that traction is much better (albeit not a fair comparison because they are brand new) and so far anyway MPG seems to be a bit better than that of the worn CTs. It is also true they may also be a little nosier than the CTs-- but that is a tradeoff I can live with.
    I'll update in about a year and see how these tires perform with some wear on them.
  19. Casey123
    Casey123 New Member
    40
    Long Island New York
    What is the number of revolutions per mile that would allow the speedometer accuracy and fuel economy to be at least what the OEM tires give?:)
  20. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The 185/65SR15 Goodyear Integrity tires are rated at 855 rev/mile when new. Of course the revs/mile for all tires increase as they wear and are about 2% higher at the end of life for this size tire.
    JeffD
