2" recvr hitches, any1 other then coastal?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by problemchild, Jun 13, 2008.
  1. problemchild
    problemchild New Member
    429
    37
    Coastal is out of stock. I called curt and they dont make them. Who is making this for coastal or are there any other vendors. I have google'd this and find nothing.
  2. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    This is what I've found. Not sure if these are 2" or 1 1/4", but either way they are showing as out of stock for me (our supplier does not carry them, even though I have repeatedly asked).
    Manufacturer Part Number
    HIDDEN HITCH 60894
    REESE 77179
    DRAW TITE 24808
    I have a feeling they are all the same part since they all cost exactly the same.
  3. problemchild
    429
    37
    Thanks
    Hidden is class 1 (1")
    Draw tite is class 1 (1")
    Reese I cant find.
    I found a hitch maker in Orange county that will weld on a class 2 (2") but I'm Leary to have something welded on to the car. I don't want the dealer to void my warranty because they see a full size tow hitch.
  4. bac
    bac Active Member
    863
    52
    Pennsylvania
    You may want to do a search on this board regarding the Coastal hitches. Several have had problems such as the hitch bending (on both the 2" and the 1 1/4").
    Do you really need a 2" hitch? As far as I know, no company makes anything but a Class I hitch (regardless of shank size) for the Prius, so you're stuck with Class I accessories.
    Good luck!
    ... Brad
  5. problemchild
    429
    37
    Interesting......
    The hitch shop said If I bought the bolt on I would have problems with it bending.
    The 2" cargo baskets have a bolt to tighten the side to side slop if there is any. I dont thing the 1" offer that because there is not enough metal to drill a hole and install the bolt.
