Nitrogenized Tires Update
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jammin012, Jan 30, 2008.
  1. jammin012
    jammin012 The man behind The Man
    510
    Cali
    With a whopping 225 miles so far since filling the tires with nitrogen I have come to this astonishing conclusion...... nitrogen will NOT make your tires impervious to wood screws in the Home Depot parking lot.
    More updates to follow
  2. qbee42
    3,079
    Oh come on now. I don't believe that for a second. The scientific literature that I read on the equipment manufacturer's website clearly says that those big Nitrogen molecules will hold tire pressure even if all of the rubber is removed from the tire. Not only that, but you will feel better and be more attractive to the opposite sex.
  3. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    Um...Uh....Duh !
  4. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    Who cares about punctures, what I want to know is, does it or does it not increase women's bust sizes as previously reported.
  5. jammin012
    510
    Cali
    I can't comment on busts, but my hands look bigger.....
  6. patsparks
    10,664
    567
    Adelaide South Australia
    It will if pumped into silicone implants.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Looking at Your Avatar, I have figured out which tire found the wood screw.
  8. jammin012
    510
    Cali
    10K Service complete and some interesting numbers.
    First off I purchased the service plan, easier for me not to worry about it when the time comes for an oil change. So at the 5K service they didn't realize I had the plan so they tried to charge me for it. Bill was for $49.99. When I brought the oversight to their attention, coupons started flying off the computer, it came to $40.00, itemized for everything and my charge being 0. At this service and itemized charge was again $40.00. Makes me wonder what I'd pay if I didn't have the service plan. And where's that other $9.99 coming from for those who don't have the plan?
    Anyway, in 5K miles I've lost 1/32 of tread from all 4 tires.
    Here's the interesting part. My rear brakes have grown 2mm. That's right, at the 5K service they were 6mm and now at the 10K they're 8mm, same as the front. Front brakes have not changed at 8mm.
    They do keed lowering my tire pressure down to 40, though they write 32 on the service sheet, so I have to keep filling them up. No biggy, nitrogen is free.
