Cruise Control stopped working...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by saelee39, Jun 23, 2008.
  1. saelee39
    saelee39 New Member
    I have a 04 Prii and my cruise control had stopped working all of a sudden. When you press the cruise control button it does not turn on. I was wondering what can this be... Thanks.
  2. Patrick Wong
    18,200
    6,499
    The repair manual suggests the following possible causes:
    Cruise control switch circuit
    CRUISE main indicator light circuit
    Combination meter​
    Hybrid vehicle control ECU
  3. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Also, do you have a check engine light on? I don't know about the Prius, but I had another car (Saturn Vue) where the cruise control was inhibited when the check engine light was on.
  4. tochatihu
    tochatihu Senior Member
    9,654
    3,723
    Kunming Yunnan China
    2001 Prius
    Some 2004 Prius get their brake light switches replaced for free because of a defect that could cause this symptom. A good Toyota shop will know if yours is on the list.
  5. rlmalmberg
    rlmalmberg New Member
    Solvang, CA
    I've only had that happen once....turned out I had bumped the "shifter" into B and didn't realize it. As soon as I put it back in drive, the cruise worked fine.
  6. Rotorhead
    Rotorhead New Member
    79
    Kalamazoo, MI
    My cruise stopped working one time. I pulled over and stopped. Shut the car down and re-booted (don't know if this is the right term?) and the cruise started working again. This was about three months ago and I haven't seen this problem since.
    Mike
  7. rayxoxo
    rayxoxo New Member
    39
    Sacramento
    My Prius has less than 1000 miles on it.
    I was driving in a hilly area in California and later in the day after my cruise control had been working fine, I noticed that it wouldn't stay at the speed I had set for it... If it was set for 60 mph and when I came to a down hill it would just keep climbing in speed, once up to 80 mph... Then when I would reset it on the level or going uphill it seemed OK. It has now happened several times and I just assumed that it was a poor design or a temporary bug... But it could get me a speeding ticket...
    Any suggestions?
  8. Patrick Wong
    18,200
    6,499
    Suppose that while you were heading downhill, cruise control was not engaged and you let go of the accelerator pedal. What would happen to your speed: would it decrease, remain constant, or increase?
    If your speed would decrease or remain constant, then cruise control should be able to maintain a constant speed.
    If the slope of the downhill run is sufficiently steep so that your speed would increase when cruise control is not engaged, then when it is engaged, your speed would also increase. Cruise control will not invoke engine braking to help reduce your speed.
  9. bwilson4web
    16,122
    Shift into "B" on downgrades.
  10. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    If the hill was that steep, cruise control can't maintain a speed, nor was it intended to. try using your brakes, because the cruise control sure can't.
    :confused: It's no an autopilot.
  11. rayxoxo
    rayxoxo New Member
    39
    Sacramento
    Thanks guys for the edumakation.
    The hills were not that steep and as soon as it got to a level area then it would go back to cruise at the adjusted speed.
    My Mercedes car and my BMW bike's cruise control would automatically continue the set speed, up and down these same hills. That is what I expected with my Prius.
    I have never had to apply brake on these same hills (Hwy 5 & Hwy 152 - just east of Monterey) and the cruise control would back off or add to the speed as needed to maintain, say the 60 mph. I just thought that the prius would do the same but it didn't, though when heading west on the same road it did work as I thought it should, but coming back is when it acted different and seemed to fly down the hills and act erratic, then correct itself when it became level.
    Maybe I am missing something but that's my story and I'm sticking to it!!! lol
  12. rayxoxo
    rayxoxo New Member
    39
    Sacramento
    I do have a question: While using the cruise control can you shift into B and still maintain the cc setting???
