Brakes "slip/skid" when hitting a bump?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ringer, Jun 25, 2008.
  1. Ringer
    Ringer 2008 Gen II
    Milwaukee, WI
    My 08 Prius seems to slip/skid when going over a bump in the road while the brakes are applied. :( The car then seems to slide ahead, feels as if the brakes are not gripping during the slide and then the brakes seem to kick back in. This seems to happen either at slow or high speeds. Has anyone else experienced this. The "bumps" are not large that seem cause this, I do of course try to avoid "large" bumps in the road. The 08' does have SBC.
  2. Patrick Wong
    18,200
    6,500
    This is pretty common. When the Prius detects wheelspin, it will shift braking from regen to friction. During that switch, there's a momentary loss of braking.
    Do you notice that the traction control light (the amber skidding car) comes on when this happens? That shows you that wheelspin has been detected by the skid control ECU.
    The original equipment Goodyear Integrity tires are not known for having outstanding traction. If you install a set of quality tires, then this issue may go away or at least happen less frequently.
  3. GeekEV
    GeekEV Member
    417
    NorCal, USA
    Yeah, I get this too in my '06. It feels weird, but I've never once felt like the car was out of control... I've learned to just ignore it.
  4. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    Yep, same here. As said, the integrity tires aren't the best for grip...combine this with a very sensitive traction control and you have the issue you described. As another poster, I just learned to ignore it. I have a similar thing happen when I accelerate sometimes from a stop going around a corner. If there's the slightest bit of slippage, the ecu completely chops power for what seems like an eternity when you're trying to merge into traffic during rush hour from a side street. :)
    Mike
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    During braking? More likely wheels lock-up and cease spinning while braking. Wheelspin typically occurs during acceleration.
  6. Tideland Prius
    16,549
    It's the traction control. It'll also happen if you go over a wet manhole cover or railway tracks.
  7. richard schumacher
    7,664
    1,046
    United States
    Hitting a bump can cause the tires to lose contact with the road surface for a moment; obviously there cannot be any braking action while a wheel is in the air. The loss-of-contact can also trigger the traction control/antiskid mechanism so that the wheel in the air won't start spinning too fast.
  8. Danny Hamilton
    926
    94
    Really? I thought traction control was an acceleration thing. I didn't think traction control came into play during braking.
  9. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I am inclined to agree that it is more of a tire issue. As my Integrities get older and are on there last few thousand miles, it happens more and more for me.
  10. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I don't think its traction control, but rather the braking equivalent. Probably the ABS or stability controller? I guess they're all related. As Patrick said its probably a bit more pronounced feeling in the Prius as at the same time the ABS system would normally be reducing braking to prevent going into a skid, its also transitioning from electric to mechanical brakes in perpetration for an emergency braking situation. If you've ever tripped the ABS in a traditional vehicle it feels similar. I've had that happen under the same circumstances in other vehicles as well (hitting a bump while braking, freaking out the wheel speed sensors) though probably under somewhat harder braking due to better tire grip.
    Rob
  11. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I think it's the traction control and not the ABS.
    When I think of the ABS working, I think of noticeable pumping action/modulation of the brakes. At least that was the way it was on my prior car, a 1995 Volvo.
    EDIT: Or maybe there can be instances when both the traction control and ABS are operating at the same time?
  12. qbee42
    3,079
    It is traction control. When you hit a bump and it unloads the front wheels, the traction control system detects that the wheels are slipping. As another poster suggested, this is not really wheel spin, but just the opposite. From an engineering or physics standpoint the two are identical, but with opposite signs. The loss of traction causes the Prius to switch from regenerative braking with the front wheels to friction braking with all four wheels. If the wheels continue to skid, the ABS system will modulate the friction brakes as needed. VSC does not come into play unless there is a loss of steering, in which case VSC will reduce power and actuate individual brakes as needed. All three systems interact with the brakes, but they are not the same.
  13. Nords
    Nords Member
    101
    Oahu
    Same here, and the traction-control light flickered 3-4 times.
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Read near the end of this.
    _H*
  15. mwc716
    mwc716 New Member
    Atlanta, GA
    This bothers me too. Most often when this happens I DO need to brake and I feel like valuable time is lost during this transition. Has made for some close calls over rough roads etc.
  16. qbee42
    3,079
    It's mostly just the sensation. If you really need to brake, you won't loose much if anything during the transition. Panic braking will automatically switch out of regen and invoke brake assist.
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Yep me too. Thanks Patrick for the excellent explanation as thats exactly what's happening to me. See the VSC flashing real quick and the sensation of no braking. Usually happens when I'm going fast and hit a rut big enough to bounce the wheels.Just another peculiarity of the best car in the world.
  18. Dipena
    Dipena Senior Member
    1,567
    68
    Massachusetts
    Hmm. I've noticed this too in my 08, especially when I cruise into my driveway in a particular way (there's a little bump). The traction control light definitely comes on. Does this mean I'm going to have a problem in the winter when the roads get slippery?
    I have the factory installed tires on my package 6...I live in Massachusetts, so winter driving is a concern. Just got my Prius in April, so have never driven it in snow or ice.
  19. patsparks
    10,664
    567
    Adelaide South Australia
    Try to avoid braking. You wont feel this sensation and you save some petrol. Actually you can save a lot of petrol.
  20. qbee42
    3,079
    It's not the VSC, it's the traction control. The two are often confused, but they are not the same. All Prius have traction control, but only some packages have VSC. VSC kicks in with loss of steering control, not simply loss of traction.
