2004 has to run on Leaded Gas
Discussion in 'Gen 2 Prius Main Forum' started by tompalee, Feb 27, 2005.
  1. tompalee
    tompalee New Member
    Hello
    I own two 2004 Prius hybrids and am considering relocating to Belize for the next 5-10 years. Belize does not have unleaded gasoline, although they do have Toyota Dealerships. I would REALLY like to keep one of the cars but other than the catalytic converter I don't know what negative effects leaded fuel would have on the engine/emissions systems.
    Any suppositions would be welcome regarding this issue.
  2. coholm
    coholm New Member
    O2 sensor will also get clogged up. That and the cat are the reasons not to run leaded gas in a fuel injected car.
  3. rick57
    rick57 Member
    572
    Circleville, Ohio
    My suggestion is to visit the local Toyota dealer there. Ask them if there needs to be any mods done to let it run on leaded. The basic ICE is the same as any other. I think maybe the O2 sensors maybe affected by the lead,leading to the ECU not being able to do its job properly in making the correct adjustments to the mixture/timing,etc. I am sure there are others here that may have more info.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    spark plugs will lead foul so your back to normal 10-12K change intervals. Also not sure if the iridium plugs might have to be changed to more conventional plugs to get away from fouling. I agree with Rick on the O2 sensor becoming coated and that will set the MIL and the computer will probably default to rich compounding the fouling problem. Remove the cat to prevent blockage and eventually total plugging.
  5. naterprius
    naterprius Senior Member
    1,843
    The irony of a Prius running leaded gasoline is just killing me...
    Nate
  6. tompalee
    tompalee New Member
    :cussing: Thanks to all for confirming my worst fears...I will now have to engineer a home brewed Lead Precipitator... :idea: wonder if I threw out all those 1970's Popular Mechanics. Thanks Again
  7. tochatihu
    tochatihu Senior Member
    9,665
    3,728
    Kunming Yunnan China
    2001 Prius
    I didn't know much about Belize so had to google, here's an excerpt from:
    http://www.belizefirst.com/current.html
    “Belize Firstâ€
    Roundup of News and Opinion about Belize and the Caribbean Coast
    LATE NEWS OF BELIZE AND THE CARIBBEAN COAST
    By Lan Sluder
    BELIZE FIRST
    UPDATED 27 FEBRUARY 2005
    GAS PRICES NEAR US$4 A GALLON IN BELIZE The price of unleaded premium has reached nearly US$3.80 a gallon in Belize City and $3.94 in San Pedro. Leaded regular on the mainland is US$3.70, and diesel is around US$ 2.40 to $2.45.
    (back to me talking)
    So, I suppose that unleaded fuel can be purchased. Still, there may be other additives in the local fuel that would do Prius harm. I doubt that it would take more than one full tank of leaded fuel to damage the catalyst. Prius may be the car least likely to thrive under those circumstances.
    In any case I would not take this sort of vehicle so far from Toyota maintenence. Better to work with the vehicles already common there.
    I also read that butane powered vehicles are used because this is a common fuel in Belize. Have you considered those?
    Not impossible to convert a Prius to operate on butane, would it be? Now that might be a large step forward, if there are many places without nice clean U/L in the pumps.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    That's a great point...do not know how many Prius certified (and experienced) techs you're going to find in Belize. If you're not near a major city you're really going to be SOL if you run into any ECU or HV Batt problems at all. And I don't think Toyota Roadside Assistance is going to be of much help there either!
    Maybe a good time to sell and trade for something more practical for the environment if you do go down there.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I would try to get an email address for the local Toyota Dealer there and ask them what you should do.
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Well, I took a peek at:
    http://www.toyota-caribbean.com/countrytop/belize
    And saw no mention of Prius. That's a bad sign, isn't it?
    If you really will be spending that long down there, I have to strongly suggest you sell your 2 Prius cars and get something fairly common down there. It's not like you're going to lose money on the Prius, right??
    I know folks who have vacationed and/or lived in Central and South America, and they claim the "safest" bet is a small pickup or car with a diesel motor. Diesel fuel is usually easier to get and of higher quality than the gasolines down there.
    The Hilux sold there has a 2.5 litre turbocharged diesel motor. You won't get anywhere near the fuel economy of the Prius, but it won't be a guzzler either. If you intend to explore down there, that would be a far safer and more practical bet than a hybrid car with North American and Western Europe exposure.
    As far as converting the Prius to run on leaded gas, I'm not sure if Toyota has even bothered to do so. If the procedure is the same as the shop manual claims for my 2000 GMC Sierra pickup, you have to remove the O2 sensors and catalytic convertors. You then have to load the PCM with software to run in Open Loop or Speed Density mode, since you can't use the O2 sensors to fine-tune engine operation.
    SFO likes this.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Wow. The RAV4 with the2.5 litre D-4D turbodiesel get's *good* economy:
    http://www.toyota-caribbean.com/showroom/r....html?selcon=05
    They claim 7.1 litres per 100km combined. That works out to 40 MPG Imperial gallon. In contrast, the Canadian Prius has a claimed city of 4.0 litres per 100km and a highway of 4.2 litres per 100km.
    Given the terrain down there, it seems that the diesel RAV4 is a nice compromise. At least you wouldn't have servicing worries.
    SFO likes this.
  12. tompalee
    tompalee New Member
    Thanks to all for the input. It would appear that the logical choice is to go with some kind of vehicle that is indigenous to the locale. The concept of giving up both of our little slices of heaven is just hard to accept.
  13. dixonr
    dixonr New Member
    Also, in reading a retirement guide on Belize they charge a serious import duty if you are going to have the car there I think more than a year. I don't think cars are alowed in San Pedro?
