Headlight glass changing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pvdo, Jul 9, 2008.
  1. pvdo
    pvdo New Member
    Lithuania
    I bought a used Prius and headlights doesn't seem as bright as a new ones. It looks like it has a soft mist on the glass and my question would be, is there a possibility to change headlight glass only? What would be your advice how to make the glass look brighter?
    Thanks,
  2. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    The plastic lenses can be polished to remove the fine scratches. There are a number of products that will work. Do a Google search for "Headlight Restoration".
    Rod
  3. fnc
    fnc Metro owner
    NH
    Plastic polish and a random orbit buffer will do the trick.
  4. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    Maybe the previous owner slapped on some of that "clear" protective film.:brick:
  5. pvdo
    pvdo New Member
    Lithuania
    No, there are no protective film. I'll try a plastic polishing. Thanks, guys.
  6. Rest
    Rest Active Member
    1,210
    CA
    Actually the plastic lens does have a UV protective film. Eventually it will peel and then the plastic will yellow and turn brittle. If you polish the plastic that will also remove the UV protection.
  7. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You can shoot the lenses with a layer of clearcoat to give them back UV protection.
    Also, unless you're really patient, an orbital buffer is way too slow. A rotary, or even a cordless drill, with a 4" pad mounted is way faster.
