2008 Hid Lights - Adjustment/leave On?
Discussion in 'Gen 2 Prius Technical Discussion' started by Genoz World, Jul 12, 2008.
  1. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    TO ALL of you that are technically well versed, i would like to ask you about the HID headlight system on my 2008 #6 prius.
    #1) is it safe to leave these lights on all the time as i drive? using it as a DRL option? safe meaning will it significantly shorten the life of the HID system? i mainly drive in the daytime, approximately 40-70 miles a day, depending on work loads.
    #2) when i do drive at night, i feel the HID system points too far DOWNWARD, it's not too bright for me. i would like to adjust the system a bit higher, but i do realize there is a self-leveler. Do i adjust the leveler or manually adjust the lights.
    forgive me in advance if this is a multiple post, i tried to research HID, but nothing significant showed up.
    my car being black, i'm noticing people NOT being able to see me as much as the lighter/brighter colors. i have to also admit that i'm a bit afraid to get hit or cutoff.............................our cars are very rare to purchase now!:flame::juggle:
  2. qbee42
    3,079
    1) It is safe to leave them on all of the time, but capsule life will be shortened. The capsules are fairly expensive to replace if you do it yourself. If the dealer does it, they are outrageous.
    2) The downward aim is mostly a function of the brightness and sharp cutoff of HID lights. Most of us are used to normal headlamps, which spill a lot more light down the road and into the eyes of oncoming traffic. Good HIDs have a very sharp divide between the light and the dark. Yours are probably adjusted the way they should be. If you really need to adjust them, there is a screw adjuster on each lamp assembly.
  3. Genoz World
    797
    22
    La Canada
    QBEE - thanks tom, are the adjustment screws easy to find? i haven't taken a look, but if i manually adjust them, will the self leveler compensate for this? for example, i aim it a bit higher, the leveler automatically compensates. will this be the case?
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    The auto-leveler for the HID headlamps compensates for the attitude of the car. If you load weight in the back, so it sinks lower under the weight, the front of the car points upward and the HID lights could blind oncoming drivers. The screws on the back of the lights set where the lights point and the auto-leveler keeps them pointed at the same spot with a load.
    Don't go blinding other drivers.
  5. Genoz World
    797
    22
    La Canada
    BILL - i have no intentions of blinding other drivers. as i said in my OP, i have problems seeing at night with my HID system.
  6. Patrick Wong
    18,200
    6,500
    Hi Gene,
    The more that you use the HID headlights, the more quickly the expensive bulbs will fail. However if you feel that having them on during the daytime is a helpful safety measure, then peace.
    Regarding headlight aim, I assume your car is under warranty, so why not have your dealer check the aim and correct it if necessary. Maybe the auto-leveling mechanism is not working, which causes the aim to be too low.
  7. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    as others have said, you will burn out the bulbs more quickly by having them on all the time. stick a couple bucks away every month into a bulb replacement fund and you'll be fine. as an unexpected expense, it's a bit of a shock.
    since HIDs are so bright, a professional adjustment is safest. DH does not even give out instructions for adjusting these, because the cutoff line for blinding other drivers is so fine.
  8. Genoz World
    797
    22
    La Canada
    NOW that makes sense.
    Thanks for the constructive help. i'll bring it to the dealer - make sure the lights are pointed in the right altitude. i doubt they are correct because my daughters #2, standard bulbs, light up the street - making it easier for me to see. This can't be right with the HID's.
  9. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    the stock ones light up more than the HIDs? If your daughters lights are anything like mine, then id say your HIDs ahve a problem. My Package 2 has such dim lights that you cant even tell they're on.
  10. qbee42
    3,079
    Standard lights often "light up the street" better than HIDs. That's because they throw light all over the place, even on low beam. HIDs are much brighter, but keep the light where it should be. Many driver's don't like this, as they feel they can't see far enough down the road. That's what high beams are for.
    Take your car out at night onto an empty road, and switch between high and low beam. If the high beams give you good illumination down the road, then the lights are adjusted properly. Most likely it's just a matter of you not being used to the sharp contrast of bright and black caused by the sharp cutout of the HID low beams. That's the way they are supposed to work.
    If, on the other hand, your high beams are pointing down, then take your car to the dealer to get the lights adjusted.
  11. Genoz World
    797
    22
    La Canada
    thank you TOM. i can't recall the features, but i'm pretty sure my STS had HID's also, so i'm somewhat used to them. when i park, i had made small marks on my garage where the caddy's lights pointed, and my prius's beams are much lower, but i'll try what you suggested. thanks for that info.
    yeah STUNDRA - i feel that my kids standard lights are brighter.
  12. Yak18
    Yak18 Junior Member
    92
    Southeast
    We drive with them on all the time for safety...does anybody know off hand how much they cost to replace?
    boomer57tux likes this.
  13. boomer57tux
    boomer57tux New Member
    I just changed BOTH headlights on my Prius 2007 even if only the driver side was failing , I read before that is better to change BOTH even if only was is not working, eventually the other one will go off too. I paid on Amazon $ 100 for both and guess what.. they identical to the ones ( D4R). TOYOTA sells you for $ 150 each (they "cut the price in half" after a lawsuit) even the kragen or auto zone sells them for $ 165 each.
    After I changed the lights I noticed the lights were on the roofs or the trees...Does anybody knows how to adjust them? Does Prius 2007 have an automatic leveler? Can I adjust it by hand? where is the automatic leveler? where can I adjust them by hand?
  14. boomer57tux
    After I changed the headlights on my Prius 2007 I noticed the lights were on the roofs or the trees...Does anybody knows how to adjust them? Does Prius 2007 have an automatic leveler? Can I adjust it by hand? where is the automatic leveler? where can I adjust them by hand?
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If they are on the trees, you probably did not seat the base of the bulb properly. It should be close, but slightly different, to where they were before after you install the bulb. Then you slightly change the adjustment with the thumbnail screws on the bottom side of the headlights to raise the entire reflector portion up and down.
