89.3 mpg!!!!!!!!!!!!!!!
Discussion in 'Gen 2 Prius Main Forum' started by Dixiechick, Jul 20, 2008.
  1. Dixiechick
    Dixiechick New Member
    North Texas
    Okay, so it was only 10 miles, downhill from Copper Mtn to Dillon, but it sure was fun to watch the screen!!!!
    Traveled from Dallas to Dillon, Colorado - about 900 miles each way. Car loaded with hubby, two kids and gear. Averaged 46.8 going and about 48 coming home. (Was a lot better until we hit flat Texas). Car didn't like the mountains, but she did great on the downhill! :)
    Jennifer
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Hahaha
    I do that sometimes coming home from wok in Auburn which is uphill from Lincoln. I try my best to keep the engine off while taking the corners pretty hard (very curvy road) and coming down the hill. I usually make the less than 20 mile trip at about 90-99mpg according the MFD. Then I hit the flat areas and it drops... :( It was fun while it lasted. :D
  3. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    90 MPG is doable even on level ground provided you P&G between 30 and 42 MPH.
    World record on the Prius is somewhere around 110 MPG. Record on Insight is 184 MPG driven cross country.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye, I've done 3 five-minute segments of P&G and had the bars maxed at 99mpg. That just isn't doable in the city though. :)
    I believe the Prius record is now at 116mpg? Was 112mpg. The girl from Japan keeps beaking it.
  5. fcc
    fcc New Member
    245
    Nashua NH
    oh to only have such a flat without stop lights surface to drive on from and to work so i
    could break the record ;-)
    i remember the pics from that japanese girl and frankly, i have never seen such a flat
    well paved road in my life! Not a stop light in a single picture.
    also, if you only drive the car in such a routine and nothing else... it makes her stats
    look rather meaningless to me. i said to me. others might be impressed but not I.
    she probably fails to mention that she uses her significant other's car for all other
    travel purposes which gets 30 MPG ;-)
  6. rogerDB
    rogerDB New Member
    29
    Spokane, WA
    I have a big, 14% 1/2 mile hill to go down on my 15 mile trip to work, and i see maybe 55mpg, one way, but then I have to go back up the hill to get home! I try different routs to get higher milage. Hmmm I wonder if it's better to drive 20 minutes and get 49-50mpg or 30 minutes and get 53mpg? Either way I've got that hill. At the bottom all my bars are green and i can travel quite a ways on battery only.
  7. Lcruiser
    Lcruiser Junior Member
    77
    Yup, I got a few of those myself. :D
  8. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    Flat, well paved roads. Yeh. I'm sure I lose at least two to five mpg just due to rough roads. I keep thinking I'm having tire problems, but then I get to a short smooth stretch so I know better. There's nowhere around here that could be described as flat for more than a 100 yards at a time.
    Dave M.
  9. gofast
    gofast Member
    151
    25
    Denver Colo.
    I live in colorado. You could of put in neutral:eek: you flatlander and got over a 100 mpg
