Nimh HV battery and discharge 40 amps
Discussion in 'Gen 2 Prius Technical Discussion' started by Flying White Dutchman, Jul 24, 2008.
  1. Flying White Dutchman
    4,376
    313
    what i don't get is the following
    the prius HV battery is 201 volts and 6,5 ah = 1,3kwh
    but when i drive with my canbus monitoring on i get a electric consumption of 40 amps on 207 volts
    is the battery not being discharged to a extend it can not handle?
    When i look at the plug in prius with lead battery's the recommendation is 20 x 12 volts -20ah because when you go lower the battery;s Will not provide enough amps...
    and the prius battery is 6,5ah???
  2. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    Try rephrasing your question.
    On first read to my eyes, you appear to be comparing Cumulative current (6.5 Ah) and Cumulative power (1.3 kWh) to instantaneous current (40 Amperes).
    Actually the instantaneous traction battery discharge current can go several times higher than 40 Amperes. My ScanguageII displays readings broadcast on the CANbus that say there are very brief peaks well above 100 Amperes at the onset of acceleration from a stop. Sustained full-throttle acceleration can also reach current well above 40 Ampere. Your battery can handle that and more--has to in fact in order to get the specified maximum power out of the electric motors MG1 and MG2. But it cannot do so for very long at all-which is the point that your comparison with the time integral numbers makes.
    Again, if this response was misoriented to your actual question, please try rephrasing it a little.
  3. Flying White Dutchman
    4,376
    313
    ok
    what i wonder wy a lead acid battery can nog provide this because then i simply put in a 7ah 12 volt x 20 lead battery pack and parallel it and i wil double the ev range!
    OR CAN Nmih handle more higher discharge amps?
  4. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Don't confuse Amp-Hour with Amp!
    Amp-Hour is how many electrons the battery can hold.
    Amp is how many electrons per second the battery can put out.
    If you have 6.5 Amp-Hours, you can spit out 6.5 Amps for 1 hour, or 13 Amps for 1/2 hour, or 1 Amp for 6.5 hours or 65 Amps for 1/10 hour or 650 Amps for 1/100 hour.
    Does this help?
    (A simplified explaination - I know that an Amp Hour really is 3600 Coulombs, and that the charge on an electron is 1.60217646 Ăƒâ€” 10-19 coulombs, and that the definition of an Amp is a coulomb per second.)
    Zamprius likes this.
  5. Flying White Dutchman
    4,376
    313
    a 12 volt 20ah lead battery can only put out 1ah ( a hour ) because the 20ah are based on a 20hours discharge rate.
    so a 12 volt 20ah battery wil not provide 1 our of 20amps or 40 amps for 30 min
    so i think battery chemistry is needed to take in to account.
    maybe a 12 volt 20ah battery wil provide ( if you take 1ah ) 2 amp for 30 min
    and not provide 40 amps in 30 min.
    if the prius battery is 6,5ah then in your calculations its 390 amps per min.
  6. Patrick Wong
    18,200
    6,498
    Consider a regular automobile that has a starter motor. The 12V battery in such a vehicle may be rated around 50-60AH. However, for a few seconds while the starter motor is running, the battery has to deliver several hundred amps to power the motor.
    In any event, it is true that the Prius traction battery can receive and deliver current in the high two-digit ampere range for brief periods of time. I also noticed this when using the Ecrostech scanner on my 2001.
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    The amount of current a battery can deliver is not related to its' Amp-hr capacity. It's related to the design intention. In the Prius battery case, the battery is designed for this application, so it can deliver up to around 100-150 Amps short term.
    Many gel lead acid batteries are designed to power remote electronics, so cannot deliver much more than 5-10 Amps without internal damage. You -can- get gel cell batteries that are designed for high current discharge, but they are not as common as the lower discharge type.
    It's related to the size of the internal cell plate connectors and cell interconnects, as well as the fine adjustment of the internal chemistry.
  8. kohnen
    317
    58
    Fullerton CA
    Nope. It doesn't make sense to use the units Amps per hour.
    You're right - the "real world" case of the Amp-hours of a battery is you have to define it at a certain discharge rate. If you have a 20 Amp-hour battery defined at a 1 Amp rate, then it will have a somewhat lower Amp-hour rating if it's discharged faster. As an example, I have a 12V, 7Ah battery (lead acid) that puts out 4 Amps for an hour. It has a lower (in this case, 4 Amp hour) capacity rating because the current is higher.
  9. Flying White Dutchman
    4,376
    313
    thats wat i was looking for
    a 12 volt 7ah lead battery x 20 wil not be able to discharge 100 amps and the design of the prius Nimh battery is able to.
    i was hoping a 12 volt 7ah x 20 = 240 volts 7ah setup wil have the same capability as the prius battery of 201 volts 6.5ah battery:(
  10. kohnen
    317
    58
    Fullerton CA
    No, but...
    (disclaimer: _YOU_ need to make sure that you know what you're doing and don't either electrocute yourself or damage your car or its surroundings. This should be in no way considered advice on what to do or how to do it nor should it be considered an endorsement thereof.)
    If (presuming it can be done) you put a lead acid battery pack in parallel with the NiMH pack, the lead acid will have a lower peak power capability (fewer amps) than the NiMH pack. But, it will have a similar energy (amp hours) as the NiMH pack. Under peak acceleration, most of the energy will come out of the NiMH pack. Then, when you're cruising, the lead acid pack will be charging the NiMH pack. So your idea still might work well.
    This is similar to the idea of putting a battery with an ultra capacitor in an electric vehicle. The battery has the energy in it, but can't provide that energy quickly. The capacitor stores less energy, but it can release it VERY quickly so you can get good acceleration.
    Good luck, but be careful: You don't get second chances with 300 Volts.
  11. Flying White Dutchman
    4,376
    313
    "YOU_ need to make sure that you know what you're doing"
    you now that there is the opensource plugin prius project?
    a lead acid battery packs are already being put in paralel to the prius battery!!
    and i already have the 500volt dc protecting gloves
  12. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    I seriously doubt it is directly hooked in parallel--the characteristics are seriously mismatched for charge and discharge to the NiMH installed traction battery.
    I'm not a car guy, but I am an electrical engineer and also know something about batteries. From the content of your posts so far and the nature of the problem, I think this endeavor is not likely to go well for you. A poor relation of cost and risk to reward seems quite clear.
  13. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    I was surprised but that is exactly what they do here in this link from Calcars:
    see PriusPlus-Theory - EAA-PHEV
    PriusPlus-RawData - EAA-PHEV
    This uses a 240V 20Ah lead-acid pack directly paralleled with the NiMh pack - I guess it works but I would have thought the surge currents would be rather high. If a lower resistance battery is used a 0.3Ohm resistor (1800W!) is inserted in series to reduce the peak current.
    kevin
  14. kohnen
    317
    58
    Fullerton CA
    Sorry to seem anal, but I'd rather not anyone get hurt.
  15. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Well I just erased this post before I could publish it, so here goes second time around. Probably won't be quite as detailed this time, sorry.
    The cal cars design is about as simple as you can get (and hence about as cheap as you can get). At its essence it really is just as simple as paralleling a big lead acid battery with the built in oem battery.
    Of course things aren't really that simple. The Prius' battery controller functions as a Coloumb counter, meaning it derives SOC by measuring how much charge comes in and out of the battery not by voltage. There is a good reason for this, as voltage is a very poor indicator of NimH SOC. The upshot is, you can park a big battery in parallel all day, but the HV controller won't use any of the extra charge available from it. It already "knows" how big the battery is supposed to be, and only lets out as much current as that battery can handle and then tells the HV controller to put it back.
    Fortunately it was discovered that there is a built in "recalibration" routine that kicks in at 242V. The OEM battery is nominally 201.6V (1.2V/cell*168) but at full charge its more like 1.4V/cell or 235V. At 242V it assumes things have drifted over time (since coulomb counting is sort of a "dead reckoning" approach) and it revises its SOC value upwards to compensate. By using a secondary battery with a voltage higher than 242V, you can trigger this routine and get the controller to use the extra charge.
    Of course this creates additional challenges. Cal-cars uses a 20 battery pack, that is nominally 240V, but more like 260V at full charge. This is more than enough voltage to cook the oem battery if you were just simply to parallel the two together. In addition, it turns out that you can't just keep the oem battery "full" and have everything work well. There is a "magic" SOC range at which the HV controller will use a lot more electric drive at all speeds, which is key to getting good mileage out of a conversion. If the SOC is a little lower, it will just drive like a normal Prius and you won't see much benefit. If the SOC is a little higher, the HV controller will start burning off charge in inefficient ways like spinning the ICE. Whats worse is that the magic number charges with temperature and driving conditions.
    Cal-cars addresses this problem by putting a switch (contactor) between the primary and secondary packs (told you it was simple). Then you need a controller to decide when to open and close the switch to keep the SOC where you want it. Currently this is done by the CAN-View. It monitors the CAN bus traffic, and opens and closes the contactor as needed. This is a pretty brute force approach. The oem battery is physically dragged around to each SOC rating, which takes time. The CAN-View can also only target two fixed (though programmable) SOC values based on two driving states (hwy, city). The next gen controller, which is currently in beta will be open source, and much more sophisticated. It uses an SOC "spoofing" approach, whereby the real SOC CAN data is read from the battery, and then the ideal SOC for the current conditions is transmitted to the HV controller. In this way the battery is simply maintained at a good level, and the HV controller is always told what it wants to hear almost immediately. This allows for much faster response times, and a much more sophisticated algorithm.
    The batteries currently in use are like these:
    http://www.bb-battery.com/productpages/EVP/Evp20-12.pdf
    They are AGM type SLAs capable of >100A sustained output, and are designed for use in UPSes and wheelchairs/scooters. At this capacity and weight you end up with a ~300 lb pack for ~10-12 miles EV range which seems about optimal. In practice the observed discharge current is about 40A-60A when fully charged and discharging into a low SOC pack or under heavy load conditions. There are other batteries available, as this is a standard form factor, these ones just seem to be above average. I have done a survey of other options on the "medium" tab here:
    Google Docs - phev batteries
    The biggest disadvantage to the cal-cars conversion at this point is battery cycle life. Part of this is inherent to lead acid, and part of it is exacerbated by the lack of battery management. Currently their is no balancing done on charge or discharge, and the batteries are run to very low SOC. When they are depleted they are currently left in parallel with the oem pack in whats called charge sustain mode. This has the benefit of providing extra regen charge storage, and lowers the effective resistance of the battery pack improving performance and efficiency somewhat even when the pack is dead. I believe both of these things take a toll on the batteries, and contribute to the observed lifespan of ~1 year. All tought the upfront cost of the cal-cars conversion is low (~$3-4k), this recurring battery cost (~$1k/year) keeps the conversion from really being financially viable. A BMS would probably help, but would add cost.
    There is work going on to expand the basic cal-cars method using Nilar nimH, or Li-ion. Both of these require custom BMSes, but the NimH is simpler and farther along. NimH adds to the upfront cost, (maybe $6-7k total) but should bring the EV range up to around 15 miles and improve cycle life greatly keeping recurring costs low. Li-ion is farther out, but should improve both again, but probably at higher cost.
    http://www.nilar.com/be/__media/pageID_14/langID_1/Nilar MB 24V 9Ah.pdf
    You can find a lot more on all things PHEV related here:
    Main Page - EAA-PHEV
    technical details on the Cal-car Prius+ here:
    PriusPlus - EAA-PHEV
    and an excellent mailing list where many of the open source contributors hang out here:
    Maillist - EAA-PHEV
    Lastly, these things have to be treated with a lot of respect. You have ~260V DC at hundreds of Amps available in a short circuit situation. Thats more power than most people have coming into the main panel on their house. A short under these conditions will create a self sustaining plasma fire that will make an arc welder look like a 4th of July sparkler. The recent Hybrids plus fire is a good reminder of what even a simple mistake like a loose HV connection can lead to.
    Rob
  16. Flying White Dutchman
    4,376
    313
    i am not and never was going to put it in parallel without a contactor
    if you just parallel it then it wil cook the prius battery
  17. miscrms
    2,079
    526
    Phoenix, AZ
    I think you'd seen this all before Dutch, some of the others on the thread seemed to be wondering about the cal-cars conversion.
    The spreadsheet I linked above has a pretty exhaustive list of batteries if you want to check it out. The medium tab are the 17-22 Ah units usually used by cal-cars. The small tab are more in the 8-15 Ah range, but still capable of putting out 100A. This list is not as fleshed out as I'm mostly looking at the medium sized ones.
    Rob
  18. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    I'm probably missing a point here, but even considering using lead is beyond tarded, it suffers GREATLY from puekert. Aside from weight, this is the main reason lead was dumped as an option decades ago
    Peukert's law, presented by the German scientist Wilhelm Peukert in 1897, expresses approximately the change in capacity of rechargeable lead–acid batteries at different rates of discharge. As the rate of discharge increases, the battery's available capacity decreases, approximately according to Peukert's law.
  19. mr_guy_mann
    mr_guy_mann Senior Member
    4,020
    1,948
    NJ-USA
    Yep- sure does. It's just that big lead acid batteries were relatively cheap and available FIFTEEN+ years ago when this post was made.
  20. tracy ing
    384
    173
    wash dc
    actually, no, they WERE THROUGH THE ROOF due to skyrocketing lead costs and huge proliferation of lead based ev's in india and china, regardless. people still READ this stuff as evidenced by me, perhaps instead, they should just go DELETE everything on this site after a certain period ?
    That would prevent people like me, detail oriented, from reading and responding, which then leads others to jump on it with a non sequitur reply regarding age of post ?
    lead sidebar, I conversed with a research scientist out of RTP in NC, he bicycled around various factory towns in china, in one that made lead plates, they hosed the place out daily into a lake out back, he said there was a lead slurry on the bottom of the lake over 12 inches thick. he also said that due to rolling blackouts planned by the govt, these same workers would migrate town to town and work in food and such, lol.
    fourteen years ago, lead was sky high and driven so by the massive proliferation world wide of high speed scooters, i would know.
    #20 tracy ing, Aug 5, 2022
    Another likes this.
