Taillight Assembly Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by racislo, Aug 7, 2008.
  1. racislo
    racislo Junior Member
    Connecticut
    How do you remove the plastic trim inside the hatch next to the bumper as described in the thread Cracked Taillight Dome: Parts and Replacement?
    I usually crack plastic parts or the tabs that hold them in place when I start pulling on them.
    Thanks for any tips.
    Bob
  2. Patrick Wong
    18,200
    6,500
    Hi Bob,
    I had to remove the hatch trim on my 2004 when I replaced the rear shocks. Use your hands, no tools, and pull gently. Once you get one end loose you can see what the clips look like, which may give you more confidence to remove the trim.
    It also would be a good idea to do this when the interior is relatively warm. The plastic is probably more brittle in cold weather.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Spammer reported to mods.
  4. Mx5Racr
    Mx5Racr New Member
    Santa Rosa, CA
    I am looking for guidance on replacing the drivers side tailight assembly. Is the assembly really held on by those little plastic nubs?
  5. Patrick Wong
    18,200
    6,500
    There are two nuts and two pins holding the rear combination light assembly to the body.
