First Real repair at 78500 miles--Struts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Aug 12, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    "That left strut's all blowed up...there's oil and stuff all over the place."
    In another thread I reported that I've had a front end rattle for a couple of weeks. From that thread it seemed likely that it was a strut.
    Toyota Service couldn't work me in today and I'm busy all week. So I went to the local Goodyear shop near my house that I've used for tire repairs in the past.
    As usual there they go to me immediately...the head honcho took the Prius out for a quick drive, threw it up on the rack and came back with the above report.
    The local parts place couldn't get the struts and mounts, the Toyota dept. can't get them until tomorrow and charges about $10/part more (total $40 more)....
    Struts $198 x2
    Mounts $98 x2
    Alignment $54 <--They said this wasn't essential, but I haven't had one for a while
    Labor $285
    Tax ~$45
    Grand Total $1014
    I just thought this project would be more than I could do at home...would think one would need a lift, or at least some decently tall jack stands....so I pay for this one. Sucks b/c its the first real repair (I'm not really counting the MFD replacement, though probably I should).
    I'll update on Thursday night after I get the car back.
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    good call on the alignment, you definitely want that if you're replacing struts.
    compressed springs are dangerous to deal with. if you're not sure, this is something you'd rather have someone else do for the safety factor anyway. you'd lose a lot more than ~$350 (tax, all labor) claiming on your short term disability insurance over going to work if something went south.
    suspension parts are wear items though- so technically you're still in maintenance territory imo.
  3. efusco
    19,891
    1,196
    Nixa, MO
    Ok, I'll buy that.
  4. Patrick Wong
    18,210
    6,510
    Hi Evan,
    Yes, you would need a couple of jackstands and a spring compressor, plus a socket of the appropriate size to loosen the two large bolts holding the bottom of the front struts to the steering knuckle. Since you've decided this work is out of your comfort zone, the price seems reasonable.
    Note that spring compression is not a big deal; I bought a spring compressor tool from Sears for $55 which works quite well and has safety pins to prevent the tool from slipping off the coil spring.
    Craftsman Strut Spring Compressor Tool with Built-In Safety Pins - Model 90500 at Sears.com
    If in the future you decide to try your hand at this job, you definitely will want a tool with the safety pins. I've used that tool to replace six struts/shocks so far: all four on my 2001 and the rear two on the 2004.
    I remain unconvinced that routinely replacing the top mounts is required, since they are quite rugged in construction. I suggest you ask the mechanic to save the old mounts so that you can see whether any play exists or not.
    BTW, Champion Toyota in Houston sells the front struts for $99 each while the strut mounts go for $62 each (plus shipping).
    http://www.trademotion.com/partloca...=2004&graphicID=F820050&callout=3&catalogid=1
    Another reason to DIY.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Planning for the future here, just in case ....
    It's been many years since I've had struts replaced on a car. Based on my (admittedly fuzzy) recollection of their cost, this seems pretty pricey. Forgetting the alignment and the mounts for a minute, that still leaves ~$800. Several questions:
    1. Is the labor component pretty consistent with most FWD cars nowadays?
    2. If not, is there something about the Prius that makes them tougher to install than in a conventional car?
    3. Do any of the aftermarket shock/strut manufacturers make one for the Prius?
    4. If so, how's their quality?
  6. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I pay $900ish to replace the struts on my Camry a few years back. They said it was labor intensive. A friend who had replaced the struts on his jeep (did the work himself) agreed with that assessment.
  7. Patrick Wong
    18,210
    6,510
    1. Yes, except that you have to remove the cowl when doing the front; and remove much of the hatch trim when doing the rear. As a DIYer, it takes me around 3 hours to do either front or back, given the lack of learning curve efficiencies.
    2. N/A
    3. KYB, which also makes the Toyota-brand struts/shocks
    4. I haven't tried the KYB-brand yet.
  8. richard schumacher
    7,664
    1,046
    United States
    Evan, would you say that the originals saw normal use? Were there any severe shocks?
  9. galaxee
    9,810
    471
    MD
    just be careful with those, they can warp springs if you're not.
    DH has one similar to this, but made by snap-on: OTC 6494 - Clamshell Strut Spring Compressor much safer to use and less likely to cause damage or injury.
    compressed springs, when released unexpectedly, can punch a hole in a cinder block wall. DH saw someone do it in his early days as a mechanic.
    they're not that rugged. worn strut mounts make suspension noise. annoying suspension noise. since he's already having the entire assy torn down and the labor to replace it is basically free, not installing new strut mounts amounts to asking for the same labor bill to replace different parts later.
    this is the same thing DH has always said, will always say, and has done to our own cars, based on what he's seen. especially front mounts.
    1. the shop that E is going to is getting more for labor than DH's old shop, but this is understandable. it's pretty standard for there to be an "easy job" rate and a "tough job" rate. sounds like DH was getting paid the easy job rate, where the shop E is going to charges the tough job rate. the tough job rate is justified in comparison to other cars.
    2. the wiper cowling is in the way- that's not typical. most of the time the mount bolts are out in the open, real easy to get to. if you've got a ratcheting wrench and know what you're doing, you can do it without pulling the cowling, but it's a similar pita with that.
    3. kyb manufactures most of toyota's oem struts and makes an a/m for the prius.
    4. the oem struts that are made for toyota are made to different specs than kyb's a/m parts. don't know of anyone who's gone with the a/m part. we had kyb a/m struts on our old camry and they did not last long. they were fine while they lasted.
  10. efusco
    19,891
    1,196
    Nixa, MO
    I'd say pretty normal use. I have used somewhat higher than usual tire pressures and have passingly wondered if the BT Strut brace could possibly be a factor.
    I'm sure I've hit a curb or two hard at times and I take some corners pretty hard. That said, I don't recall any bumps/strikes of great significance that would be responsible for damaging the strut....but then I don't really know what it takes to do so.
  11. efusco
    19,891
    1,196
    Nixa, MO
    Let me add a comment on the price....
    I sort of figured the price for the parts was higher than I could find them elsewhere, and Toyota's price was higher than what the Goodyear place had on their computer list, but I believe the guy as I was standing there as he talked to Toyota parts.
    The labor seemed reasonable for the work involved, and I did look at the Toyota TSB. I wanted an alignment and certainly couldn't do that at home. I wanted it done fairly soon as I don't have a lot of free time or a 3rd vehicle to use. Toyota needed me to make an appt., then they couldn't be sure they could do the repair the day they made the diagnosis, then I'd need another appt.
    And most importantly....this is a local small business in my small town that deserves support. EVERY time I've gone in there they've gotten my vehicle right in, did good work, were fair, honest, took care of my car, were nice and respectful. They got me in and made a diagnosis after I drove in cold within 15 minutes of walking in the door and would have fixed it today if they could have gotten parts....as it is they're doing it tomorrow while I'm out of town.
    That kind of service has significant value. Supporting a local small business has value. I can afford to pay for those things and am happy to do so.
  12. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    how much more for tourings!!!
  13. chinalfr2
    chinalfr2 Member
    234
    New England
    I will take the opportunity and swap out the suspension with TRD sportivo kit. With the amount you paid for OEM parts, it's seem to be no brainer to upgrade to the TRD sportivo suspension kit.
  14. efusco
    19,891
    1,196
    Nixa, MO
    No upgrading, no touring....The car is almost 5 years old and I'll be selling it in about 2 years and have poured enought money into it for various upgrades at this point.
  15. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    lol yeah i was choked when i found out TRD version wasn't that more expensive than stock strut/mounts.
    they came with new springs too ARGH!!!
    3 hours for a rookie like me with shop equipment (fancy compressor spring tool, automotive lift and a tech's toolbox)
    it pays 1.5 hours, :( maybe i should be a service ad visor lol
  16. Eunurse
    Eunurse New Member
    32
    Orange County Ca
    Would struts be something that were covered under the extended warranty?
  17. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I think so, as I don't see struts listed among the exclusions.
    The Toyota Financial Services website has this to say about the Platinum Plan and its excluded components:
    "Note: Platinum protection covers virtually all component groups on new vehicles. If your new vehicle's component does not appear on our List of Excluded Components , it is covered by Platinum protection."
    "List of Excluded Components
    • Accessory Drive Belts
    • Batteries
    • Body Panels
    • Brake Linings, Pads and Shoes
    • Bumpers
    • Carpet
    • Chrome
    • Clutch Friction Disk and Pressure Plate
    • Dash Cover and Pad
    • Door Trim, Handles and Fabric
    • Filters
    • Fluids
    • Glass (including Windshield)
    • Headliner
    • Heating Hoses, Lines and Tubes
    • Hinges
    • Hybrid System Main Relays
    • Hybrid Vehicle Battery
    • Hybrid Vehicle Battery Module/Pack
    • Hoses
    • Interior and Exterior Trim Moldings, including but not limited to, Cup Holders, Ashtrays, Covers, and Vents
    • Lamps
    • Light Bulbs
    • Nuts, Bolts, Clips, Retainers and Fasteners
    • Paint
    • Rotors and Drums
    • Rust and Corrosion Damage
    • Seat Covers
    • Service Plug
    • Shiny Metals
    • Spark Plugs
    • Structural Framework and Wells
    • Tires
    • Vacuum Hoses, Lines and Tubes
    • Weather Stripping
    • Wheels and Rims
    • Windshield Wiper Blades (Rubber Component)"
  18. Boo
    5,051
    488
    97
    Flushing, NY
    I think the Touring has the same front struts and springs as the Standard Prius.
    The suspension parts that are different on the Touring are the front and rear stabilizer bars and the rear shocks and springs.
  19. efusco
    19,891
    1,196
    Nixa, MO
    Crap! I figured a wear part wouldn't be covered but didn't check the warranty. I've already paid for the parts....and the labor for that matter.
  20. Boo
    5,051
    488
    97
    Flushing, NY
    The parts should be returnable, and the labor hasn't been performed yet.
    I would think you should be able to get a full refund, and give the guy $50 for his trouble.
    But I'd re-read all that extended warranty stuff again to be sure.
    But if I'm right about the extended warranty I think you might be able to get everything (both struts and maybe the alignment) done under the extended warranty on the theory that common practice is to get both struts replaced at the same time (and not just the single damaged strut), and I thought that when you get front struts replaced you're supposed to get an alignment too.
