TPWS workings
Discussion in 'Gen 2 Prius Technical Discussion' started by dwreed3rd, Aug 20, 2008.
  1. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Can anyone point me to a place where I can learn more about the TPWS on the Prius. Like:
    What psi sets off the alarm?
    Is it adjustable?
    What about running higher psi?
    What about rotating tires?
    What about rotating tires with different psi front to rear?
    Do you need a special tool to reset/register?
    If so, does that mean that if I change the psi in my tires or rotate them that I have to have it serviced to keep the TPWS in sync?
    I realize this is alot of questions, so if you can just point me in the right direction I would appreciate it. I have the Bentley shop manual but it really does not adress some of the Q's. I've searched PC, the web, and TN to no avail.
    Thanking everyone in advance for any information.
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    use advanced search, look for posts containing the term TPMS by me. :) that should get you started on a bunch of technical info, and if you have follow-up questions, fire away.
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    a drop of psi of 25%
    Is it adjustable?
    you press the tire button to set it at the current psi, for the alarm no
    same you press the tire button to set it at the level you want
    rotating tires is m00t because the prius does not tell you which tire is low, you have to find out which one and inflate it to get the light turned off
    if any of the tires drop the light will come on.
    same thing.
    yes. you need the dealer's scantool, the dealer's laptop or a third party device
    like ones manufactured by bartec, for resetting registered sensors you do not need any tools
    no just ignore the tpms when you rotate. the syncing process is easy (once the transmitters are registered) its just a matter of holding that set button down
    the only thing you have to be careful about is when the tire needs to be taken off the rim, make sure the tire installer knows you have tpms installed so he does not accidently take out a sensor. make the tire installer walk you around your car to make sure all the sensors are operational
    another thing is do not use those spare tire in a can products, it will damage your sensors
    yet another thing is the prius only has room in its computer for 4 tires. which means if you switch from summer to snow tires, or you either need to take the tire off the rim, or buy 4 more sensors and have them 'registered' each winter!
  4. dwreed3rd
    742
    Marietta, Ga
    rigormortis: I really appreciate the time you took to answer all my questions. I was trying to avoid anyone having to do that. Thank you many times over.
