quick question about cargo and the prius
Discussion in 'Gen 2 Prius Main Forum' started by slair, Aug 25, 2008.
  1. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Real quick and simple while I'm at work and my wife has the prius for the whole day. Can a 4x8 sheet of wood fit in the prius? With the seats down and everything. I cant get to it to measure it right now. :p
    I need to know if I need to let my buddy know if I need to borrow his truck or not.
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    No, a 4'X8' sheet will not fit in a Prius. No matter what you do.
  3. Patrick Wong
    18,200
    6,500
    43" or 44" width is the maximum if you have the wood laying flat. However, if you have the wood turned diagonally and don't mind having three feet of wood hanging out the hatch opening, you might be good to go for a short distance.
  4. qbee42
    3,079
    Yes, but you have to saw it into a bunch of smaller pieces. :D
  5. Qlara
    Qlara New Member
    488
    No need to fit inside, just tie it 'very securely' on the roof......
    Your MPG will drop a lot though, due to the increased in wind resistance.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Folding always works, or rolling it up into a tube ....
    or renting a van or pickup so you don't kill yourself!!!
    Thats why I kept the gas sucking 4Runner, Home Depot!!!
    73 de Pat KK6PD
  7. qbee42
    3,079
    You can also buy your plywood in kit form, where you get several rolled sheets of veneer and a gallon or so of glue.
  8. slair
    404
    Lafayette, IN
    (I'm not being a smart@$$, I promise!)
    I never said it was plywood :p
  9. KK6PD
    4,003
    946
    118
    OK, OSB, MDO, veneer plywood
    What else comes in 4' X 8' sheets???!!!!!
    Pat KK6PD
  10. richard schumacher
    7,664
    1,046
    United States
    The roof? Yeesh! Unless you can creep along at less than 20 MPH or so the forces there will either damage the roof or tear the sheet away. Put it in the back with lots of bungees to secure it and the hatch, or have it delivered.
  11. qbee42
    3,079
    OSB, chipboard, or plywood - we can give you a kit for any of these. If you have a 4x8 plank of wood, I want to see the tree! :D
    One way around the size problem is to buy a small tree, take it home in your Prius, then plant it in the back yard. Once it gets a bit over four feet in diameter you can harvest it for wood.
  12. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    My previous car - Buick Regal - wouldn't carry a 4x8 sheet either. I still do what I did back then: borrow a buddy's full-sized truck and return it with a full tank and case of beer.
    If you have no friends with full-sized trucks, follow KK6PD's advice and rent a flatbed from a home improvement store.
  13. KK6PD
    4,003
    946
    118
    Now that's funny!!! If I only had the time to wait!
    Pat KK6PD
  14. slair
    404
    Lafayette, IN
    hah, thats good :D
  15. Sarge
    Sarge Senior Member
    1,324
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Don't forget to hug the tree as well, to further reinforce the stereotype us Prius drivers seem to carry... :D
  16. Qlara
    Qlara New Member
    488
    30MPH is the max, I did it last time when buying a storm door.
    It won't inflict any damage if you know how the air will flow on top of the roof. Just never stick out more than 3 inches on top of the front windshield and drive with caution will be fine. The car DOES show you the sign (loud banging) when you're in dangerous speed, indeed.....
    People used to carry mattress with car this way, not see one on Prius yet.
  17. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I carried a bunch of mdf for some shelving, but I had it cut at the store. :)
  18. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Sorry to bump such an old thread, but this is the one that came up when I searched.
    So plenty of joking on here, and 2 conflicting answers (yes diagonally, and not at all). I'm assuming based on all the joking answers that David's answer is the correct one. So I'm curious, does anyone know what the largest possible size plywood will fit diagonally (or otherwise)? Or do I need to go try it out myself to find out?
