Get all cars off the road because some leak oil
Discussion in 'Environmental Discussion' started by carz89, Aug 20, 2008.
  1. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    This thread title is an exact analogy of a recent news article published on August 16th in Bloomberg.com. In the article "McCain's Pitch for Safe Nuclear Power May Be Undercut by Leaks" Bloomberg.com: Exclusive the author asserts that John McCain should not be promoting Nuclear Power because a recently-discovered leak on a submarine proves that nuclear power is not safe. As an expert in nuclear power and one who tests and certifies submarine nuclear powerplant components, I can assure you that this is analogous to saying automobiles are not safe to the population or environment because a very small percentage of them occasionally leak a few drops of oil.
    McCain is absolutely correct in touting the safety record of Navy Nuclear Propulsion. There have been no accidents or releases of radioactivity that resulted in a member of the public receiving a dose above any federal limits. And the federal radioactive exposure limits are very conservative, well below the threshold that would manifest itself in an increase in measurable cancer rates. And the safety trend is only improving. The article's author seems very focused on "accidents" that occured back in the 1960's, when nuclear power technology was in its infancy.
    Again, another case of the general public (fed by the media) not understanding the true science and statistics behind nuclear power. There doesn't appear to be much negative press about all the routine leaks and spills that are commonplace at refineries and fossil-fuel powerplants, or at gas stations, or dripping from your engine. Probably because no one is afraid of them. If a spill occurs at a oil-burning powerplant, people can see, feel, taste, touch and smell it. Not so with radiation, so people are afraid of any amount of radiation, even if it's less than the amount you receive getting your teeth x-rayed.
    Are there politics involved? Maybe. Hopefully not. I hope Obama is smart enough to recognize the nonsense assertion in the Bloomberg article. If Obama's camp uses that story against McCain, and he ends up as our President, then our country will be in a world of hurt with a leader who believes bad science. Whoever becomes our president needs to scientifically embrace clean energy, of which nuclear power is a part.
  2. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Even a small amount of oil can contaminate surprising volumes of soil and water. Engine leaks are definitely a problem, and more concern isn't such a bad idea.
    As for nuclear, yes, there are irrational fears about it, but it really can't be considered 'clean' in the same way that sustainable forms of energy can.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Unfortunately, there is a little bit of bait and switch going on. The safety of Navy nuclear plants would be applicable if building Navy nuclear propulsion plants was what we were going to generate utility power with. We are not doing that. We are talking about commercial power plants. Utility plants are engineered different, have different safety design, have different everything. Very important, is that financial concerns can pressure a utility to make decisions to put maintenance and safety concerns second to financial concerns.
    Additionally, the real issue is not so much the operational safety, but the overall safety of the whole life cycle of the fuel. This spans many thousands of years, not just the 50 years of an operational plant.
    This is not a statement for, or against, nuclear plants. That's a seperate thread. This is a post to get the focus off media manipulation and on the real issues worthy of nuclear discussions.
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    Never mind. I realized this isn't FHOP.
  5. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    Can you guarantee that Homer Simpson won't be working in one?
    I don't have a problem with the concept of nuk-you-lar power. Unlike dim witted lefties I don't think 'nuke make weapon, nuke bad' but can private industry with it's cronyism and nepotism or worse yet a government agency following EEOC guidelines be trusted to run something with such potential danger ?
    Logically comparing an oil leak from a car to a leak from a nuclear power plant is a false....... something. It's been a long time since I've taken the courses to label it correctly so I'll simplify it to JUST F'ING STUPID.
  6. Devil's Advocate
    922
    Las Vegas, Nevada
    This thread may have started with Hyperbole, but this is EXACTLY the mindset to many environmentalists that view human society as "un-natural" and want a more natural existence. re. go live in a cave.
  7. darelldd
    6,057
    389
    Northern CA
    Only one thing to say:
    EV's don't use engine oil. Power one with nuke's and you've got a win-win situation if there ever was one. :)
  8. blamy
    blamy Member
    380
    Central Florida
    Would that be a onetime lifetime fillup!:D
  9. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    No engine oil at all to reduce wear and tear on parts?
  10. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    Yes but you have to get an IAEA inspection every quarter.
  11. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    You'd probably use grease for that not oil. That's me guess anyways.
  12. bac
    bac Active Member
    863
    52
    Pennsylvania
    I am NOT an expert on nuclear (I can pronounce it though!) power, but logic tells me that a engine oil leak does not equate to a nuclear power leak.
    Call me silly if you must. ;)
    ... Brad
  13. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    To environazis a single drop of oil is equivelent to Chernobyl. It could harm an entire ant colony!!!
  14. carz89
    444
    47
    San Diego
    I am an expert in both nuclear power and environmental engineering, holding a PE and masters degrees in each. I can tell you with certainty, without divulging sensitive information, that the particular leak on the USS Houston, emitted fewer curies (spread out over thousands of cubic miles) than are contained in a typical bag of garden fertilizer. Bet you didn't know fertilizer was radioactive! Actually, most things around us are radioactive. In fact, most submariners receive less exposure while underway than do average land-bound humans, even though they spend all of their time less than 200 feet from an operational nuclear reactor. This is an extremely well-documented fact, proven with the use of radiation monitors that must be worn at all times by Navy submariners. While underway, submariners are shielded (under hundreds of feet of water) from most natural radiation sources that result in each of us land-lubbers receiving an average dose of 1 mrem per day.
    Some people think that I'm comparing apples to oranges (radioactive water leak versus common automotive oil leaks). Well, I am. But there are certain properties of apples and oranges that you can compare: calories, nutrient content, etc). Likewise, you can scientifically compare the environmental damage (including the effect of exposure on humans and other animals) caused by a radioactive water leak of known magnitude versus common automotive oil leaks.
    So, contrary to a very ignorant and lazy statement by "Dave_PH", it is not *^#&$@ stupid to compare the two. In fact, a comparison is the only thing that gets the point across to most people. Nothing wrong with people not understanding nuclear energy, just those that refuse to accept other's educated analysis.
  15. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    Of course you are. And I bet you're also a former Navy Seal stationed aboard that submarine.
  16. tripp
    4,717
    79
    Denver, CO
    carz39, it seems like breeder reactors might be a good path to follow, from what little I know. They can use thorium, no? If I recall, it's considerably more abundant than Uranium. What's the end result of using thorium? Can it be weponized in the same way uranium can when used in this type of reactor?
    The other concern I have with nuclear is water. In a lot of places it seems that nuke plants consume a tremendous amount of water as part of their operation. To what extend can that be mitigated?
  17. Bob47
    Bob47 New Member
    182
    Arlington, TX
    Not sure I agree with the final paragraph. People seem to think that wind and solar are without environmental impact simply because they are considered renewable forms of energy. Both; however, require large areas of land to be cleared and, particularly in the case of solar, that land can not be used for agriculture or natural vegetation that contributes to scrubbing of the atmosphere. This can also have long-term implications in terms of storm water runoff from changing ground cover types and will certainly have an impact on habitat quality and quantity. Likewise both wind and solar are subject to damage from natural occurrences (tornadoes, hail storms, hurricanes, severe micro-bursts from thundershowers, lightning, etc.). Finally both require extensive connections to the grid, spread out over very large areas. These connections demand land as well as generate electromagnetic fields that "may" be harmful to humans and animals.
    I understand that folks tend to become excited over the half life of nuclear waste being in the thousands of years; however, I recently read that all of the waste generated by all of the nuclear power plants in the world to date would not fill up a small warehouse. I wonder how significant this problem really is once the emotion is removed and the science analyzed.
  18. carz89
    444
    47
    San Diego
    I am not an expert on nuclear weapons, so I can't help you there.
    Regarding the water usage of a nuclear reactor, the systems of concern are pretty well closed systems. Water that becomes radioactive gets reprocessed through filtration and ion exchange. Very little water is wasted or "consumed". Most of the water that is "used" is simply to provide a heat sink for secondary cooling on the steam turbine condensers. It does not pick up any radioactivity. The only thing that happens to this cooling water is that it picks up a good bit of heat energy. Thus, the outlet temperature is a few degrees warmer than the inlet temperature. This warmer water (fresh river water or ocean saltwater) is dumped right back to the source it was obtained from. If cooling towers are used rather than condensers, then some of that water (still clean) is evaporated to the atmosphere. Hence, the plume of steam that you typically see rising from the cooling tower (not smoke, which is a common misconception).
    The warm water emission is the reason you will always see a civilian nuclear reactor situated by a large body of water capable of mitigating the temperature effect. Permits are required to ensure the environmental impact (local temperature rise) does not exceed ecological limitations. Warmer water will hold less dissolved oxygen, which can affect sea life.
  19. carz89
    444
    47
    San Diego
    I've noticed from reading your responses on other threads (such as "Arkansas Gazette - Bell the Hybrid") that you pretty much disregard the intelligently-stated, well-documented posts of other forum members to further your own agenda.
    When you walk into a doctor's office, do you say in a sarcastic tone "of course you are a doctor. And I bet you are also a former resident physician at Bethesda Medical Hospital who treats members of congress and the President." Do you inspect the copies of their diplomas and licenses for authenticity before you accept any advise from a doctor?
    As a matter of fact, I am a veteran submarine officer, USNA graduate, with a master's degree in Environmental Engineering from the U of Washington. Intensively nuclear trained while on active duty, as well as having 10 years of experience as a nuclear test engineer and emergency planner for a naval shipyard. Do I need to have my universities mail you certified copies of my transcripts?
    If you are that untrusting of other people's genuine advice and experience in a forum like this, then you have bigger issues that certainly won't be solved by browsing PriusChat.
    I anxiously await to hear your credentials, since you seem to have boundless energy in discrediting the opinions on just about every thread you visit.
  20. darelldd
    6,057
    389
    Northern CA
    I was going to write "crankcase oil" but didn't want to alienate anybody. :)
    There is no engine oil because there is no engine. The electric motor's output shaft support bearings do sit in a sealed oil bath of a couple of tablespoons of synthetic oil. It isn't going anywhere though. It is truly sealed - for life of the motor assembly. And that life is considered to be about 1 million miles of road duty.
