Window won't stay up....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LaniSydney, Aug 31, 2008.
  1. LaniSydney
    LaniSydney New Member
    Hi All
    Thought I would go to the experts with this problem.
    Last week we had a flat battery and since being restarted etc the driver side window will not close automatically.
    When you have it down and pull up on the window close button the window goes to the top and then immediately unwinds to about half way and stops.
    Has anyone come across this before? Is there a reset button somewhere?
    Thanks
    Lani
  2. patsparks
    10,664
    567
    Adelaide South Australia
    wind the window half way down then up but hold the switch up while it goes up and after the window gets to the top for 5 seconds, this resets the auto window.
    I just checked this on another thread using search (top right of each window of PC).
  3. LaniSydney
    Thanks Pat - I will give this a go - i did a search but obviously didn't have the right terms in - thanks for the tip.
  4. patsparks
    10,664
    567
    Please let us know if that works for you.
  5. LaniSydney
    Works like a dream - thanks Pat
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Hurray! Pat with the answer!
    I knew there was a window recalibration technique but couldn't remember it.
  7. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Huzzah, Pat! I had to say Huzzah because we just came back from Philadelphia and the actors made us say it all the time. :)
