will 06-08 taillights fit a 04-05 prius?
Discussion in 'Gen 2 Prius Main Forum' started by mrplease, Sep 14, 2008.
  1. mrplease
    mrplease New Member
    51
    oklahoma city, ok
    just as the title says...
    will the 06-08 taillights fit a 04-05 prius?
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    im going on a limb and say no just because they are seperate part numbers
    i am probably wrong, heh
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    mrplease,
    From recent personal experience, I can say that 04-05s fit perfectly in an
    '08. I'm confident that the reverse is true.
    rigormortis,
    I suspect that the different part numbers comes from the difference in the
    brake lights: darkened in the 04-05, clear in the '08.
  4. rigormortis
    1,340
    26
    san jose, ca
    yeah i wouldn't know. all i know is that the 2004 prius tail light would be $23 cheaper.
    maybe he should post this in the modications forum
  5. rigormortis
    1,340
    26
    san jose, ca
    please do not yell at us if you purchase the wrong part and it won't fit
    but im leaning towards saying yes, because if you go to parts.com all the other tail light parts, like tail light pocket, tail light back, tail light socket and wire back, are all the same parts from 2004 - 2008, with the exception of maybe the quarter panel???
  6. northwichita
    481
    102
    29
    Wichita KS
    I was looking at one on ebay , the later models have a row of led looking lights midway of the light. My 04 doesn't have this. The wiring is the same??
    Also I have the HID lights, which are great, but the front of the headlight is hazy toward the top, and I like the cool additional led's on the later ones. Does the HID option I have complicate matters in making a switch?
    ((Yes, I was focused on headlights- some newer ones were about to be sold on Ebay and my mind went !@!@!, sorry for resulting confusion.) Added several days later. )
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    northwichita,
    I take it you're speaking of headlights here.
    At least on the '08, what at first glance looks to be LEDs are just fashion
    bumps. But they do raise the question, "What if... " It really would look cool
    if they were LEDs.
    But the headlight assembly is sealed and as a minimum, breaking the
    connection between the body and clear lens -- sonic weld? -- in such a way
    as it could be redone with a waterproof seal would be at least a bear, and
    maybe even a b!tch.
  8. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    That row of "LED looking lights" is not actually lights. It is a decorative feature. The same is true with the newer headlight design. Sorry.
  9. rigormortis
    1,340
    26
    san jose, ca
  10. RinMI
    RinMI New Member
    132
    SW Michigan
    Can we get clarification on whether or not the OP is referring to tail lights or headlights here?
    If taillights are the question, the HID thought is moot. Therefore, the answer that i got from my local Toyota dealer is that yes the tail light assemblies are interchangable on the Prius for model years 04-09.
    If headlights are the question and you have HID, why would you want to switch away from them? Even if you do not like them, you would probably have to remove the ballasts and associated wiring in order to switch it out.
    Hope it helps.
  11. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    OP, mrplease, started with tail lights.
    Then, in post #6, northwichita switched horses in mid-stream to headlights.
    I suppose there is a logical, no, make that electrical connection. :rolleyes:
  12. mrplease
    mrplease New Member
    51
    oklahoma city, ok
    tail lights!
    and thanks for the answer!
  13. rigormortis
    1,340
    26
    san jose, ca
    yeah it sounded like they were interchangeable. ill have to mod my car sometime so
    the brake lights match my tinted out windows
  14. RinMI
    RinMI New Member
    132
    SW Michigan
    There was someone on here a while back that had totally blacked out their tail lights. It looked very clean since the tint looks very similar to the body color (their car was black). I can't remember who it was but do remember he was out on the east coast around NY, NJ or one of those New England area states.
    I wish I know of someone around SW MI that could do it.
