Heat Retention, Coolant and Thermos
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Mar 14, 2005.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    isn't that an interesting observation, I'll try that this weekend.
  2. rick57
    rick57 Member
    572
    Circleville, Ohio
    I will have to look for that too. Might be good if a customer asks that question. :roll:
  3. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(prius mdt\";p=\"73114)</div>
    prius mdt, Thanks for joining us here on PriusChat and shedding the light!
    I think 25 extra PriusChat Points will help in your quest. . . but not for getting that “Master Tech†thingie . . . that’s up to Danny . . . the big Kahuna. I’m sure someone, maybe a moderator, will let him know of your presence.
    Danny and the moderators were taking earlier about setting-up a moderated “Ask the Prius Master Tech†Forum (or something along those lines).
    As far as I am concerned, the more Master Techs on PriusChat, the merrier!
  4. Tideland Prius
    16,549
    When you say driver's external door lock, do you mean the touchpad, black button or the mechnical keyhole? Sorry I'm not sure
  5. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Mine is just like rmm20, coolant pump has to stop or no lock from the black button of the SKS at the front drivers door. However if I run to the passenger door or hatch then it will lock before the coolant pump shuts off.
    Wayne
  6. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(ken1784\";p=\"72797)</div> Thank you Ken!
    Just when I think I've found all the good stuff on John's site, something else pops up. (PS -- is this presentation available anywhere in its original PowerPoint format (or better yet, as an Adobe Acrobat file?))
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(bookrats\";p=\"73272)</div>
    Thank you Ken!
    Just when I think I've found all the good stuff on John's site, something else pops up. (PS -- is this presentation available anywhere in its original PowerPoint format (or better yet, as an Adobe Acrobat file?))[/b][/quote]
    You're welcome. :)
    However, I don't know the source.
    John, any comments?
    Regards,
    Ken@Japan
  8. rmm20
    rmm20 New Member
    61
    The black lock button on the door handle.
    Robert
