2004 - 2005 Prius Repairs
Discussion in 'Gen 2 Prius Main Forum' started by Patrick Wong, Sep 17, 2008.
  1. HID headlights
    3.3%
  2. MFD
    18.0%
  3. Inverter coolant pump
    9.8%
  4. Engine coolant pump
    1.6%
  5. Inverter
    1.6%
  6. Transaxle
    4.9%
  7. Traction battery
    4.9%
  8. Front struts/rear shocks
    6.6%
  9. Brake system problem
    4.9%
  10. Catalytic converter
    1.6%
  11. O2 or air/fuel ratio sensor
    4.9%
  12. Engine misfire due to water in spark plug wells
    4.9%
  13. Stereo or nav problem
    4.9%
  14. Other drivetrain problem (pls comment)
    3.3%
  15. Other non-drivetrain failure (pls comment)
    11.5%
  16. No failures
    54.1%
Multiple votes are allowed.
  1. Patrick Wong
    18,200
    6,501
    2004 - 2005 Prius Owners only:
    I'm interested in seeing how reliable the older 2G models have been. I'm limiting the poll to older 2G since various engineering changes were made in 2006.
    The poll will allow you to vote for multiple choices, so if you have had more than one listed failure, please vote for each one.
    If your 2004/2005 hasn't logged any failures, please also vote. For purposes of this poll, let's not count an SSC (aka recall) as a failure. The hybrid vehicle ECU reprogramming and intermediate steering shaft replacement are examples of SSCs.
    My 2004 has 61K miles. So far the MFD was replaced under warranty and I replaced the rear shocks at my expense at around 30K miles since one side was seeping oil. However after I removed the old shocks I found that their compression behavior was similar to the new shocks, so in retrospect they still had some useful life remaining. Knock on wood, the HID headlights have been reliable so far. I had the intermediate steering shaft replaced and the ECUs reflashed per the SSCs.
    If you voted for an "other" failure, please reply with the details.
    Thanks!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    1) I've replaced my MFD
    2) I've replaced my front Struts recently
    3) I had the Fuel filler and gauge/combination panel TSB done
    4) I had a new SKS ECU and keys...but this was due to the dealer error during an SSC, not a problem with the system.
    That's all I can think of. I'm at 79,000 miles on a very early '04 (delivery Oct. 21, 2003)
  3. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Have had a few things, coolant leak and a AC compressor, but this car had a prior front collision and I believe both items were related to that event. The only other thing we've had done is the steering TSB, which was preventative. I consider that no failures, though I'm only at 35k miles.
    Rob
  4. Patrick Wong
    18,200
    6,501
    Thanks for voting, Rob; I agree that failures resulting from accident damage should not be counted.
  5. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I'm one of the "No Failures" guys, at 47000miles.
    Although there is some sort of funky substance seeping out of my lower dash. That's going to be another post topic when I finally get a picture of it...
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've had the water in the plugs problem, repaired out of warranty, unfortunately. I also had recalls done for the brake light switch and the steering, but I had not noticed these to be problems. Overall, it's been very reliable. It's only got about 60,000 km - too bad it's not the greater of mileage or time that counts for warranty expiration.
  7. Flying White Dutchman
    4,376
    313
    nothing yet
    well the ac condensor but thats because a stone hit it! and started leaking.
  8. Patrick Wong
    18,200
    6,501
    I think this should count as a legitimate failure.
    I hope that this is not a mouse-related problem!
  9. pviebey
    pviebey New Member
    78
    No problems at all with our 2005.
  10. Dunlin
    Dunlin Senior Birder
    Grays Harbor, WA
    My late 2005 (August) has 36k miles and no repairs needed.
    I did replace the tires at 27k, but that's normal wear for the OEM tires.
  11. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    manufacture date 2/05, 56k miles
    1. replaced window run to stop a rattle- warranty
    2. replaced visors- warranty
    3. replaced upper glove box door- warranty
    4. steering shaft recall- warranty
    5. replaced squeaky CHS water pump, but no failure prior to replacement- warranty
    6. replaced halogen headlights and taillights- $20
    i wouldn't expect the 04-05 HIDs to be a problem, they weren't an issue until 06.
    and damnit, my car is not old. :)
  12. captnpops
    captnpops Junior Member
    17
    Salt Lake City
    no failures... 72,000 miles!
  13. Flying White Dutchman
    4,376
    313
    wy? every car can have this its more a unlucky moment.
    its not a failure in design of the car systems or build and no warranty replacement.
  14. Patrick Wong
    18,200
    6,501
    I assume that we are talking about a small rock kicked up by a truck or car in front of the Prius while driving on the highway. It is predictable that this will happen occasionally if a driver logs sufficient miles on the road.
    I can accept cosmetic or windshield damage resulting from such an incident and would not fault the car's design if such damage occurred. In fact I have a small dent on the roof of my 2004 where a rock bounced off the windshield (without damaging the glass) and hit the sheet metal.
    However I think it is reasonable to expect that the Prius will not suffer mechanical failure due to this issue.
  15. Flying White Dutchman
    4,376
    313
    so my condensor failing because off a small rock hitting it is not a legitimate failure
  16. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    All has been well, currently at 96,000 miles
    PA P
  17. IDrivePrymaat
    IDrivePrymaat Junior Member
    67
    SoCal
  18. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    I've got a loud bearing in my hot coolant storage pump when it's really cold outside, but since I live in northern CA, it's no longer an issue.
    I chose "no failures", 29K miles.
  19. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    2k5 Prius... going on 3.5 years, and no issues.
    I would expect more problems/failures with the 2k4 MY since it's the first year of a new generation.
  20. birdsquared
    birdsquared New Member
    46
    Burnaby, B.C., Canada
    No problems with my 2004, though I only got it in December of last year. It's at 110K miles (got it with 95k), and no problems were noted in the previous (one) owner's service log.
