Replacing OEM Tires
Discussion in 'Newbie Forum' started by amidetx, Sep 21, 2008.
  1. amidetx
    amidetx New Member
    Just got my Prius (used 2007) with less than 10,000 miles. But tires have significant wear, especially on front. Have had great luck with Goodyear Assurance Tripletred on previous vehicle (2001 Honda CRV) and was disappointed to learn they aren't made in the size recommended by Toyota, but there were some similar sizes. Has anyone successfully changed to this tire on their Prius?
  2. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    There are several Priuschatters running on GY Assurance Tripletreds at a non stock size of 195/60 R15. The difference in size is just minimal and only changes the speedometer by less then 1 % (I think it will read 60 MPH and you will be travelling 59.4 MPH)
    It should also greatly improve your handling and stopping distances at a small cost of gas mileage.
    A good place to buy them is on Tirerack.com for just $92 each plus shipping of about $10 per tire.
  3. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Just put on my second set, great tires.
  4. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    I changed to Tripletreds and they are wonderful tires. The ride is SO much smoother and quieter. Handling is improved markedly and the rain handling is fantastic. It even will do well in snow!
  5. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I was just going to ask if anyone had them in the snow, how much change in mileage should we get with these?
  6. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I think it would be relatively hard to find a tire worse than the OEM GY Integritys.
    I just replaced mine early because I picked up a nail or screw and had a flat.
    I chose Michelin X Radial DTs. They are reported by Consumer Reports as low rolling resistance (I have yet to confirm that) and nearly tied for first place in their reviews.
    They are much much better than the OEMs. They track better, corner better, turn better and are quieter. I haven't had them in the wet or snow yet so I'll have to leave that report for later.
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I love TripleTreds. This is the third car I've put them on. All things considered (handling, braking, noise, comfort, wear, rolling resistance, etc.), I think one would be hard pressed to find a better all season tire for the price.
    I also think that a lot is gained by moving to the 195/60/15 size -- improved handling and braking. When Consumer Reports road tested the Touring Edition, it noted that the Touring's 60-0 mph braking distances were 10 feet (dry) and 12 feet (wet) shorter than the Standard Prius'. Those are huge improvements. My bet is that the Standard Prius equipped with 195/60/15 TripleTreds will have braking distances similar to (and maybe better than) the Touring's.
