1st oil change Q
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kojiono32, Mar 16, 2005.
  1. kojiono32
    kojiono32 New Member
    Granada Hills, California
    Hi all,
    I have a question about oil change.
    When(how many miles) and which brand?
    Is Toyota dealer oil change worht it? or JiffyLube will be ok?
    Thanks
  2. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    mobil 1 synthetic
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    jiffy lube will be fine. make sure to tell them to not overfill. they actualy use the quart containers (helps to keep them from overfilling).. but remember 3.5 quarts.
    5k miles for each change. you can do first as early as 1 or 2k if you really want to. just to clean out the engine.
    oh yeah.. if not done at toyota, keep receipts so you can prove it was changes x amount of miles.
  4. KTPhil
    KTPhil Active Member
    1,379
    Also tell them the car uses 5W-30, not 10W-30 like most cars.
  5. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(V8Cobrakid\";p=\"72857)</div>
    Keep your receipts whether you go to Toyota (they should keep records anyway), Jiffy lube, or even if you DIY. Toyota will want some proof that you have kept it maintained if you ever have a problem.. Comes in handy when the factory guy asks for proof, :wink:
