A/C AUTO -- set it and forget it?
Discussion in 'Gen 2 Prius Technical Discussion' started by Bluesguitar, Oct 14, 2008.
  1. Bluesguitar
    Bluesguitar New Member
    Boston
    I'm trying to figure out whether I gain anything relative to climate control by using any setting other than "A/C AUTO."
    I'm figuring that running the A/C can't help fuel economy, but going into the CLIMATE screen and turning off A/C while leaving the temperature goal the same seems wrong to me somehow.
    Do most people just leave it on AUTO A/C year round and just adjust the temp you want on the steering wheel? That seems to work fine.
    Thanks.
    Mitch
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I leave mine in Auto A/C all year and adjust the comfort level with the temperature control. Keep in mind that the AC compressor is electric and will only run when needed for cooling and humidity control. It doesn't use that much gas.
  3. qbee42
    3,079
    +1 on that. Keep in mind that not only is the compressor electrically driven, but it is variable speed. It only runs as much as needed.
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Firepa's right in that the A/C is electric. You will see a minor hit to your hybrid battery's charge (since it's powering the A/C) but normal ICE recharging takes care of that.
    If you set the temperature without the "Auto A/C" the Prius will attempt to hold the desired temperature using what it's got: either recycled or outside air, depending on the setting.
    If you want to use the "Auto A/C" then yes, just set it and forget it. It's a truly automated system in that it will heat or cool as needed and the fan will speed up or slow down as needed. It will even adjust which vents to use based on the fan speed and desired temp.
  5. dwdean
    dwdean Member
    377
    South Florida
    The only thing that I'd add to the "set it and forget it" philosophy is that I find on very hot days I sometimes have to force the system to re-circulate air instead of trying to bring air in from outside. The car never will cool down if it tries to bring 95+ degree air in from outside and cool it to my set point. However, if I just hit the re-circulate button, the car cools down reasonably quickly.
    I'm guessing that this may also be true in very cold temperatures with the heater on instead of the AC compressor.
  6. richard schumacher
    7,664
    1,046
    United States
    Yes, but I also force re-circ because I hate breathing Diesel exhaust.
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I like a lot of fresh air, so most of the year I have the system set on 'max cold' to force the vent setting. "Too hot" for me kicks in at about 40C, and "too cold" means putting on another layer. Other than the all-too-rare vacation, most of my driving is Dad's taxi service. I'll toggle the defrost as needed, but usually I'm not going far enough for the heating or cooling to have much effect. Yes, I know short trips aren't good for the mileage, but neither is driving out of my way just to bring the average consumption down.
  8. dwdean
    dwdean Member
    377
    South Florida
    There's that too....funny, but that's usually the thing that reminds me that the car has flipped over to "vent", when it's 95 out and I can smell the truck in front of me.....
    I just have to be careful to remember to but it back on "vent" for a while or you wind up with "AC funk" as discussed in many other posts.
  9. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Think of AC as climate control, not cooling.
  10. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Mitch,
    You will find that you need to force it to 'floor/defrost' to keep the windshield from fogging in the fall and Spring, maybe winter too. IMO, it SHOULD be the automatic position any time the outside temp is 40F or below, maybe even 45F. I don't know what the set point is for the computers but it is MUCH too low. I really wish this set point was customizable.
    So, you can hit the Auto A/C on the wheel, then the Climate button on the MFD surround, the the Floor/Defrost on the MFD. It will still manage the temp and fan speed for you.
  11. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Mitch:
    Also remember that the car relies upon "recycled" cabin air to cool the traction battery (that's what that mysterious vent by the right rear passenger's shoulder does). Though it may not be a huge issue in your climate, trying to "sweat it out" to save gas as you might do in a conventional car, can turn counter-productive should the TB get too hot. The ECU will act to protect it if it does, and the result will be an mpg hit. I'm with the set it and forget it group. Just use the temp settings to moderate it (and occasionally mode too), and you'll do fine.
  12. peirhead
    peirhead Junior Member
    48
    PEI Canada
    So let me see if I understand this...if I turn off the A/C when in "Auto" mode then the system will still still try to meet the target temperature....right? What happens when you are not in "Auto" mode and have the A/C turned off...does the system still try to meet the set temperure?
    The Owners manual entirely skips how the system operates when not in "Auto" mode.
  13. qbee42
    3,079
    In manual mode you have to manually set the fan speed and vent settings. There is no temperature setpoint in fully manual mode.
  14. TonyPSchaefer
    14,816
    2,501
    66
    This is because when the system is not in "Auto" mode, it operates the way you tell it to.
  15. peirhead
    48
    PEI Canada
    Thanks Tom...if that is the case what air comes off the fan..hot? cold? If the temp setting doesn't do anything in manual mode how does the car know if you want heat or not, just from fan settings?
    In an older conventional car there is a manual heat setting, non thermostatic, that regulates how much air passes through the heater core.....Does the Temp setting on the Prius also determine the amount of air passing the heater core ( or regulate the temp of the heater core itself?
