Removing the Upper Grill "Smile"
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Rokeby, Oct 19, 2008.
  1. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Several times on several threads, posters --including me -- have asked how
    to remove the "smile" in the upper grill. To my knowledge, the questions
    went unanswered... until now.
    This process isn't particularly difficult, allow about an hour for disassembly,
    then reassembly. Along the way there are 15 fasteners of four kinds to be
    dealt with. Necessary tools are:
    * Flat bladed screw driver
    * Phillips head screwdriver
    * Small ratchet with socket to hold a standard short Phillips head bit
    Notes:
    Do this in warmish weather, I would guess 60+ deg F.
    If you've replaced the OEM horns, much of this will be familiar
    First, remove the flatish black plastic radiator shroud. There are 6 plastic
    fasteners that require a quarter turn with the Phillips screw driver. Note:
    Just below the windshield wipers, there is a convenient tray to hold all the
    fasterers as they are removed.
    Next, remove the five fasteners that secure the upper edge of the plastic
    front bumper cover. Three of the fasteners pop up using the flat bladed
    screwdriver. The other two secure two hood cushions and require the Phillips
    head screwdriver.
    Here things look scary, but its not at all that bad. So, with heart in mouth,
    lift and bend the upper edge of the bumper cover forward near the center.
    Peer in and you'll see the "smile" is retained with four Phillips head sheet
    metal screws. Two of the screws are about 6 inches off center on either
    side. Two of the screws are about 2 inches in from the ends, and are
    obstructed by some metal brackets.
    There isn't much room to work, Here's where you need the ratchet cum
    socket and Phillips bit. The end screws are the more difficult, start there to
    ensure that your ratchet tool will work. On the drivers side end, reach down
    inside the bumper cover with your left hand, grab the smile/grill, and pull
    up and towards you to get at the screw. You have to exert considerable
    force. You'll be surprised how much the bumper cover will bend, then return
    unscathed to its original shape. Work the screw out, in 1/6 - 1/8 turn
    increments. The screws near the center are much easier to remove.
    Repeat for the center and passenger side end. The "smile" is still retained by
    two plastic flat flanges positioned about 6 inches off center on both sides.
    Work one end of the "smile" free. Then pull and wiggle it towards you. It will
    eventually free itself. Voila!
    Do what ever needs be done and remount or replace with a new "smile" as
    appropriate. STOP -- If you are mounting a new "smile," you can make the
    job easier by using the sheet metal screws to pre-thread the mounting holes
    before you installl the "smile."
    Begin the reassembly by getting the plastic flanges in their slots. Push the
    "smile" on snugly. Mount permanently with the screws, again it will probably
    require 1/6 - 1/8 turn increments on the ends. The driver side end screw
    may be some what difficult. Resecure the upper edge of the bumper cover
    and the radiator shroud.
    Now, that wasn't so hard, was it?
  2. sandman
    sandman Member
    277
    32
    kentucky
    What, no before and after pics??
  3. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Once I got up the resolve just to begin, the process was straight forward and,
    well, linear. No real complications, except perhaps the ratchet/socket/Phillips
    bit work-around. Pictures didn't seem necessary.
    I guess that I was mistaken.
  4. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    You sure were.
    Any serious modder would know to take pictures every step of the way. :)
  5. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
    So, what does this new "smile" look like? How about a post-op photo?
    Thanks
  6. mechanic
    mechanic New Member
    please post pic, i would love to see how this looks
  7. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
