Excited... picked up new snow tires...
Discussion in 'Gen 2 Prius Main Forum' started by fish_antlers, Oct 17, 2008.
  1. fish_antlers
    fish_antlers New Member
    200
    Ca
    After speaking with a close friend of mune who onws a prius and lives in bend, oregon - where it snows a LOT - I just picked up 4 Nokian Hakkapeliitta R tires mounted on steel rims...
    After everything he's told me - I can't wait for winter to come so I can try them out! He said his prius with the Hakkas beats both his SUVs in the snow!
    (warning, they're not cheap)
  2. fish_antlers
    200
    Ca
    wow... surprised no one has commented on this.
  3. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    I have a set of RSi tires that have seen me through 2 winters so far. I'm very happy with their performance. If the new R lives up to it's billing (including even lower rolling resistance than the RSi ), it should be an excellent choice.
  4. Prius313
    Prius313 Member
    219
    You will love them, Fish Antlers. I've been using Dunlop winter tires for the past several winters and they make a HUGE difference especially going up a hill. Wouldn't go out in the snow in my PRIUS without winter tires.
  5. rpg51
    rpg51 Member
    200
    Vermont
    I just bought a spare set of wheels and I'm about to buy Nokian snows. Tell me, will the Nokian R give anything away to the Nokian Hak 5 as far as all out ice and snow performance do you think? Given my recent experiences goinog up hills on loose gravel I am frankly very concerned about the performance of the Prius in slippery and hilly country like we have here in Vermont pretty much all winter long. I'm determined to do everything I can possibly do to avoid problems - even if it means giving up a little as far as rolling resistance.
  6. Patrick Wong
    18,210
    6,511
    Congratulations on your acquiring new winter tires.
    Regarding your friend and his SUVs, are those vehicles 4x4 or 4x2; what kind of tires are they equipped with; and what is the tread depth of those tires?
  7. fish_antlers
    200
    Ca
    pat... he owns several 4 wheel drive vehicles.
    rpg - from speaking with nokian directly the hakka R sits at the top of the product line. I was told there is no snow tire avail that's more agressive/has more traction on the market... next step is studded.
  8. rpg51
    rpg51 Member
    200
    Vermont
    Yea, I was going to get the Hakk 5 but I don't run studs so I am going to switch to the R if for no other reason that it apparently has less rolling resistance - I'm hoping maybe it will be a little quiter than the 5 as well. I thought about studs but its $18 per tire extra and given the price of these tires I just can't bring myself to spend the dough. Plus, I'm not really sure about studs - I used to run them years ago and it seemed like they were very noisy and wore down by the end of the first winter anyway. I'm convinced the R is every bit as aggressive in snow and maybe a little better in wet.
    I'm dreading the first time I drive to a meeting and find a foot of snow in the lot at the end of the day. I just have a bad feeling that this Prius is going to be a problem in certain situations. Nothing worse than struggling with a car stuck in the snow in a suit and wingtips! I may carry a tow rope and a shovel for the winter. Hopefully with a little modification of my winter driving techniques and some good snow tires it will be fine. We'll see.
    We will have to compare notes as the winter progresses!
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I'm glad I came across your post. I leave bright and early tomorrow morning on a business trip, back in a couple of weeks
    For winter I run 4 "multi-fit" steel wheels from Canadian Tire, with Goodyear Nordic studded snow tires. This snow tire is exactly the same as the Goodyear Ultra Grip 500 sold in the EU
    Goodyear Eur-Winter Tire-UltraGrip 500
    If you click on Profile, a Flash movie loads that explains the tire construction and benefits.
    This is a very aggressive winter tire, on dry pavement it hums like a truck bias-ply mud tire from the 1970's. On snow and especially glare ice, it can't be beat
    I should warn you *not* to use the Toyota OEM lugnuts that are for the factory aluminum wheels. At least in my case, they dangerously loosened up! You should put the proper "acorn" style lugnut on a steel wheel
    I got my lugnuts at Napa. The box is marked #641-2042. The correct size/thrad is M12-1.5 X 21mm
    Napa dinged me $20 or $1 a nut
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Incidentely, the same lugnut fits my FJ as well. I run steel wheels and Toyo Open Country G-02 Plus studless snow tires for winter. Good snow traction, but the ice traction is inferior compared to my Prius running the studded tires
    I'm considering putting on a set of Hankook Dynapro I-Pike studded truck tires. They have a soft tread compound like the Open Country, with the added safety benefit of studs
  11. Romeo
    Romeo New Member
    27
    Calgary AB
    I've been using Nokean tires for quite a while. In addition to exceptional performance, they have great durability, even on winter tires the tread should last for about 80,000 km (50,000 miles). I still use Nokean RSi that I purchased in November 2004 on my wife's car and they are not even half way through yet (appx 40,000 km of driving). I installed Hakka R last week on my Prius and noticed significant improvement in coasting. Not sure if it is the low rollong resistance feature, though because I also did wheal alignment.
  12. Emilio
    Emilio New Member
    Rhode Island
    Question, how do these tires effect mileage ?
  13. fish_antlers
    200
    Ca
    uh... who cares? SERIOUSLY... think about it... snow... ice... if you want to sit there and spin your wheels, go right ahead... i think there are many factors that will effect your mileage in greater ways in a snow storm
  14. rpg51
    rpg51 Member
    200
    Vermont
    Its a close call whether to run studs for me. I certainly could use them here in Vermont. But, I have found that the high end Nokian studless snows seem to be almost, but not quite I agree, as good as studs on ice - its really pretty amazing how good they have gotten. They perform a lot better on dry and wet which in reality is about 50% of my driving even in the dead of winter. Also, the studless nokian - like the R - is a low rolling resistance tire. Also, the R is MUCH quieter on dry pavement. So, while I totally understand the decision to use studs, I've decided to go studless, (in a snow tire sense only:)). I found some original equipment toyota alloy wheels for a reasonable price and decided to go with them - it was a little bit more $ than the steel wheels, lugs and hub cap option - but really not all that much more after you add in the hubcaps and lugs that you need with steel wheels.
    We'll see how it goes. I hope I don't regret the studless option - but it is certainly possible I will.
    As far as MPG goes it is my understanding that the Nokian R is actually very good in that department - I honestly don't know that for sure - but that is what I have read in various reviews - most of it probably propaganda of course. But I agree, whatever the mpg hit I am going to use full bore snow tires in winter on this car given where I live and work. If I lived in RI I would not get snow tires and deal with the semi annual switching issue - I would go with a really good all season.
  15. Emilio
    Emilio New Member
    Rhode Island
    I agree as well, just curious as to the MPG
  16. Emilio
    Emilio New Member
    Rhode Island
    Vermont wow, never thought about seriously using my Prius in heavy snow conditions, figured I’d still use my gas guzzler SUV for ski trips to Stowe. Have you been through a Vermont winter with your Prius as of yet (Studs or not?)
  17. rpg51
    rpg51 Member
    200
    Vermont
    I just bought this Prius a few months ago and I'm frankly annoyed at Toyota for not disclosing the potential problems a Prius presents in my climate and hilly terrain. I had no idea it was a problem getting up slippery hills when I bought it. I have an 4x4 Pick Up to fall back on if need be. But I'm planning to use this Prius most of the time. Call me crazy - I don't know. But there are a lot of people here that have purchased a Prius in the last year - you see them all over the place. Kind of like Subaru was years ago in Vermont. I know I am going to have to be very careful not to put this rig in hard places to get out of. Last weekend I visited a relative at a lake house he rented. It had a long, winding, steep and very narrow drive with loose gravel. I wasn't even thinking about the Prius issue and I went ahead and drove down there. The first time I tried to drive out I was stopped dead at the first steep switchback. I backed down and had all the passengers get out and then I made it up - barely. I suspect it will be fine as long as I don't head up into the mountains and avoid steep drives where you have to start up hill from a dead stop. Also, I do think part of the problem is learning how to stay off the pedal to keep the wheels from spinning. As soon as they spin your dead in the water.
  18. fish_antlers
    200
    Ca
    thx for the tip... I'll look into that!
  19. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    While during the actual snow storm and the rare times that the roads are actually significantly ice/snow covered I wouldn't care about the mpg. And, as you suggest, the impact of snow tires during that time would likely be very small, some of us do care about the other 80% of the time.
    The point, for some of us, is that there are maybe 2 days per year where I live that snow tires would be of significant benefit. Some times there are more days...last year there were maybe 10 days here thanks to some serious ice storms and long delays in clearing the road in my little subdivision. But even then the main roads were clear.
    It's about compromises and that's why I, for one, care. If I lived in Minnesota or Alaska it would be a no-brainer...too many days, too long of distances to travel, and snow tires would be mandatory. Where I live now with so few days of signficant snow on the roads and my current tires being 'good enough' and offering better fuel efficiency for the other 118 days of winter I've chosen to stick to the Hydroedge tires.
    So don't minimize people's questions just b/c you haven't considered each person's individual circumstances. Nobody judged your decision to get snow tires, why be hostile when they ask a legitimate question.
  20. fish_antlers
    200
    Ca
    agreed.... wondering if there is any way to turn off the "traction control" (though it hardly qualifies as this) or the ABS... as simple as pulling a fuse? anyone accomplished this?
