Help! Code 293 after plug-in conversion
Discussion in 'Gen 2 Prius Technical Discussion' started by EVron, Oct 26, 2008.
  1. EVron
    EVron New Member
    Portland, OR
    After completing plug-in conversion (plug-in supply) on 06 Prius:
    Car operated normally in all modes inititially.
    After about 10 miles, car would only operate in ev only mode.
    Check engine light on when trying to start with on button and car will not go into gear.
    The following morning:
    Engine started on start up.
    Conditions appear normal
    After warmup, check eng light on, car will not go into gear.
    On shutdown, on button is orange, dash displays flashing boxes where PRNDL would normally be.
    Pulled code U293 - Inverter current sensor malfunction when inverter in fail-safe mode.
    Stuck in Petaluma until problem fixed.
    Plug-in Supply folks very cooperative. Company works with customers
  2. PeakOilGarage
    PeakOilGarage Nothing less than 99.9
    334
    Pacific Northwest
    I know it is too late to change your choice, but why did you do Plug In Supply instead of Hymotion?
  3. Flying White Dutchman
    4,376
    313
    i think because of price!
  4. jstack
    jstack New Member
    211
    40
    Chandler Arizona
    I
    I have the 10 Kw lithium pluginsupply system and have never has that problem. I've only been driving 24-30 miles each day for 4 months in all electric mode. It is perfect.
    It cost less than trading a 201 that only gets 51 mpg. I go totally electric. We finally had to buy some gas after 3 months for a longer trip.
  5. richard schumacher
    7,664
    1,045
    United States
    I wonder whether EVron ever made it back to Portland?
  6. dcoyne78
    dcoyne78 New Member
    135
    I would also be curious about how this problem was resolved
  7. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    Did you ever get this issue resolved?
