Shock replacement on 03 Prius
Discussion in 'Gen 2 Prius Main Forum' started by Prerun4fun13, Nov 10, 2008.
  1. Prerun4fun13
    Prerun4fun13 New Member
    Pacifica
    Ok i just bought a 03 Prius and it rides pretty soft like the shocks are worn out on it. So i am a mechanic but i have never really done anything on these cars other than a oil change. So anyone know what is involved and what does a typical shop charge? Oh ya and it has 90k miles and is all stock..
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    The dealership wanted $600 (labor only) or so to swap my struts and springs on all 4 corners. I went to a local performance shop, and they offered the same labor for $120. The Prius does have fairly soft suspension, so your ride experience may be normal. A quick visual inspection to see if the struts are leaking would be a good start.
  3. Patrick Wong
    18,200
    6,500
    It really is not hard to do this job if you have experience replacing the struts on other Macpherson strut-equipped vehicles. The first photo shows the cowl parts that you have to remove to gain access to the top of the front struts. The second photo shows a removed rear shock, just for fun (I didn't take a photo of a front strut.)
  4. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    it has been reported that the 7 year 100,000 mile extended warranty covers shocks and struts, the prius house of rumors and urban legends says they are not specifically excluded from coverage.
    if you bought into that, it might be worth checking out
  5. Prerun4fun13
    Pacifica
    thanks for the info guys im gonna do it....
