Negative Prius review in 2009 buyers guide
Discussion in 'Gen 2 Prius Main Forum' started by cycledrum, Nov 13, 2008.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I was browsing through a 2009 'Ultimate Car Buyers Guide' from the editors of Automobile magazine at Borders Books tonight, of course going straight to the Prius review.
    It had a full page review of the Prius with a large pic of a Silver Pine Mica, that was kinda negative. They called the 1.5 liter engine 'feeble', warned that if going up and down hills, the battery can get drained thus making the 'puny' engine do all the work up the next hill. And said the weight of the car is relatively heavy.
    Anyone found the claim of the battery getting drained going up and down hills to be true?
    I haven't seen that yet although I'm still pretty new at it.
    Don't mean to stir up poop, but geez this review seemed biased. I like (and trust) Consumer Reports much more.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    yep... in really long uphill grades.
  3. Tideland Prius
    16,431
    Yeah.. if your hill is the Rocky Mountains at their steepest grades... I've never drained the battery going up the side of a mountain. If any I'll drop from 6 bars to 5 bars and depends on your speed. I've gone up a mountain at 100km/h and dropped to 4 bars but that was because I was doing 100km/h up the mountain.
  4. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    never drained completely but i was down to about 2bars...going from LA to LV via the 15North fwy at about 75mph
    5 people in the car, AC on @ 73, trunk full of luggage, and practically a full tank of 87 octane gas
  5. patsparks
    10,664
    567
    Adelaide South Australia
    I've never had an issue but things are different here I'm told.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Cycledrum,
    Sure it can happen. But you know people do not stick their hands into blenders either ;-).
    With the Prius there is some education needed. On tha dash board there is this thing called the MFD. When your climbing the long grade look to see if you have continuous yellow arrows. If so, slow down until they go out. If the grade remains the same, you should make it to the top of the hill with the same battery SOC as you started.
  7. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    I've only made one trip into the mountains with my Prius. Just a small climb from 5200 to about 8800 or so. Got to the top after a pretty much continuous climb with 2 bars left. By the time I got down to the plains, however, the battery got to all bars filled (first and only time so far). And while specs wise the engine is wimpy, the CVT allows a much faster pickup from 0-30 than a lot of cars and much faster than my S-10 Blazer- I admit I've tried it a few times!
  8. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    The quoted reference didn't say mountains, it said up and down HILLS. So the answer is the reviewer is full of BS. I drive from Burlington, VT to Northampton, MA on I-89 and I-91 once a week. There is barely a flat section anywhere, it is ALL up and down hills, cruise control all the way. My battery bars are ALWAYS 6 blue to 7 green, except on the steep downhill where it can go to 8 green. There are sections where it will run on electric only, even at 65 when the hill is just the right slope. And sometimes it will be in 'glide' (no arrows either direction) all by itself for 10 to 20 seconds. The car is clearly 'smarter' than the reviewer.
    Can you drain it going up to Angel Pass in Colorado? I am sure you can, that is one long up hill. But even then the car won't damage the big battery, it will just stop using it.
  9. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Well, you ARE upside down and counter-clockwise.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I drain the battery down to purple every time I drive to Santa Fe or Los Alamos at a couple of long inclines here in New Mexico. Doesn't bother me or the car one bit, although I do drive in the rightmost highway lane, and have no illusions about passing other cars.
    OTOH, I average 55 - 60 mpg on those trips. Pick your trade-off.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Crazy Aussies. They wander around in bathing suits in the winter.
  12. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    I drive, on a daily basis, 60 miles from NH to MASS> I start at 1260 feet ASL down to 200 feet elevation. I go back up at the end of the day. Never had any issues with the battery draining.
    What I do like is that I get about 20 minutes of gas free motion daily travling down the hills.
  13. bushface
    bushface Junior Member
    Spruce Pine NC
    I live in the mountains of western North Carolina. We have no flat roads just up and down with curves. My car is hardly ever below 6 bars except going up Coxes Creek Road which has upto a 14% grade, most of the grade is at least 10% for about 2.8 miles, which it normally has at least 4 bars with me passing most traffic. No problem with get up and go all the way up.
    Bunch of BULL in that article.
  14. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Beware of negative reviews of a hybrid. There is a huge status quo industry out there related to gasoline and gas-powered vehicles. A lot of the reviewers are supported by the car and gasoline industry. And there is a glut of unsold dinosaurs the car companies are stuck with.
  15. qbee42
    3,076
    This has been my experience too. On one pass, just shy of 12,000 feet, I was down to one purple bar and stuck behind a nearly stationary truck. When the passing lane cleared I went around him. I had the pedal smashed to the floor with a screaming engine and no perceptible acceleration. I stayed with it and we slowly gained speed. The faster we went, the faster it seemed to accelerate. You aren't going to snap your neck from acceleration, but it will get you up and over any mountain pass, and get 55 mpg in the bargain.
  16. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    The only time I have gotten crap mileage and had the ICE do all the work was going up the Tejon Pass with 4 people and full luggage.
    The Tejon Pass is a mountain pass at the southwest end of the Tehachapi Mountains linking Southern to Central California. It traverses the boundary between Los Angeles and Kern counties. Its highest point at 4,160 feet (1,260 m).
  17. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    On many occasions I've been full of people going up long 10+ mile 7% grades at high speed 80-90mph. It gets down to 2 bars (even 1 bar) but it still holds the speed. I don't see any noticeable difference going up the grade when the battery is drained.... at least at high speeds. The CVT does a great job at maintaining speed.
  18. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    I have done that trip too, on our twice-a-year trips to Ashland, in Southern Oregon for the Shakespeare festival there. The only difference is that we are normally only two people aboard, plus luggage for a week or so stay in Oregon. Never had any problem with the Grapevine transit over the Tehachapis or in the northern reaches of the I-5 in California, where there are a number of fairly long grades, though usually never more than around 6% or so.
    Your experience with the Prius in this respect will always be a function of the load being carried, the climb distance and gradient and the speed at which you climb. The lower your speed when climbing the less total energy you are consuming, but the fraction used in fighting gravity remains constant. That is until you reach the top of the hill. The Prius gets a big chunk of it back via regeneration as you descend.
  19. Fibb222
    Fibb222 New Member
    1,499
    99
    I get down to 1 or 2 bars traveling between hope and Coquihalla summit and again on the 97C highway between Merritt and Kelowna. It's no big deal. It's never like your on a one lane highway on grades like that. I drive slow only because i don't like to waste gas on the inclines. Given time the engine can accelerate up these hills.
  20. Fibb222
    Fibb222 New Member
    1,499
    99
    Negative reviews of the prius are less common now, but there have been dozens of them over the years. It's mostly just the status quo seekers trying stay alive in a world soon to be dominated by ev's (hevs, phevs and bevs).
