2001 momentary loss of power
Discussion in 'Gen 2 Prius Technical Discussion' started by finco, Nov 12, 2008.
  1. finco
    finco New Member
    connecticut
    2001 Prius
    Latey when I am driving I have momentary losses of power- going along at 30 then it feels like car dies but all power is still on and then within seconds it is fine. This happens about 5 times in a 5 mile drive between my home and work. One time the car completely died, warning came on and said I needed to take to dealer. I turned car back on adn drove home with this warning on but car drove fine. Next day when I cranked car up it was fine as it nothing happened but now I have these momentary power losses. I have 95 K on my car ; no problems really ever. Help. :mad:
  2. Patrick Wong
    18,200
    6,491
    Fuel tank level?
    If good, I suggest you visit your Toyota dealer so that the diagnostic codes can be read.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    There is a possibility that the potentiometer on your gas pedal is starting to go bad. Do a search on this site to get the rebuild procedures. Hopefully, one of the experts on this problem will chime in.
  4. tochatihu
    tochatihu Senior Member
    9,507
    3,669
    Kunming Yunnan China
    2001 Prius
    Welcome to PriusChat, finco the 1st time poster.
    Unfortunately, tangible problems caused by the accelerator pedal do not always set codes. Neither are they rare. Bob Wilson who posts here offers a rebuilding service, but we would want to eliminate other possibilities before sending him money :)
    Just about any other Prius problem *will* set codes, so a Toyota scan remains a good next step. Bring them a bag of cookies and see if you can get it done for free.
    Post updates.
  5. bwilson4web
    15,985
    There are many possible causes. My recommendation is to see if Toyota will do a diagnostic read out of all ECU codes and sub-codes. If you can, find out if they'll also read out all battery module voltages (might as well if it doesn't cost any more.) Certainly share the Toyota recommendations but bring them here since the folks have figured out a few clues. But let's start with diagnosis before going nuts on repair actions.
    One quick question, how would you rate your technical skills? Change your own oil and air filters? Major car repairs like engine rebuild? Pretty much take it to a mechanic? It is mostly a question so we'll not go too technical nor too simplistic in our explanations.
    GOOD LUCK and come back!
  6. finco
    finco New Member
    connecticut
    2001 Prius
    I take it to the Toyota service folks for everything, local station for oil/filter changes. However I can follow more than basic comments....:)
  7. bwilson4web
    15,985
    Excellent! We often have 'hit and run' posters and I'm happy to see your note.
    I'd expect to pay ~$100 to get a good diagnostic read-out and be sure to ask for hard copy of the codes and read outs. Try to get a battery module voltage read out too (it doesn't hurt to ask<grins>.)
    The ambiguity group for 'momentary loss of power' is huge ranging from:
    • loose connector(s)
    • sticky parts like throttle plate and others
    • failing ignition (spark plug system)
    • other stuff that happens
    But the beauty of our Prius are the diagnostic codes recorded in the hybrid, engine and battery ECUs (and the others including brake, body, e.t.c.) With the codes and sub-codes, the service technician can come back with a likely diagnosis. Just ask them to hold off on any expensive repairs until you get a chance to "... talk with my brain trust ... " (that be all of us <grins>.)
    Call the day before for an early morning appointment and bring a good book or something to enjoy.
    GOOD LUCK!
  8. finco
    finco New Member
    connecticut
    2001 Prius
    Thanks, unless my car dies anytime soon, it will be a while until I can get time off to spend a part day at the service place.........plus dollars are short these days with the economy and what not. If it were something with the spark plugs would this not have a tendency to affect starting regularly? Do no laugh if this shows my car ignorance.Car always starts fine, it is just when driving it has these moments were it temporarily loses umph. I am going to pay attention to see if it only happens when gas pedal is depressed or if it happens when foot is not on the pedal (I tend to drive with a light foot and take my foot off gas pedal if going down hills and things). I am leaning towards loose connectors and other stuff- hahaha. Seems like it usually happens when I am going between 20-35; but maybe since I so seldom get out on highway I have just not noticed at faster speeds.
  9. Patrick Wong
    18,200
    6,491
    Yes, a spark plug problem should manifest itself with an engine misfire and the check engine light should come on.
    For fun, I suggest that when the car is IG-OFF, you fully depress and release the accelerator pedal around 30x. The point of doing that is to clean the two variable resistors that are actuated when you depress the pedal. See if that temporarily relieves the driveability symptoms that you note.
    If yes, then you will know that the accelerator pedal assembly needs to be replaced.
  10. tochatihu
    9,507
    3,669
    2001 Prius
    Finco if you don't mind bending like a pretzel, here is an even better way to carry out Patrick's suggestion. Get your face down into the footwell, right near the accel pedal. Attached to its assembly right next to the cable connector is a lighter-gray-colored piece of plastic, shaped something like a "D". Press somewhat hard on the middle of that D with your thumb while 'exercising the pedal'. You will be causing the potentiometer wipers into better contact with the..um..things they are supposed to contact by doing this.
    Oh, and no time/money for a proper Toyota code scan? Go to your local auto parts chain and see what they can pick up with a free scan. It will be incomplete, no subcodes, but better than nothing.
  11. bwilson4web
    15,985
    Another, part to check is the throttle plate. There is also throttle sensor that can go marginal. However, sticky throttle plates tend to show up as starting problems.
  12. DHugh
    DHugh New Member
    Syracuse, NY
    2001 Prius
    I've experienced the same problem with temporary loss of power. Have had check engine come on three times over past 6 months. FIrst visit to Toyota (Lia, in Schenectady, NY) was unsatisfactory--they could not fiugre out the problem. Second visit to Toyota (Romano, in E. Syracuse, NY) yielded code P 420 code, leading to diagnosis of catalytic converter malfunction. Estimate to replace: a mere $2,025!
    My trusted auto mechanic says the loss in power could be related to cat, converter problems. Or not. It's hard to say. My gas mileage has been decreasing, avg = 35-40 mpg December - February, compared with 40 - 44 mpg July - November '09, so I suspect something is not quite right.
    Don H
  13. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    If you check on other threads, you can get after market cats much less expensively. They may not last as long as the OEM, but will the car?
