Visible differences
Discussion in 'Newbie Forum' started by Sundog105, Nov 19, 2008.
  1. Sundog105
    Sundog105 Sundog105
    Roswell NM
    I'm a Newbie, with a 2008 "Option 6." What noticable visible differences are there, to distinguish a "Base" 2008 from an "Option 6" 2008 (other than the wheels, Base has six spokes, Option 6 has seven, but that's really hard to tell when the vehicle is moving)?
    Same question but about distinguishing different years?
    Sundog105
  2. gak27
    gak27 Prius, Take Two
    117
    Akron, OH
    Externally, virtually nothing except fog lights (pkg 4 and above)... (btw, if you have 7 spoke wheels you have a Touring, even Option 6 'standard' models have the 6 spoke wheels)...
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    above poster is exactly right.
  4. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    u can tell a base and any other package by looking for the rear view camera
    u can tell a package 2 from its lock buttons
    3,5, & 6 do not have any external clues that i can think of
    if u see fog lights then its at least a package 4, or a touring (any package)
    if you see a prius driving by and you stick your head out of the window
    you can tell the package from the number of buttons on the display screen too
  5. Tideland Prius
    16,539
    backup camera, SKS buttons, fogs, HIDs (unless it's a base Touring which has HIDs as standard equipment)....
    so basically what the others have said so far.
  6. Sundog105
    Sundog105 Sundog105
    Roswell NM
    Hey guys/gals, thanks for the info!
    I read somewhere that the rear Wing was different on some models; anyone have info on that?
    Also noticed that some antennas are different, but don't know how to correlate that either.
    Sundog105
  7. Tideland Prius
    16,539
    The Touring Edition had a longer rear spoiler. The antenna is the same (unless they changed it to a sharkfin but that is not a Toyota option)
  8. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    x2, so your (referring to the poster) spoiler is actually slightly larger (by less than a half inch I believe) than a base model. You really have to look closely to tell. It's easiest to tell when a touring and non-touring are parked side by side. It's almost laughable that Toyota has separate spoilers since they're so close in size.
  9. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    The wing/spoiler on the Touring is maybe 2 inches longer that the Standard
    one. Don't know how much, if at all, it helps the aero.
    The length does make it much easier to break/crack the Touring spoiler/wing,
    especially if someone uses it as a handle to close the lift gate...
    a very big NO-NO.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    2006 & later have side badges & clear tail lights. 2005 & earlier the top third of the tail light is dark. Color can also be a clue. Magnetic Gray is 2006-, Spectra Blue Mica is 2007-. The red changed from Salsa Red to Barcelona Red 2006-.
  11. Tideland Prius
    16,539
    My friend almost did that. I yelled at him to stop before he could apply any pressure.
  12. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    Sundog, the most obvious difference between a Generation 2 Touring Prius and a Generation 2 Prius are the wheels: 7 spoke with a plastic cover vs 6 spoke with a trim ring.
  13. KAR IDEA
    KAR IDEA Member
    465
    Three Touring
    I did that! It didn't crack though, it creaked. Then my wife looked at me and said "Dave, we've only had the car for a week, please don't break it!" :( Now I use the built in leverage handle...
  14. van-island
    van-island New Member
    17
    Vancouver
    I am going to take possession of my Base 2009 next weekend, but I went and took a peek at it on the lot and I am pretty sure it has the longer spoiler. It also has the roof antenna... although I don't know if this is standard...?
    When I actually get the thing I will confirm!
  15. Tideland Prius
    16,539
    You can use the Toyota emblem for leverage if you must use the outside of the car to close the hatch.
  16. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I use the Toyota emblem on the hood to close - I set the hood down, make a fist and give a push.
  18. Tideland Prius
    16,539
    sounds good to me. I just "hit" the centre of any hood once I lower it down. I don't like dropping it from a height and letting it slam itself close.
  19. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    That's why there are so many rumply hoods out there. Lower your hood to 6 to 12 inches above closure and then just drop it. No huge impact or damage will result. I've seen a lot of dented hoods and hatches from that little push to close.
  20. patsparks
    10,664
    567
    Adelaide South Australia
    The touring spoiler is 1 inch longer than standard. I measured it.
