fuel gauge issue
Discussion in 'Gen 2 Prius Technical Discussion' started by jerrym, Nov 26, 2008.
  1. jerrym
    jerrym Junior Member
    The car in question is a 2007 Prius which I have had for 18 months. I just did a 195 mile trip and the fuel gauge read just over 1/2 full so I decided to get some gas. It took 4.7 gallons, but after I started to drive, the gauge has not moved. I stopped and restarted the car---no movement on the gauge. This has never happened before. Does anyone have any ideas ? Thanks-----Jerry
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    When I topped off once it took a couple of starts to have the gauge show full. It can also take some distance for the gauge to show full on a normal fill of 6-8 gallons. IMO no need to worry. As you continue to drive does it eventually register full or does the next pip disappear?
  3. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Just filled mine tonight and noticed the same phenomenon, but as I drove away, it slowly migrated up to full scale - took about 2 minutes.
    I suspect it takes time for the levels in the tank and the secondary reservor to equalize.
  4. jerrym
    Thanks for all the answers. The car is "resting" today and has not been driven since I posted the question----only 2 miles from the gas station o my home. I will let you know what happens----jerry
  5. jorgeez
    jorgeez New Member
    121
    Might be a problem with the floater or the sensor?
  6. jerrym
    Thanks again----took the car on a 65 mile trip---the gauge has not moved at all. Guess I will drive 200 -300 miles and if it does not move, I'll fuel up again. If the problem goes away, great. If not, it's a trip to my local dealer. Jerry
  7. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    Maybe refueling will help.
    The systems probably differ enough to make my 2002 Audi A4 experience irrelevant to your Prius, but just for entertainment: here is the story.
    I left a thermoelectric cooler rated at 4.5 Amps plugged into the cig lighter accidentally. Two hours later the 6-year old OEM battery was depleted enough that the cabin lights came on dim and when I (foolishly) tried to start the car the engine would not turn over. I saw the 12V line dip below 7V on my ScanGuageII readout, and as it only samples once per second and I was not watching continuously I don't know the real low.
    After I recharged the battery everything work fine, except that a few remembered entries were gone, and the gas gauge read zero. Not low, zero. The tank was actually about full, so I drove it long enough to be able to put in three or four gallons. For the next half hour of driving the indicated level steadily rose, finishing at about right.
    Oh yes, I did replace the 12V battery before winter came.
    It is worth remembering that even the dial gauges on modern cars are often just computer readouts, and if one feeds the computer an unexpected sequence of events, it may provide an absurd output.
  8. jerrym
    Just a quick follow up. I drove 200 + miles, filled up again and lo and behold, the fuel gauge registered full and after a week seems to still be working properly. Thanks again to all who answered---Jerry
