Expensive Brake Light assembly
Discussion in 'Gen 2 Prius Technical Discussion' started by Hank Brandenburg, Dec 3, 2008.
  1. Hank Brandenburg
    Hank Brandenburg New Member
    Bristow, VA
    The right brake light is out on my Prius. The dealer quoted $450 for the part and of course labor on top of that to install it.
    I have two questions:
    1 - Anybody have a cheaper way to buy this part?
    2 - Any recommendations on repair manuals for the Prius?
    Thanks for any help you can provide - this will be the first time I've had to work on car.
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
  3. Qlara
    Qlara New Member
    488
    The brake lights are LEDs, but is it always required to change the whole assembly whenever the lights out? This sounds excessive.....
    Maybe you just need the LED light module for fixing?
  4. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Let's see if I can preclude any further uncertainty re: my earlier post. :)
    At a quoted price of $450, :eek: I nice person-u-me-d :confused: the OP was referring to the
    one-piece tail light assembly. This unit does in fact house an LED brake
    light array; and three incandescent bulbs for turn signals, reverse and running
    lights.
    There are somepost/threads floating around in the data base about there being
    a possibility of replacing individual LEDs. Use of the search function should turn
    them up.
    IIRC, a used but good tail light assembly goes for ~$150.
  5. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Usually you can fine one on eBay for much less than new. There are even some 2006-up NEW lights for $183 right now. You could replace both (to match) for less than the dealer charges for one.
  6. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
